Sharp E50E41NKFMBXNNX white screen
  • odi
    • Jan 2022
    • 6
    I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
    I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
    Tried wiggling the LVDS while on and no change to the white screen. Have removed the two cables going to the panel from Tcon one at a time, still white screen.
    I've done quite a bit of reading and I suspect the Tcon but I'm not 100% sure. Here's the information I have.
    Tcon:
    F01 fuse 12v
    avdd 15.6v
    vcom 6.4v
    vgs -6
    vref 15.3
    vgh 30v
    Found 3.3v and 1.8v on RT9183.
    VGM 17 to 1 are all there in descending order
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp E50E41NKFMBXNNX white screen
    You seem to have voltages. I would check if I had signal coming into the t-con on the pads with the dual lines at center of connector. Should be about 1.2v.
    • odi
      • Jan 2022
      • 6
      Thanks for that idea, (pasted the results below) those voltages appear too low or inconsistent right? Based on those readings I went back to the logic board and got the same readings from the test points by the lvds connector. I desoldered the metal shield over the processor to get a better look at it. (2nd time I've gotten to use my hot air station!). I have the service manual so took a look at the pinout on the MSD8220LB-S9. Grasping at straws but figured I should at least check that it's getting power. I found 4 "vddc" lines on the schematic and verified that they all have voltage which is 1.16v (not sure if that is the voltage it should have though). It does have a good ground as well.
      At this point perhaps the processor has failed? It's weird that it's decoding hdmi audio though.
      1st block pins left to right then top to bottom
      1.45v
      1.5v
      0
      10mv
      .2v
      .2v
      2nd block
      .78v
      10mv
      1.9v
      1.56v
      0
      .39v
      3rd block
      2.1v
      11mv
      2v
      .3v
      0v
      .3v
      4th block
      1.4v
      10mv
      2.1v
      1.45v
      0v
      .23v
      5th block
      .79v
      10mv
      1.94v
      1.54v
      0v
      .4v
      6th block
      2.1v
      10mv
      2v
      .3v
      0
      .3v
      • dskall
        • Oct 2016
        • 2905
        • usa
        These are probably ok if you are reading across top ans then across bottom. My first guess would be t-con. I have a tv with basically same problem. I found data went into chip on t-con but wasn't coming out. I verified with my mainboard tester which showed a picture.
          • 12276
          • U.S.
          That mainboard tester sounds like a sweet tool, can you tell us more about it? thanks.
          • dskall
            • Oct 2016
            • 2905
            • usa
            This is older version. https://www.aliexpress.com/item/1005...7e7e4c4dfTVkk7
            Won't test 2K etc. but is about 1/4 price of new version.
              • 12276
              • U.S.
              That is a cool tool, thanks Dskall.
              • odi
                • Jan 2022
                • 6
                Very cool tool. I managed to find the tcon and mainboard for cheap on ebay so I bought them both, I'll update and let you know what the issue turned out to be once I get them. Thank you for the help!
                • odi
                  • Jan 2022
                  • 6
                  Just an update - The tcon was the issue, replacing it fixed the tv. thanks for all your help
                  • EazyBone
                    Sharp LC-65Q620U White Screen
                    by EazyBone
                    Another TV topic!!
                    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                    08-21-2024, 12:56 PM
                  • harp
                    White screen repairs
                    by harp
                    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                    05-13-2024, 03:43 AM
                  • Megan0
                    Sharp LC-70UD1U Half screen Normal half screen is white
                    by Megan0
                    My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
                    Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
                    Result:
                    I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
                    Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
                    Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
                    Only in the first test, where I did not
                    01-19-2022, 11:20 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • thesharpfella
                    Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                    by thesharpfella
                    Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                    07-23-2024, 10:37 AM
