Samsung UE65JS8500 UE65JS8500LX 5 blinks
  • alltvrepairs
    • Jan 2014
    • 245
    • Malta
    Have this curved TV for repair. I have noticed 5 blinks then goes to standby and cycle repeats. Seems responds to remote commands but backlights not lit
    What I have done so far:
    • Disconnected power supply from Main Board and TCON. (this model has a connector lead to TCON as well) -> Backlight lit on but have noticed that LEDS are purplish.
    • Tried ALL 16 sets of LEDs (8 LED sets per connector) with my LED tester and all Lit up although again purplish not that intense.
    • Disconnected Panel LVDS Connectors but same error code.
    Am not sure if this model detects the low emittance of the LEDs and goes to error state.
    Any hints on this model?
  • CapLeaker
    Leaking Member
    • 8327
    Re: Samsung UE65JS8500 UE65JS8500LX 5 blinks
    Check all the voltages on the connector from the PSU to main board and see if there is something missing. While purple LEDS aren’t the best, at least they did turn on with the main board disconnected and stayed on. Right now I think you are barking at the wrong tree. post the PIN number, name and the voltage measured with tv On and Off.
    • neilc6
      • Nov 2015
      • 1550
      Did you see if the TV powers up with only one side connected at a time between the tcon and panel?
      • alltvrepairs
        • Jan 2014
        • 245
        • Malta
        Yes any or both no difference.
        • Sucher
          • Mar 2014
          • 9
          • United Kingdom
          Main board is faulty. Please upoload the picture of the board, I need to see where eeprom and eMMC IC/ NAND are located, also check voltages on line voltage regulators directly after switch on- one of them could be dropping. Chcek if 12V to screen is present
          • alltvrepairs
            • Jan 2014
            • 245
            • Malta
            UPDATE: FULL MODEL UE65JS8500TXZT VERSION: 01
            These are the voltages from ps at standby and On
            CNM803
            ------------STBY ON
            2 GND -0 0
            4 GND -0 0
            6 GND -0 0
            8 GND -0 0
            10 OD LEVEL- 0 3.3
            12 ANA DIM- 0 3.3
            14 OD ON/OFF- 0 3.3
            16 BLU_ON/OFF- 0 0
            18 POWER ON/OFF- 0 3.3
            20 GND- 0 0
            22 GND- 0 0
            1 VAMP- 9 12.8
            3 VAMP- 9 12.8
            5 VAMP- 9 12.8
            7 A13V- 9 12.8
            9 GND- 0 0
            11 FAIL_COUNT- 2.5 2.5
            13 A13V- 9 12.8
            15 A13V- 9 12.8
            17 A13V- 9 12.8
            19 A13V- 9 12.8
            21 GND- 0 0
            The BLU_ON/OFF signal (pin 16) is ,kept TTL_Low from main board. I have disconnected this pin 16 from main board side. There is 3.3v coming from power supply now on this pin. But backlights still not switched on. If I remove CN9003 (power supply to TCON) backlights on but still same fault.
            CN9003 has the PWM signals from TCON to Backlight circuit in power supply.
            TCON supply 12v is actually being supplied from main board. 2 blue LEDs on TCON are lit when ON
            Now its a chicken and egg problem Is it the TCON not sending signals to supply or main board faulty or detecting another fault??
            Probably I can only get help from any Samsung expert that have had experience on the JS series.
            • alltvrepairs
              • Jan 2014
              • 245
              • Malta
              uploaded, see my comments. Tks
                • 12276
                • U.S.
                Purple leds and the fail count, seems to be bad led backlights.
                • alltvrepairs
                  • Jan 2014
                  • 245
                  • Malta
                  Have found service manual for the JS9500 series but is very different from the JS8500 series.
                  Anyone has this SM available please?
                  • Storyteller12
                    • Jun 2020
                    • 625
                    The backlights are fine I think? In the US model of this TV UN65JS8500 it’s a quantum dot TV. These tv use blue leds and not white. The layers i between the screen have nano dot technology and turn the blue backlight to a pure white.
