Bush dled40fhds no backlight
  • sbt123
    • Feb 2022
    • 9
    hello all,could some please offer some advice,on the above tv,when switched on there is image on screen (with torch shining at an angle at the screen),but no backlight,i ave checked voltage at the led pins on the power supply as the set is switched on,it starts around 48v then slowly drops to zero,the power supply is a vestel ips12.
    Thank you.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Bush dled40fhds no backlight
    if i remember rightly these sets have 3 led strips in the panel and can sometimes fail on the connecting joints have you got a led tester and have you ever stripped a lcd panel down to the leds
    • sbt123
      • Feb 2022
      • 9
      thanks for your reply,yes i have stripped down a tv to replace the leds before,but vowed never to bother again,what a pain.lol
      Im afraid i dont have an led tester.
      • sintv
        • Feb 2015
        • 37
        • scotland
        Common problem is the panel connection to the led strips as other poster said. Check for continuity between connections though it helps to have power supply to confirm leds are okay. Still involves stripping it down.
        • vinceroger69
          • Mar 2012
          • 6714
          if your thinking of doing more tv repairs its certainly worth getting a led tester try to get one with voltage and mah display as they are the better type
          a tester like this is ok https://www.ebay.co.uk/itm/284653056...8AAOSw74BiCiI7
          • sbt123
            • Feb 2022
            • 9
            quick update ,,all back together fixed and working now,i reluctantly stripped it down lol,luckily as 2 other members suggested itwas indeed just one of the connectors to one of the strips of leds not making contact just put a tiny amount of solder on the pcb contacts,and all leds working again.
            Thank you for your help.
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
            • gabrielA7
              Macbook pro A1706 / Backlight flex cable compatibility
              by gabrielA7
              Hey guys!!
              I’ve got a question here!
              I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
              Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
              Here’s what the bot told me:
              I said to him: “I’m going to install the 821-01229-A.”
              ChatGPT replied:
              Understood — but before you solder or install the 821-01229-A,
              11-11-2025, 03:26 PM
