TV LG 65UM7470PSA Display Doesn't Turn On
  • ekronz
    • Feb 2022
    • 5
    Hello, people.
    My TV has gone bad about a month ago. At first it wasn't turning on from the standby state, so I replaced the mainboard. (The mainboard has a humming to it, but I believe it is normal Coil Whinning)
    Now... With the new mainboard it does turn on, however, my display isn't working properly, It doesn't turn on when I turn the TV on.
    I measured the Power-On voltage on the P201 connector, it has ok voltage when in standby (0V, according to specification), however when I turn the TV on it should have 3V+. The other pins that has voltage on the P201 should be 7.8V on standby and 13.2V when the tv is on. However, they all keep the same voltage at 7.8V, regardless of the TV state.
    Also measured the voltages across the mainboard. When it is on the Power-On voltage goes to 3.3V (which is right), however the other voltages stay at 7.8V (as if it was at standby mode)
    After checking the above, I went and measured the LED Power connector. The LED+ is measuring something around 300 and the LED- something around 130V. Also, something strange happens! When I connect the probe to the LED- the backlight turns on, is it normal?
    Finally I checked the voltage in the "green" component (check picture, I believe it is a voltage regulator) and it measured 30~40V.
    Now I'm thinking... Do I need a new powerboard? Did my LED Strips gone bad? I don't know what else to test.
    Please Help!
    Thank you all, in advance.
  • CapLeaker
    Leaking Member
    • 8218
    Re: TV LG 65UM7470PSA Display Doesn't Turn On
    Measure all pins with your DMM and post the pin name with the voltages measured with the TV on and off.
    • Diah
      • Feb 2013
      • 6398
      Originally posted by ekronz
      Hello, people.
      this TV it may smarter rather than user,, you are going to toast PCB and MB.
      changing MB not easy task if it is not 100& same series
      • R_J
        • 9557
        Measure the voltage across C611 (main filter) Post this voltage in standby and when power-on
        • ekronz
          • Feb 2022
          • 5
          On P201?
          • ekronz
            • Feb 2022
            • 5
            I checked serial numbers, model, rev etc. It's the same board 100%
            Also, the noise only appears when the TV is on
            • ekronz
              • Feb 2022
              • 5
              around 390V when Standby, around 380V when On
              • PNI E.
                Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                by PNI E.
                Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                03-17-2025, 04:23 AM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • Michael Long
                No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                by Michael Long
                I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                Dead / No Power / No Standby Light results after power company had three
                consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                09-13-2022, 06:55 AM
              • gabri2211
                Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                by gabri2211
                Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                This NEXUS connector broke.
                Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                07-28-2025, 07:13 PM
              • Sebastijan V.
                Samsung UE40K1502AKXXH - flashing LED, no life but still responsive
                by Sebastijan V.
                So, I got this UE40K1502AK(XXH) TV from a friend.
                TV has no picture or sound, but it reacts on remote control and power button on bottom side.
                - When plugged into mains, the LED is red on. If I use remote to power it on for the first time, it flashes 6x then LED remains off. I assume this would be the same as by normal tv?
                - LED also flashes fast when I push any button on remote controller. If I turn it off with remote, the LED will lit solid red. And by next turn-on with remote, it flashes 5x. Also will flash fast when any remote button is pressed.
                - The background...
                03-20-2025, 04:22 AM
