Philips LCD 42PFL5432D/37 - Bad PSU
  • PlainBill
    replied
    Re: Philips LCD 42PFL5432D/37 - Bad PSU
    Originally posted by nuklear
    could you post a link or send it to me? I looked and only found one for around 240.
    I'm having problems finding it again. I found it by Googling either the part number or the TVs it's used in - it's also used in the 42MF437B. Alternate part numbers are 996500044559, ADPF24300R1P and 715T2432.
    PlainBill
  • nuklear
    replied
  • PlainBill
    replied
    I stand corrected. That certainly looks like the ferrite core is broken. The power supply is available for $75 online.
    PlainBill
  • nuklear
    replied
    Sorry I think what I called a magnet is the ferrite,lol. I dont know much about electronics. I dont think my friend means anyharm or trying to rip me off (didnt charge me anything) but I dont think he understands this much into it. Well here are the pics.
  • PlainBill
    replied
    no offense taken, he doesnt do this for a living but he told me he new the basics about fixing electronics. He had me call the company for a new transformer and they said it cant be bought. He showed me how brittle the "magnet" is around the transformer by pushing the edge and it broke again. can I get a new magnet? I took pics of the board w/o the transformer I will post them when I edit the size of them. And again thanks for the info and help!
    With all due respect, I find this unlikely. A transformer usually consists of three parts - a core - in this case, ferrite; a plastic bobbin, and the windings. There is no 'magnet'. Ferrite is brittle, but usually the core of a transformer is quite hard - think of a clay pot. Pictures would go a long way toward convincing me that the part he broke off was of the core. To me, it seems far more likely it was the bobbin.
    PlainBill
  • nuklear
    replied
    replied
    thanks for the reply. He said the magnet around the transformer was broke and thats what was wrong with it.
    I highly doubt that's the problem. This guy sounds like he doesn't know what he is doing (if he did, and if the transformer really was "broken", then he should be able to replace it and not tell you to get a $300 power supply). No offence, but the guy is probably just a typical board swapper.
    Like I said, post some pictures of your board here and we can tell you what to measure with your multimeter and you how to troubleshoot it.
  • nuklear
    replied
    thanks for the reply. He said the magnet around the transformer was broke and thats what was wrong with it. he should me it was by taking the tape off and a piece fell off it. I am assuming this was the problem, i didnt buy a new power supply yet I just wish there was a way to fix the transformer instead of spending $300 on a new psu I can get a multimeter but I didnt know what points to test and what not.
    replied
    Except in the backlight inverters, transformers very, very rarely go bad. With that said, there's a very big chance this power supply is repairable, and most of the time it's usually something simple too.
    The chirping could be caused by a couple of reasons:
    1) PSU tries to start but fails due to dry start-up capacitor (somewhat common failure and very easy to fix)
    2) PSU tries to start but fails due to bad output capacitors (slightly more rare... however, this issue should have been eliminated if you replaced that cap on the bottom next to the connector with a proper low ESR one)
    3) shorted output (not very common, but still easy to fix)
    Well I had it check I was told it was the Transformer and I need a new psu.
    If you had it checked at a TV repair shop, don't blindly believe in what they say. Most of them just swap the bad board with a new one and don't really analyze what have caused the failure in the first place. Moreover, the replacement board may have the same failure-prone capacitors, so you may end up with the same problems again down the road. Fixing your own power supply with proper, high-quality components is a much better way to go about this, and it's usually cheaper too.
    Before I buy a new psu, what are the chances it wrecked another board in this tv?
    Very small, but they do exist.
    Nonetheless, I still think you should fix the old power supply (again, see above reasons). Start by posting pictures of your power supply. Get a multimeter too.
    Originally posted by dougsoxman
    I just recently bought one of these tv's with what i believe to be the same problem. The larger caps look slightly bloated on the top. I also have the chirping noise and wasn't sure if that was related to the caps, or if the transformer is bad like someone else suggested.
    Bloated capacitors are always a bad thing. Get them replaced first, then if needed, troubleshoot the power supply if it's still chirping.
    My recommendation is the same as above - start by posting large, clear pictures of your power supply as well as the brand and series that is printed on each capacitor (if you're not sure how to obtain this information, just post all of the info you see on each capacitor). This will help in determining proper capacitor replacements.
  • dougsoxman
    replied
    I just recently bought one of these tv's with what i believe to be the same problem. The larger caps look slightly bloated on the top. I also have the chirping noise and wasn't sure if that was related to the caps, or if the transformer is bad like someone else suggested. Did the original poster ever get his to work? Was it just the capacitors that you replaced? Thanks
  • nuklear
    replied
    Well I had it check I was told it was the Transformer and I need a new psu. Before I buy a new psu, what are the chances it wrecked another board in this tv?
    replied
    Do you have a multimeter?
