LG55UB850V no picture or audio - flashing LED's help please?
  • Scoff
    • Jul 2017
    • 101
    • Uk
    #101
    Re: LG55UB850V no picture or audio - flashing LED's help please?
    Thank you. I soldered a short jumper wire between those 2 points.
    I turned the tv on and the screen came on, however, the same voltage fluctuation and buzzing came back from the T-Con cap
    • Diah
      • Feb 2013
      • 6498
      can you disconnect the LVDS from T-CON side.. and check the cap you mentioned if it had direct connection at any of LVDS socket pins on t_CON
      if there are no direct connection to the sockets pins ...
      then remove the jumper.. solder back Q2301 at it place.
      go to the cheap option replace T-CON.. but the questions i cant find answer why T-CON got damaged, or its really damaged.
      • Scoff
        • Jul 2017
        • 101
        • Uk
        #103
        OK i've checked as you said, and there are several pins from the LVDS that have a direct connection to the negative side of the cap on the T-Con board, however there are none that I can find that have a direct connection to the positive side of the cap.
        It's certainly very strange how the T-Con may have become faulty, as it was seemingly working fine back at the start of the troubles, after first unplugging the WiFi module.
        When looking for a replacement board, I can easily match the details:
        Model: V14 TM120 UHD Ver0.6
        P/N: 6870C-0502C
        as this board seems to be used across a variety of LG models/sizes.
        The numbers I cannot match are those printed on the white sticker -
        NBD25G
        3703M1
        Are these simply to uniquely identify my particular board, like a serial number, or do I need to keep looking to find a board with these same numbers in the white sticker?
        • nomoresonys
          • 12307
          • U.S.
          #104
          Good one there to help you with testing: https://www.youtube.com/watch?v=DiW6nNk1TYA
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #105
            This should be the correct one
            https://www.ebay.co.uk/itm/125119290...wAAOSwj~th9-5b
            see link about lg tcon
            https://www.tvparts.co.uk/lcd-tv-spa...-LG-TCON-BOARD
            • Diah
              • Feb 2013
              • 6498
              well i dont think the t-con defect.. but it could be one of VDD line on mainboards which are make the conflict on T-CON. if you feed the T-CON with 12V VCC with out LVDS i dont think this caps will buzzer at all and the VCC will remain stable
              • Scoff
                • Jul 2017
                • 101
                • Uk
                #107
                Thank you both for the links! The ebay T-Con is the nearest match I have seen, although the title doesn't specify 55UB850V - but it looks like it should be correct.
                One other thing which I don't think can be T-Con related is the Optical audio port not lighting up red. While I wait for the T-Con to arrive, is there anything I can check/test to see what's wrong there? Again, way back at the start of the troubleshooting this was lighting up red...
                • Scoff
                  • Jul 2017
                  • 101
                  • Uk
                  #108
                  I have an adjustable DC power supply which goes up to 30v, should I use this or should I take 12v from the power board to the T-Con, bypassing the LVDS, to check for buzzing / fluctuation?
                  • nomoresonys
                    • 12307
                    • U.S.
                    #109
                    Sure use the adjustable, just don't take it past 12 volts.
                    • Diah
                      • Feb 2013
                      • 6498
                      yes, use the PCB 12V rail to F1. LVDS must be disconnected and CN5 Vsyn should be in place on t_CON
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #111
                        i still think this is a mainboard fault though and must be common issue as non available online.
                        • Scoff
                          • Jul 2017
                          • 101
                          • Uk
                          #112
                          So jumper removed and transistor soldered back onto the MB, so MB is complete again.
                          Fitted it back to the TV, removed the LVDS cable from the T-Con, connected a jumper wire from the 12v J71 to T-Con Fuse F1.
                          Powered the TV on and backlights came on, no buzzing from T-Con cap like this, and voltage stable at 11.8v at fuse F1.
                          So T-Con cap only buzzing when it is getting it's 12v feed from the MB via the LVDS.
