OLED65G6P-U.BUSWLJR Temperature sensor issue
  • drake441335
    • Feb 2022
    • 6
    • usa
    I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
    Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
    So i did what any person would do and I looked on Google for the temperature sensor. I ordered the $15 sensor. and installed it. The temperature sensor is a very small 1x1 inch circuit board. After install same problem.
    A previous repair while it was under warranty June 2021 was a main motherboard for a separate problem. That problem was the cable connection kept disconnecting, so the warranty replaced the main circuit board where the cable goes into the tv. But this issue with temperature happened after a few months after when the warranty expired.
    So once again I go to google and didnt really find any viable information. So I did what i felt was the right thing. I spent $125 and replaced two of the three remaining circuit boards. So now the only board that was not replaced was the video board. There are four big main circuit boards on this tv. I have replaced three of them.
    I really need help. This tv cost $3000 when I bought it and dont have that money to get a similar tv.
    Does anyone know much about this. Just to quickly recap. When I turn the tv on a pop comes up and states the temperature sensor issue, and then the tv powers down.
    The lg part numbers I have installed so far are:
    eay64339201 lg power supply master
    eay64349202 lg power supply slave
    ebr82440301 lg sub pcb assy, (temp sensor) Could this be incorrect sensor?
    The board replaced under warranty, i do not have the part number.
    I appreciate the time spent helping me out.
    One thing I forgot to mention. Last time I messed with it, I decided to put the tv in reset mode to reset to factory settings. and now I am stuck in the opening sequence of time, language etc etc. Tv doesnt stay on long enough to get past this part.
    • 12306
    • U.S.
    Re: OLED65G6P-U.BUSWLJR Temperature sensor issue
    Maybe turn off all the Ambient light temperature picture optimization and crap like that, see if it makes any difference.
    • drake441335
      • Feb 2022
      • 6
      • usa
      I cant get to the settings on the tv, I edited my post. I am in factory reset screen. And tv wont stay on long enough for me to get past the opening, language, time zone, etc etc.
      • Diah
        • Feb 2013
        • 6496
        i just wounder what temperature sensor you replaced... its TV not cooker LOL
        so stop doing any things... upload focused clear photos on the whole back and the all boards you replaced ..
        this error and go to shutdown to protect the panel module its 90% happen because one of the cable / sockets get on power boards warming up and the resistances of them changed so the MICOM on main boards watching this and turn the tv off.
        so start with photos.
          • 12306
          • U.S.
          seems reasonable diah, try that, here's a little article i ran across: https://www.digitaltrends.com/home-t...-issue-repair/
          • Diah
            • Feb 2013
            • 6496
            we have this error of warrning same on this threat https://www.badcaps.net/forum/showthread.php?t=103155
              • 12306
              • U.S.
              Yep, seems like they need to use bigger guage wires on those connectors, seems like the engineers would know that. Probably more planned obsolescence like way over-driving the leds on the led tvs etc.
                • 12306
                • U.S.
                Just had a few connector wires go fried on my old sammy ccfl tv from 2007, had to get a new little harness, not too mad tho, it's been working hard for 15 years now, only repair was replaced mainboard in 2015.
                • Diah
                  • Feb 2013
                  • 6496
                  this happen almost on 65 size OLED and above. because they used same socket and cable at 55 size and below... cheap manufacturing sourcing.. 65 OLED pull current from the 24V PCB rail, 1/3 more than 55 OLED.
                    • 12306
                    • U.S.
                    Holy cow, that makes them a dangerous fire hazard, if I bought one I would be trying for a refund or at least trying to get them to fix it for no charge, that's disgraceful.
                    • drake441335
                      • Feb 2022
                      • 6
                      • usa
                      Sorry, I started a new job and getting back to this tv was not a priority. here are the pictures. the pictures show all pieces i have replaced. the wires in the final pictured were not replaced, i just took the picture for part numbers for myself.
                      thanks for your help
                      • Diah
                        • Feb 2013
                        • 6496
                        Originally posted by drake441335
                        i just took the picture for part numbers for myself. thanks for your help
                        if yours cable and socket fine at power boards and there are no burn then you have the problem with this FAN, the RM ( spinning )of it became low so its resistance become high.
                        open it clean and oil the shift of it. if it still make noise and didnt spin in high speed as i think its 12V you can use PC FAN too and see the tv will remain on
                        • drake441335
                          • Feb 2022
                          • 6
                          • usa
                          I will look into it this weekend. thanks for feedback.
                          • drake441335
                            • Feb 2022
                            • 6
                            • usa
                            Well, I decided that trying to make this repair myself was starting to get above my head. I took the tv into a repair facility. they told me that the main board is not communication with the temp sensor. The board with the metal on top of it is the one that is not communicating. The board is on order and will be installed next week or so.
                            I truly thank you all for your help.
                            • Diah
                              • Feb 2013
                              • 6496
                              short and clear words.. they told you a lie. its FAN issue
                              the top boards you mentioned are the T-CON driver boards had nothings to do.
                              the FAN will sitting on it to pull air. that's all... am sure this shop owner a member in this forum... so if you read take it easy.. earning money are your right but not by lie.
                              • r3vsEngIT
                                • Jul 2023
                                • 7
                                same tv, similar issue. tv will come on and screen will display normally but then after about 45 seconds it will shut off and go back to standby red led. my initial thought was temp sensor or fan fault (how i found this thread and forum) but if i uplug the fan or temp sensor the tv will shut off just the same.
                                i am also only getting 3.5v on the 12VT_ON pin at all times. is that normal?
                                OP did the main board replacement fix your issue?
                                • CapLeaker
                                  AcuRite 5 in 1 temperature sensor replacement repair
                                  by CapLeaker
                                  Got a new victim:
                                  AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                  A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                  B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                  Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                  04-15-2025, 01:32 PM
                                • mitchw
                                  MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
                                  by mitchw
                                  Hello
                                  I got this MacBook Pro M4 Pro to have a look at.
                                  It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
                                  Since it was liquid damaged, warranty does not apply anymore.
                                  Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
                                  The main issue was that the screen remained black.
                                  Anyways I cleaned the liquid damaged area, put the machine back...
                                  09-06-2025, 07:19 AM
                                • ErParucca
                                  Thinkpad X390 (motherboard NM-B891 shared with other models) : battery sensor reporting wrong temperature -> sudden power off
                                  by ErParucca
                                  I have a thinkpad X390 that would work fine if not for a problem: sensor temp5 (battery as far as I know) shows variable values over 100° C. When it reaches higher temps (I guess 110° as I was able to list temperatures up to 109°) it simply powers off. All other sensors show 0° except for the CPU which seems to report correct temperatures.
                                  In a wishful thinking I hoped replacing the battery (as far as I know the temperature sensor is in the battery) would fix the problem, but it didn't.
                                  Given this situation I can't even upgrade the firmware as the machine powers off...
                                  07-10-2025, 10:46 AM
                                • bart64
                                  ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
                                  by bart64
                                  After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
                                  10-18-2025, 05:51 AM
                                • Stephen
                                  A2141 MacBook Pro 16" lid sensor issue.
                                  by Stephen
                                  Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
                                  11-01-2024, 03:45 PM
