Pyramid 7" LCD - No stable picture
  • pentium
    • Mar 2006
    • 2778
    I picked up this dinky 12V LCD panel at a flea market and it has at the least a composite video input however when I power it (from a bench PSU), all I see is a white screen with a horizontally unstable picture.
    That should be the "PYRAMID" logo (sometimes it's a bit cleaner but it's always looking like that) but as you can see, it's pretty hard to make out.
    Inside the unit:
    It has a really nice CASIO LCD controller and subsystem but the video input controller and overlay board is garbage. Poorly soldered joints and it just looks like something you would get in a kit. Reflowing yielded nothing but I'm eyeing these caps.
    Could these be the source of my problem?
    Also, I didn't get to see what the panel was like if I fed it a video signal.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • tmwalsh
    • Jan 2009
    • 119
    Re: Pyramid 7" LCD - No stable picture
    Is the last image a picture of the board at the bottom of the 1st picture flipped over and end-for-end? Doesn't really matter, but replacing the caps on that board would be a low cost experiment. The farthest to the left looks dodgy to me, with apparent 'white stuff' leaking out the bottom.
    As they say "It couldn't hoit..."
    tom
    • Wizard
      • Mar 2008
      • 2296
      The LCD itself is a composite, focus your capacitors check on that. The purple cap is polymer.
      Cheers, Wizard
      • mbates14
        • May 2005
        • 169
        i had a couple of LCD displays that were a different brand, but exact setup as yours, with the exact problem. turned out to be an issue with the panel itself and i never did fix it. so if you figure it out, give me a heads up.
        Also, that panel setup isnt even an active matrix TFT, its a piss-poor low contrast passive PSTN display. and once working, the picture will look awful.
        • pentium
          • Mar 2006
          • 2778
          So you say it's the LCD panel itself that is probably the problem and not the other components like the controller or overlay boards? Damn.
          I don't need a super high resolution. I was going to mount it on my CCD-V5000 camera and use it as a monitor and substitute for the b/w viewfinder.
          Find Nedry!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            had an icom ic-2800h in with that same washed out mess.
            it was a dc-dc converter bad.it was supposed to supply -15v.it was at 0.
            • Wizard
              • Mar 2008
              • 2296
              Exactly, that why need to check all the voltages. One might show wrong as well as bad caps.
              Cheers, Wizard
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Scruit
                What is a normal composite signal range for a C64?
                by Scruit
                Hello all,
                Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                https://imgur.com/gallery/PpqcqPY
                My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                More detail:
                Symptoms are that that I get...
                04-28-2022, 05:33 AM
              • Mgiffune
                by Mgiffune
                I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                I ordered a supposedly β€˜new' Tcon board this time, and
                06-09-2024, 10:28 AM
