NEVIR NVR-7402-40HD-N no standy by light
  • mi16rs
    • Jul 2015
    • 43
    • Portugal
    Re: NEVIR NVR-7402-40HD-N no standy by light
    I understand what you mean but this diode is not conect to the LNK6777E it , the anode goes straight to the transformer and the cathode goes to a resistence that is under the heatsheld and then goes to de 103m blue capacitor thats near the main capacitor
    • R_J
      • 9555
      With no power applied, check the resistance between drain and source of the controller ic. I suspect the resistor under the heatsink could be open.
      • mi16rs
        • Jul 2015
        • 43
        • Portugal
        Hi R_J i dont know how to check the resistance as i dont know the pinout for the controller LKN7666E
        • dskall
          • Oct 2016
          • 2905
          • usa
          https://cdn.badcaps-static.com/pdfs/...6c3b87121c.pdf
          • R_J
            • 9555
            First you need the correct number of the controller. then you can look up the datasheet.
            you posted : LNK6777E and LKN7666E
            Is it a LNK6777E? if yes here is the datasheet
            • mi16rs
              • Jul 2015
              • 43
              • Portugal
              #26
              whit the power suplly off i have the only 2 pins that gave some value is the mark in red
              so the feedback and bypass pin is the only ones that gives some value
              • R_J
                • 9555
                Those are not the pins I asked you to check, Check between pins 5 and 7
                • mi16rs
                  • Jul 2015
                  • 43
                  • Portugal
                  #28
                  yes i know i have got nothing in those 2 pins 5 and 7
                  • R_J
                    • 9555
                    Then I suspect the controller might be ok. Check the voltage between the main capacitor negative (HOT GROUND) and pin7 of the controller ic.
                    • mi16rs
                      • Jul 2015
                      • 43
                      • Portugal
                      #30
                      290v same as iff i mesured the capacitor direct
                      • R_J
                        • 9555
                        Check the voltage between the HOT Ground and pin 4 of the ic, this should be around 6VDC
                        • mi16rs
                          • Jul 2015
                          • 43
                          • Portugal
                          #32
                          no , got nothing betewen hot ground and pin 4
                          • R_J
                            • 9555
                            Check that there is no short between pin4 and hot ground, if nothing is shorted I suspect the ic is bad, the internal startup cell is bad or something inside is killing the 5.75v startup voltage.
                            • mi16rs
                              • Jul 2015
                              • 43
                              • Portugal
                              #34
                              no no short to ground , i will order a new ic , and let you know , thanks for the help
                              • mi16rs
                                • Jul 2015
                                • 43
                                • Portugal
                                #35
                                HI,
                                Finaly the Ic as arrived , and the tv is working .
                                Thanks a lot for all the users that help me on this one .
                                • learnmore
                                  Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                  by learnmore
                                  Hello Community!
                                  CASE DETAILS
                                  Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                  13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                  Tried inserting firmware on USB and left it in for a few hours, but no change
                                  03-03-2024, 09:49 AM
                                  Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                  by sam_sam_sam
                                  I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                  I also have back when Light of America had these light bulbs available for yard lights
                                  The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                  While the Lithonia lighting fixture has all most certain bulb failure
                                  So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                  I have only had this light fixture for not more than a year if it...
                                  07-02-2023, 03:45 PM
                                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                  LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 09:10 PM
                                  09-06-2024, 08:40 PM
