Sharp LC52D62U
  • rviani
    • Dec 2022
    • 12
    Sharp LC52D62U
    After many years of service this unit now refuses to turn on and gives a once per second continuous blinking power indicator. Service manual indicates this is a "lamp failure".
    If I force the power on with Channel down and volume up buttons I measure correct power supply voltages at the main board. The Power supply to the inverters (connector LA) measure 10V and 47.3V which I don't have a value for from the manual but appears should be 24V. LB connector which I guess are control voltages to inverter measure 3.3V, 3.1V, 0V, and 0V at contacts 1, 2, 3, and 4 respectivly.
    I looked for open circuits at the inverter output transformers but all seem normal.
    At this point I am stumped as to where to look next and any help from members of this forum would be greatly appreciated.
    Thanks in advance
    Ron
  • rviani
    • Dec 2022
    • 12
    Re: Sharp LC52D62U
    Update: all CCFL test ok. Why is power to inverters @48V -bad power supply ? Help appreciated.
    • nomoresonys
      • 12206
      • U.S.
      Re: Sharp LC52D62U
      can you post a good clear straight on picture of each board and one of the whole back, as to see how everything is connected.
      • R_J
        • Jun 2012
        • 9553
        Re: Sharp LC52D62U
        I don't have the exact power supply schematic but on a similar one, the inverter is supplied by unregulated 12v and 50v
        What did you use to check the ccfls? I suspect you have a bad transformer on one of the inverter boards, check the secondary winding resistance and compare them to each other and see if one is different.
        Also check the fuses on the inverter boards
        • nomoresonys
          • 12206
          • U.S.
          Re: Sharp LC52D62U
          did you also try holding vol down and input while plugging in?
          • R_J
            • Jun 2012
            • 9553
            Re: Sharp LC52D62U
            To bypass the lamp error, press and hold CH_DOWN and VOL_UP then plug in the tv This should light the backlight for a few minutes then shut down.
            • nomoresonys
              • 12206
              • U.S.
              Re: Sharp LC52D62U
              if you haven't already, unhook the cables from powerboard to inverter board/s and retest the voltages of the connector pins on powerboard, another easy test, heat up the capacitors of the inverter board with a hairdryer for a couple minutes, heat the electrolytics first, then try it, don't wait til they cool down try it while its still hot, see if it comes on or theres any change, no joy, heat the blue ceramic caps and try it.
              • rviani
                • Dec 2022
                • 12
                Re: Sharp LC52D62U
                Thanks for all suggestions - will try all these and post results tomorrow.
                REALLY APPRECIATE THE HELP
                • rviani
                  • Dec 2022
                  • 12
                  Re: Sharp LC52D62U
                  Update: Heating the electrolytic capacitors on the inverter boards worked ! This resulted in all the CCFLs flashing rapidly - the first time I have gotten any light at all. Assume the flashing may be due to having the LCD paned disconnected at this time? Assume I should change all the electrolytics on all four boards ? Input voltage from power supply board to inverters still reading 48V whether connected to inverters or not - service manual seems to indicate this should be 24V so not sure what is going on.
                  Once again suggestions appreciated.
                  • nomoresonys
                    • 12206
                    • U.S.
                    Re: Sharp LC52D62U
                    sure, change out those caps, might be all you need to do.
                    • rviani
                      • Dec 2022
                      • 12
                      Re: Sharp LC52D62U
                      Will give it a try and post results .
                      THANKS MUCH !!!
                      • rviani
                        • Dec 2022
                        • 12
                        Re: Sharp LC52D62U
                        Changed all 16 electrolytics on all 4 inverter boards. Result is that I now get rapidly flashing CCFLs when power on.
                        Doing reset procedures with channel and volume buttons does not cause any change. LCD display panel is currently removed but I don't think this causes the problem. Assume if inverters were working I would get CCFLs on constantly. Is the next step to change the blue ceramic caps?
                        Once again all help appreciated.
                        • rviani
                          • Dec 2022
                          • 12
                          Re: Sharp LC52D62U
                          Additional info. Heating ceramics ( a bit more difficult due to location on the board) did not seem to make a difference. Also ceramics seem to be unmarked - any idea what rating they are?
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Re: Sharp LC52D62U
                            Don't waste you time trying to heat the ceramic capacitors it will have no effect.
                            • rviani
                              • Dec 2022
                              • 12
                              Re: Sharp LC52D62U
                              Correct it had no effect - but is it useful to change these? - any idea what the rating is ?
                              • rviani
                                • Dec 2022
                                • 12
                                Re: Sharp LC52D62U
                                Update: Still stumped as to what the is the problem. Does anyone have a schematic for the RDENCA184WJQZ power supply board or know where to get one? The only problem I can find is the output voltage to the inverters is 47.3 volts (even with the inverters disconnected) where the service manual calls for 24V. Am considering to buy a new power supply board. Any help appreciated.
                                • rviani
                                  • Dec 2022
                                  • 12
                                  Re: Sharp LC52D62U
                                  Sharp power supply RDERNCA184WJQZ
                                  Anyone know the correct output voltage of this board to the inverters? This board is used in many 42" to 62" Sharp Aquos (2005 - 2010 era) TVs. Also known as ZEBRALC605-4001CC.
                                  SOMEONE must have this data - help gratefully appreciated.
                                  Thanks in advance.
                                  Ron
                                  • nomoresonys
                                    • 12206
                                    • U.S.
                                    Re: Sharp LC52D62U
                                    • advant
                                      by advant
                                      02-03-2020, 12:25 AM
                                    • sefoster
                                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                      by sefoster
                                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                      11-20-2022, 09:29 AM
                                    • gavenb
                                      Sharp LC-80LE661U 80 inch
                                      by gavenb
                                      Hi folks!
                                      I have a LC-80LE661U that had some interesting issues.
                                      Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                                      I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                                      11-12-2023, 02:05 PM
                                    • SONY_E-WASTER
                                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                      by SONY_E-WASTER
                                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                      does...
                                      12-26-2021, 05:46 PM
                                    • Superbee_dad
                                      Sharp 80” long short flash backlight error - Help
                                      by Superbee_dad
                                      Hello Sharp TV experts
                                      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                      01-24-2025, 11:51 PM