    If so, use it to check if there is a stand-by voltage present. Using the picture from the first post in this thread, the stand-by voltage will most likely be present somehwere on that connector where the arrow for "D" is. Most of the time, the stand-by voltage is usually 5v or so.
    If there is no stand-by voltage, replace the small green capacitor to the left of the transformer (if you haven't already done so). Also, what brand and series of capacitors did you use for your replacements?
    A picture of your power supply would also be helpful.
  • nuklear
    replied
    It seems to be coming from the transformer next to D. Is there any way to replace that? Would that cause a chirping noise when plugged in? What do the numbers at the top of the transformer mean? 80tl37t912 ls
    pph6012al
    lse-b9 0747f2
  • nuklear
    replied
    I had the same issue on my Philips I replaced the bad caps but I still have the chirping noise and no standby light at all. I zeroed the noise down to an area but dont know how to go about repairing/testing it. It seems like it is coming from the yello block left of D (picture from first post) or the small reddish/brown thing just above D. Any help/insite on this would help.
  • Dgtech
    replied
    I'd try that same player on another TV. I think it might be the player that has the problem.
  • maxthecat
    replied
    I found this page help full in repairing my Philips LCD 42PFL5432D/37, the same thing had happened after 2 year and 8 months It did the same thing, so I Google the tv shutting of a few second after turning it on, came across this page, ordered 5 dollars in capacitors, the tv had been working for a day now, awesome, it does have another problem sometimes we watch bluerays on our ps3 which is hooked up with a hdmi cable sometimes you have to restart the player several for the sound to work, have you had any problems with this
  • Lobo
    replied
    Thanks for the helpful suggestions guys. You're right that I still have a lot to learn so I will try to keep it simple for now. Today I received my replacement PSU and tried it out. Sure enough it was the problem. Thankfully I can RMA the PSU and save myself 85 dollars but first I will be taking a shot at fixing the old one myself. Thanks again for all your help.
    It's crazy when I think of all the electronics I've tossed over the years that probably could have been fixed with a soldering iron and nice people willing to share their knowledge.
  • retiredcaps
    replied
    I checked here already for the OP. Topcat (not Tom - as I originally wrote earlier) has 2200uF 16V, but not 1500uF 35V as per
    https://www.badcaps.net/pages.php?vid=22
    which is why I suggested Digikey with the Panasonic FM part numbers. I just wasn't sure if this was the right Panasonic series or not.
    And yes, I agree that almost any type of cap will work with the other poster (including general purpose), BUT some members are quick to point out (in sometimes not so diplomatic ways) that you should match ripple, esr, etc by reading the datasheets.
    Originally posted by momaka
    Rubycon ZL is avaliable from here (badcaps.net), but I'm not sure if Top Cat has the ones you need, so you should check that.
    replied
    Originally posted by Lobo
    Does "GF" sound right?
    Yes. Now I see that you even mentioned it in your first post, but I just never saw it .
    Anyways. Looks like United Chemicon KZE and Rubycon ZL are good matches for those CapXon GF caps. That means Panasonic FM would also work so any of these 3 choices should be good. According to datasheets, Nichicon HE and Chemicon KY are not as good as CapXon GF. But then again, CapXon GF are probably much better on paper than in real world applications, so HE and KY might also work.
    You can get Chemicon KZE and Panasonic FM both from Digikey and Mouser. Same goes for Nichicon HE and Chemicon KY. Rubycon ZL is avaliable from here (badcaps.net), but I'm not sure if Top Cat has the ones you need, so you should check that.
    Let us know how it goes and like Dgtech said, keep it simple and don't worry too much. Those CapXons are already bulged so you can't get much worse than that.
  • Dgtech
    replied
    Dude seriously, with there being only four caps to replace, this is getting to be too scientific. Keep it simple, this is your first recap.
    Lets be real for a second. Even if you replaced these caps with the same brand (which I dont suggest), the unit may work for years. Some monitors with these bad brands dont fail until year 6 or longer. Even if you soldered in new capxon caps just to see if this fixes the unit, fine. Then you can take the time to enjoy what you have until you've done some research into some better caps just in case the unit fails later. Depending on how hard it is to take this thing apart though, you might just wanna do it right the first time.
    Just dont get too caught up in the science of it all.
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • Ifixstuff9
    Philips 42PFL5432D/37 power supply issue no 12v
    by Ifixstuff9
    I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
    After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
    05-02-2021, 09:29 PM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
  • Cornito
    Philips 50PUH6400 bad color and gosting / slow motion on one side
    by Cornito
    Hello Team,
    New issue on LCD panel where I need to find out the cause and the potential solution.
    This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
    I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
    When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
    I've checked voltages, no issue found comparing right and left side of the panel driver.
    VHG VGL CKV... are the sames on...
    03-08-2024, 06:41 AM
  • spantor
    Activate power board Philips 40PFH40009/88 tv
    by spantor
    Hello partners.
    Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
    The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
    02-11-2024, 05:07 PM
