LG 70UH6350 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 624
    Re: LG 70UH6350 Mainboard issue
    Originally posted by dskall
    So what voltages have you found?
    1. 24v - 27v
    2. 24v - 27
    3. 24v - 27v
    4. 24v - 27
    5. G - 0
    6. G. - 0
    7. 12v - 11.77.
    8. 12v - 11.77
    9. G. - 0.
    10. G. - 0
    11. G - 0.
    12. G. - 0
    13. Pwr on - 2.8.
    14. P-dim 2 - 0v
    15. G. - 0.
    16. 12v - 11.77
    17. 12v - 11.77.
    18. 12v - 11.77
    19. 24v - 27.
    20. 24v - 27
    21. G. - 0.
    22. G. - 0
    23. DRV On - 0.
    24. P-dim 1 - 2.96
    25. G. - 0.
    26 sclk - 0
    27. Vsync - 0.
    28. Sin - 0
    • dskall
      • Oct 2016
      • 2905
      • usa
      You did ask for help on your mainboard. I gave you some voltages. But while we are on power board does your voltage change on Pwr on and DRV On when you press your power button?
      • Storyteller12
        • Jun 2020
        • 624
        Sorry I'm new to troubleshooting mainboards. Not sure where to check For those voltages you mentioned a few post back.
        As for the pwr on and dvr on I'll have to check tomorrow what they are in Standby. The ones I provided are after hitting the power button to turn on.
        • dskall
          • Oct 2016
          • 2905
          • usa
          I think drv_on is your backlights. Probably should have a voltage if not in standby.
          • Storyteller12
            • Jun 2020
            • 624
            That would make sense because the backlights don’t come on.
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              If you activate backlights I wonder if you would get a picture.
              • Storyteller12
                • Jun 2020
                • 624
                Possibly, would it damage anything else doing that. There’s several smd caps that are shorted to ground. I just don’t want to cause more problems. But I can try….
                • nomoresonys
                  • 12086
                  • U.S.
                  #28
                  Try unplugging everything from the mainboard you are testing if you haven't already and see if you still have the shorts, lots of things can cause it, recently had a wire on the power to mainboard cable fried and it made many caps test short on mainboard when all boards were hooked up, need to track down the short if you have one, what procedure are you using when testing?
                  • Storyteller12
                    • Jun 2020
                    • 624
                    I removed the main board from the tv. So nothing else hooked up. Then I started testing all the smd caps and found them shorted to ground along with an 8 pin ic which I removed and it tested fine out of circuit.
                    Haven't started removing any bad caps yet to see if one of them failed and caused the short.
                    • nomoresonys
                      • 12086
                      • U.S.
                      #30
                      And you still have the shorted caps with that IC removed?
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Yes, caps still shorted
                        • Diah
                          • Feb 2013
                          • 6353
                          my post#11
                          this is wrong way you walking on.. take out the powerboards on the table alone and just jumper STBY and Pwr on .. messures yours 24V it should 24 or little less not 27 as you wrote . any time you plug the MB with this PCB will toasted more.
                          • nomoresonys
                            • 12086
                            • U.S.
                            #33
                            He has shorted caps on the mainboard with it unplugged from everything else.
                            • Storyteller12
                              • Jun 2020
                              • 624
                              Originally posted by Diah
                              my post#11
                              I have 24v on the power supply when it’s powered on. But when I plug in the mainboard it jumps to 27v.
                              So it’s the main board that is the problem. Not the power supply. We have confirmed this.
                              Now I need to find out what is shorted on the main board causing all the smd caps to be shorted.
                              • Diah
                                • Feb 2013
                                • 6353
                                Originally posted by Storyteller12
                                I have 24v on the power supply when it's powered on. But when I plug in the mainboard it jumps to 27v. .
                                then good, 24V rail on MB used only for Audio amp / Tuner / and DC to DC 5V.
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Ok, we are making some progress. So what should I be testing or looking for now? Bad IC or do you think one of those smd caps is shorted causing everything else to be short
                                  • Diah
                                    • Feb 2013
                                    • 6353
                                    i dont think so.most caps will be mounted withhin chassis iif one short MB will cutoff pwr on.
                                    each circuit i mentioned before working with 24V line. all took the feed via L . disconnect on side of this L or complete out and check 24 back to normal or not.
                                    • Storyteller12
                                      • Jun 2020
                                      • 624
                                      Sorry, I’m not sure what you mean by Feed via L?
                                      • Diah
                                        • Feb 2013
                                        • 6353
                                        L = Coil you check which L had 27V mean its the line inter to the circuit we talked on. sure all the mentioned circuit will read 27 this why need to disconnect one by one and check if 24 back to normal
                                        • Storyteller12
                                          • Jun 2020
                                          • 624
                                          Ok I understand now. Thanks for the clarification I will check when I get back to the office and let you know what I find.
                                          Thanks again
                                          • max789
                                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                            by max789
                                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                            I made the following tests:
                                            1. Disconnected the main board from Power Board = backlight works.
                                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                                            So I ordered a main board from Ebay also BN41-02156A but from...
                                            01-18-2024, 06:56 AM
                                          • alltvrepairs
                                            Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                                            by alltvrepairs
                                            I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                                            This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                                            Any help appreciated!...
                                            03-14-2024, 03:39 AM
                                          • dbuergi
                                            PS5 Dualsense controller stick drift a mainboard issue?
                                            by dbuergi
                                            I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
                                            I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
                                            05-02-2025, 05:00 PM
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                            šŸ›  Original Issue
                                            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                            āš ļø New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                            by ugamazing
                                            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                            12-17-2024, 07:05 PM
