Use different IR SENSOR /TV CONTROL BUTTONS BOARD Possible
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Hi everyone is it possible to change or use a different IR SENSOR / CONTROL BUTTONS BOARD on a tv?
    exp: from a Philips to a Samsung or any
    if it breaks or if there is some odd brand or if universal remote control would not work
  • cheeky2
    • Dec 2012
    • 339
    • uk
    Re: Use different IR SENSOR /TV CONTROL BUTTONS BOARD Possible
    Why would bother to do that! I have never come across an infra red sensor on a TV that has failed! I have repaired hundred's of TV's. Even when I suspected failure of the sensor and replaced it with another good working unit it wasn't the issue. I suggest you look elsewhere for the problem.
    As for changing buttons across different brands thats pointless as they are wired differently and don't use any standard connection method. Push buttons contacts do fail and go high resistance generally but these are easily checked and can manually overidden by soldering wires to the connections and shorting out the wires.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • CG2
      Meaco Arete One / Deye Dehumidifier not working
      by CG2
      I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
      Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
      08-17-2024, 07:47 AM
