I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
Tried wiggling the LVDS while on and no change to the white screen. Have removed the two cables going to the panel from Tcon one at a time, still white screen.
I've done quite a bit of reading and I suspect the Tcon but I'm not 100% sure. Here's the information I have.
Tcon:
F01 fuse 12v
avdd 15.6v
vcom 6.4v
vgs -6
vref 15.3
vgh 30v
Found 3.3v and 1.8v on RT9183.
VGM 17 to 1 are all there in descending order
Tcon:
F01 fuse 12v
avdd 15.6v
vcom 6.4v
vgs -6
vref 15.3
vgh 30v
