Trying to fix LCD samsung LE32A330J1 tv, half screen with red tint
  • RedKazl
    • Feb 2022
    • 11
    • Lithuania
    I came here for help with a passion project I've been trying to do. I want to repair a not so new samsung LCD TV.
    My journey began with this tv showing distorted colours, they just weren't right, so I did a lot of googling and voltage measuring, to find out that it was probably the doing of a faulty capacitor and the AS15-G chip on my tcon board.
    After replacing the two parts with new ones I turn on the tv and half of it is working perfectly and the other half has a red tint and red lines, so continued googling brought me to try and clean the connectors from the tcon to the other parts of the tv, but it didnt help. Then I tried switching the cables places to see if it's the wires, nothing changed and I am out of ideas what to do for the time being.
    I hope someone here can help me, some photos are attached if more are needed feel free to ask
  • Diah
    • Feb 2013
    • 6374
    Re: Trying to fix LCD samsung tv, half screen with red tint
    which cap on T-CON ?? normally only AS15-G chip replacment enough.
    you got now new issue so the caps could not fault or the chip need to rework.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Can we get a close up of chip you replaced?
      • RedKazl
        • Feb 2022
        • 11
        • Lithuania
        Oh no a faulty capacitor was on a different part of the tv. I only replaced the chip on the tcon. Sorry that i did not make that clear.
        • RedKazl
          • Feb 2022
          • 11
          • Lithuania
          This is the replacement chip, best photos I could manage with something this small
          • dskall
            • Oct 2016
            • 2905
            • usa
            Don't think it's a chip problem. I would examine all areas around where you worked for any missing damaged misaligned parts. And concentrate on the side that has the problem. Inspect all ribbon cable connections for damage on connector.
              • 12192
              • U.S.
              Wonder if they sent you a defective AS15 or it got damaged somehow. But I do like that color, I'll take a Porsche 911 in that color, no new crap, whaletail only.
              • RedKazl
                • Feb 2022
                • 11
                • Lithuania
                Yes a fine idea I thought of myself but could you please tell me how to do it? Or a link to some kind of video? From my understanding I should take the voltage of each cable of the ribbon cable while the tv is turned on? Or am I wrong? And what exacly would tell me that something is missaligned or damaged? No voltage?
                • Diah
                  • Feb 2013
                  • 6374
                  what the hell over here... what had ribbon to do... before you replace the chip did you have this issue ??? if no then your chip one channel fault causees , all what you buy on aliexpress 80% are fault. COPY
                  ( why people enjoy harmimg other by repairing... strange ) listen to nomoresonys he is right as my post #2
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    I am saying to unhook cables and look at contacts and make sure none of the contacts are bent or damaged on your connector going to the side with the defect.
                    • RedKazl
                      • Feb 2022
                      • 11
                      • Lithuania
                      Before replacement the issue was that the whole screen was solarized, after replacement only half the screen stayed solarized. I bought the chip on ebay from germany to specificly avoid this problem.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        To be clear here. I have never seen a gamma chip cause half a screen to be polarized. But I learn something every day. I would say that it is most likely a problem that came from working on it. So I was suggesting you inspect everything closely. If you don't find anything else then through process of elimination would be a bad or poorly soldered chip. Also what was the capacitor that was changed?
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          AS15s appear to have possibly been a fad. All of them I remember seeing AS15s on, were late-'00s TVs.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • RedKazl
                            • Feb 2022
                            • 11
                            • Lithuania
                            Ok so I looked at the ribbon cabbles more closely and did see something, two of the cables where damaged here are pictures. However I have suspision that I did this while trying to figure out what was wrong because it would be weird to me that because of these two connections half the screen is solarized. The cabble with damage on the right side is on the right side of the tv. I changed the capacitor on this board which one I cannot check right now and will only be able to do it on sunday evening/monday morning. I am starting to think about replacing the chip again...
                              • 12192
                              • U.S.
                              Well i have no confidence in those ribbon cables any more, replace both of them.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                If cap you changed is on power board, that would have no effect on this problem. On the cables you can trim the ends a small amount.
                                • RedKazl
                                  • Feb 2022
                                  • 11
                                  • Lithuania
                                  Can I actually just cut the of the damaged end and it will be ok?
                                  And a side note, how to search for a ribon cabble? Like should I just write the numbers and letters on my ribbon cables or do other parametres need to be specified?
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    https://www.youtube.com/watch?v=ULwU...Repairs%26Mods
                                    • petehall347
                                      • Jan 2015
                                      • 4426
                                      • United Kingdom
                                      just cut off to good connections with sharp scissors
                                      • RedKazl
                                        • Feb 2022
                                        • 11
                                        • Lithuania
                                        Cut off the ends, nothing changed. Any other suggestions apart from replacing the chip again?
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Tom C
                                          Samsung QN55Q70AAFXZA Half Screen Dim
                                          by Tom C
                                          I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                                          Any suggestions would be appreciated.
                                          thanks.
                                          09-19-2024, 07:22 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Ifixstuff9
                                          LG 49UF6400 tint on half of screen + no OSD?
                                          by Ifixstuff9
                                          I have a LG 49UF6400 with two issues. The first is a colored tint on the left side of the screen. The color of the tint depends, but I've seen red, green, and purple so far. I can see a normal image behind the tint as shown in the photos. The tinted side flashes rapidly between "normal" and "tinted"
                                          I suspected either the panel or the TCON, so I tested the TV with one of the panel cables disconnected. With the left side unplugged, the left half of the screen is white and the right is black. With the right unplugged, the left has vertical bars and...
                                          05-30-2020, 04:09 PM