                          Does this test show the the T-Con is actually OK, or could it still be faulty? What about the Optical audio port?
                          • Scoff
                            • Jul 2017
                            • 101
                            • Uk
                            #113
                            Yes there has to have been an issue with these boards, as even though the model is a few years old, I would have though there would be a few boards kicking around in working condition. Perhaps most people that have had issues in the past have binned the faulty board and replaced rather than fixing the faulty component on the board. Understandable given the time it takes to diagnose - especially when you have no experience!
                            I would love to be able to fix the MB if at all possible, for my own satisfaction, but I understand that perhaps there is only so far one can go, even with all the help from the experts on this forum!
                            • Diah
                              • Feb 2013
                              • 6498
                              as expected.. T-CON full function.
                              the Optical ports working direct with Main CPU IC100 on LG and some other brands too. so the issue 100% MB. ignore the order of t.con if you can.
                              the MB we will not able to track and test unless you naked the DDRs and main IC from the heat sinks .
                              BTW you need back to solder my request at post #76
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #115
                                from reading various threads lg seem to suffer from bad bga soldering could be ram could be main ic so remove re ball the ics would be ideal if had correct stencils and bga machine but ics could be faulty internally too.
                                not sure if you watch phils youtube channel but he re balls bga by hand
                                https://www.youtube.com/watch?v=XiER-Zxo-54&t=27386s
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #116
                                  Stencils are available for the LG chips but the last one I did I used a universal stencil and a bit of kapton tape to mask off the inner part where there are no balls.
                                  • Diah
                                    • Feb 2013
                                    • 6498
                                    this issue to me look like when you start the car but the starter keep on LOL... he had some kind of script repeat it self to take place.. however he tried to heat. and disconnect MICOM action. but i do suggest to freeze but he went to heat.. because the tv was turning on but not complete no panel vcc and optical ports still until now didn't lit on. i would start freezing instead of heating..
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #118
                                      This maybe a set that gets put aside for a while in the hope a replacent mainbord becomes available does the likes of shopjimmy etc list a alternative board?
                                      i thinkk this forum has a for sale/wanted section maybe post in that thread too regarding a working mainboard needed.
                                      • Scoff
                                        • Jul 2017
                                        • 101
                                        • Uk
                                        #119
                                        Thankfully I didn't get as far as clicking 'Buy' on the T-Con board
                                        I will resolder the cap which is not straight, as per your post #76, however it does have good electrical contact on both sides.
                                        I will also remove the heatsinks from the DDR and IC chips to expose them all.
                                        It is good that the issue is isolated to the MB at least.
                                        • Scoff
                                          • Jul 2017
                                          • 101
                                          • Uk
                                          #120
                                          Sadly I don't have anything as advanced as a BGA machine, as other than the odd basic soldering job in the past, mainly auto-electrics, I'm very much an amateur/Noob - but very willing to learn and try things.
                                          I think re-balling would be a bit too much to tackle with my lack of experience, and the outlay for the equipment would be too much for a one off job.
                                          I could look at getting a price for sending the board off to get the main ICs and DDR re-balled as see if it is cheaper than a new TV as I have no idea
                                          Wow not seen that Phil guy's channel before - just watched some of the highlights of that epic PD4 APU reballing by hand
                                          • Green Probe
                                            Recapping a Denon AVR X6400h SMPS
                                            by Green Probe
                                            (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                            Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                            Always use caution when working around mains power and high voltage capacitors!
                                            Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                            SYMPTOMS:
                                            -No display...
                                            07-18-2025, 03:36 PM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
                                          • Bloopeta
                                            Samsung UE43KU6400U Flashing Red Standby Light
                                            by Bloopeta
                                            Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                            Power button does nothing
                                            Have unplugged the mainboard, and backlights illuminate.
                                            Have tried removing panel ribbon cables one at a time, and that makes no change.
                                            With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                            Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                            09-11-2023, 02:34 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