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Most likely the main board as mentioned. It could be the eeprom is corrupt but it sure.
                        • 12276
                        • U.S.
                        Oh I see, did not know that, thanks for explanation.
                        • alltvrepairs
                          • Jan 2014
                          • 245
                          • Malta
                          Originally posted by Storyteller12
                          The backlights are fine I think? In the US model of this TV UN65JS8500 it's a quantum dot TV. These tv use blue leds and not white. The layers i between the screen have nano dot technology and turn the blue backlight to a pure white.
                          Tks I wasn't aware of this! It was a big help indeed!
                          SO far found closer SM for:
                          UE65JU7500T chassis UWJ50
                          UE65JS9500F chassis UWH50
                          UE65JS8500 chassis ???
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            We haven't even been able to confirm blink codes for LG and Samsung TVs.
                            We know that Panasonic, Sony, Sharp and Pioneer (most likely) OTOH, routinely give blink codes for a malfunction.
                            But, it looks like you got one, where 5-blinks, is possibly the equivalent to Sony's 6-blinks. (The recent Sony TV that my father and mom had, suddenly gave 6-blinks at 1 Hz, (IIRC) stops and repeats)
                            Went to YouTube after that, IIRC, then IIRC, YouTube videos indicate either a bad mainboard or bad LEDs in the case of that Sony TV, which we don't have anymore.
                            Simply wasn't durable like the Sony TV that my brother-in-law has! I believe the Sony TV that my brother-in-law has, is still trucking along!
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • alltvrepairs
                              • Jan 2014
                              • 245
                              • Malta
                              Screen CY-XJ065FLLV4H
                              I don't think it is a Quantum Dot display but a SUHD
                              Service Manual for the JU7500 series says:
                              • . How to distinguish if the problem is caused by Main Board or T CON.
                              • - No Video
                              • If the problem is No Video but BLU is on and Indication LED is blinking repeatedly and faster than nomal booting, replace the T-CON board.
                              • - Distorted Picture
                              Check the inner patterns.
                              If I apply this logic to my case, my BLU signal is 0v so more inclined to a main board.
                              • Storyteller12
                                • Jun 2020
                                • 625
                                • - No Video
                                If I'm not mistaken the SUHD is quantum dot. It just wasn't marketed as that until 2018 or 2019 when they rebranded as QLED to compete with LG OLED. If you removed the screen you can see the layers in between. 1 will be a yellowish color instead of white.
                                That's the quantum dot layer.
                                • alltvrepairs
                                  • Jan 2014
                                  • 245
                                  • Malta
                                  Yes you are right. SUHD = QLED first generation. DIdn't know it myself but made some research after your comment.
                                  Now am trying to find a good price for Main Board and possibly TCON
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    I have this same tv with the back cover off already. Everything is working. If i can help let me know
                                    • Storyteller12
                                      • Jun 2020
                                      • 625
                                      I think it’s most likely the eeprom. Can you probe the eeprom pins and let us know what you get. Almost all samsung main boards I have fail are from eeprom with the exception of a few.
                                      Do you have an eeprom programmer?
                                      Since I have the same boards I can read my eeproms and upload. Keep in mind it’s the US version
                                      • alltvrepairs
                                        • Jan 2014
                                        • 245
                                        • Malta
                                        Hi, So I will take the offer these are 3 tests that can help me and possibly others with problems in this chassis.
                                        1) If you disconnect the TCON from the main board what happens? Backlight is ON (Y/N)? Does it give any error (Y/N)? Sound OK on HDMI (Y/N)
                                        2) If you just take out both panel to tcon ribbons , Backlight is ON (Y/N)? Does it give any error? (Y/N) (Y/N)
                                        3) If everything in place except the LED connectors. Backlight is ON (Y/N)? Does it give any error (N) ? Sound OK on HDMI (Y/N)
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
