Sharp LC-40LE431U Manual control buttons not working properly
  • DRIFT-O-MATIC
    • Apr 2014
    • 5
    I have a Sharp LC-40LE431U TV. The symptoms are when plugged in, the control buttons on the right side panel don't seem to want to work correctly. I get a solid red light. But when I press the Power button, it does not power on immediately. I have to keep pressing ALL the side buttons randomly until finally the solid green light is on. Then when pressing each additional button, they do not always respond correctly, if at all. Pressing the Volume button might bring up the Menu, or vise versa. Even if I can get the Menu screen to come up and scroll through the selections, I still cannot select any of them to connect to a source. Will a complete repair kit solve this, or is it a simpler fix?
    Last edited by SMDFlea; 02-14-2022, 06:42 AM. Reason: Added model number to thread title
    • 12274
    • U.S.
    Re: Manual control buttons not working properly
    might not work but start with simple first, unplug tv from power, try to get a little isopropyl alcohol in between each button and push the buttons lots of times, always remember to give plenty of time for the alcohol to dry up but it usually dont take too long.
      • 12274
      • U.S.
      can try a reset, see if this works for you: https://www.google.com/search?q=shar...359AOB94DwDw15
        • 12274
        • U.S.
        does the remote do the same thing? you can try a universal remote if you dont have original, seems like sticky buttons tho.
        • Ritchie_Uk
          Sharp 32BC2K0 Service Manual of Fix Please?
          by Ritchie_Uk
          Hi Folks
          I am searching for a Sharp 32BC2K0 Service Manual
          Sharp 32BC2K0 << Could be an "O" as in Orange or a Zero
          Fault - Coloured "Bars" very thin all across the screen.
          I would like tho get the values for the 2 Resistors and I believe a Missing Capacitor.
          I would Like a Service Manual, that has the component values, and locations, as the PCB isnt that clear as for designations
          Is there such thing as a Boardview for this TV?
          I will Post the Photos in a second
          Stay Safe !...
          09-05-2024, 06:35 AM
        • my2k2
          Help: Sharp 2T-C42EG1X (QPWBNH1 96WJN1) service manual/ PSU Schematic Diagram
          by my2k2
          Kindly somebody share schematic diagram for Sharp 2T-C42EG1X (Board: QPWBNH1 96WJN1 )
          Most of the smd resistors were burned
          Thanks in advance...
          09-05-2025, 10:19 AM
        • bohaboha
          Use different IR SENSOR /TV CONTROL BUTTONS BOARD Possible
          by bohaboha
          Hi everyone is it possible to change or use a different IR SENSOR / CONTROL BUTTONS BOARD on a tv?
          exp: from a Philips to a Samsung or any
          if it breaks or if there is some odd brand or if universal remote control would not work
          05-05-2023, 07:24 AM
        • rviani
          Sharp LC52D62U
          by rviani
          After many years of service this unit now refuses to turn on and gives a once per second continuous blinking power indicator. Service manual indicates this is a "lamp failure".
          If I force the power on with Channel down and volume up buttons I measure correct power supply voltages at the main board. The Power supply to the inverters (connector LA) measure 10V and 47.3V which I don't have a value for from the manual but appears should be 24V. LB connector which I guess are control voltages to inverter measure 3.3V, 3.1V, 0V, and 0V at contacts 1, 2, 3, and 4 respectivly....
          01-01-2023, 11:40 AM
        • Yanleb
          LG 60PK550 Logic Control Board EBR63450301
          by Yanleb
          Hi all, I just want to share the repair of my 60PK550-UA TV set.
          The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
          But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
          All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
          C57: 3.30V
          C61:...
          07-20-2023, 12:38 AM
