LG55UB850V no picture or audio - flashing LED's help please?
  • Scoff
    • Jul 2017
    • 101
    • Uk
    Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
    I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
    We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at all and no LG logo on the screen. The screen stays completely black. I've used a flashlight to check and there is no life on the screen at all.
    The model is LG 55UB850V. I have taken the back off the set and observed the following internally.
    The power supply board is model PCB: EAX65613901 (1.6), LG P/N: EAY63149401 REV 1.0 2014.01.27
    The Main Logic board is model L#41V EAX65684604 (1.0)
    The T-CON board is mode V14 TM120 UHD Ver 0.6, LG P/N: 6870C – 0502C
    When the set is in standby mode, there are no LED's lit up on either the power supply board or the main board. When I press the power button on the remote or the TV, the red standby led flashes 3 times and then goes out. The red led LD2300 on the main logic board is lit up solid and the red led LD1900 on the main logic board lights up briefly for around 1 second then goes out.
    After 60 seconds in this state, the amber LED LD701 on the power supply board starts flashing a sequence of 5 flashes, and then 5 seconds off, then 5 flashes, then 5 seconds off etc. This carries on seemingly indefinitely.
    During this time there is absolutely nothing on the screen.
    If I leave the set in this state, as if the screen should be on, and with the amber LED LD701 repeatedly flashing it's 5 flash sequence, for around 20 minutes or so, then use the remote to put the set back into standby, then again use the remote to turn the set on form standby, it springs back into life.
    It seems the set needs to have constant power, in the normal 'on' state for around 20 minutes or so before it will then start to work, once put into and back out of standby.
    Can anyone suggest what might cause this behaviour? If I unplug the set form the mains, and then plug it back in again, it fails to work, until I have left it in the 'on state for 20 minutes or so.
    Could this be cause by failing capacitors that are unable to keep their stored voltage once the mains power is cut? Could it take 20 minutes or so for them to get to full capacity in order to allow the set to start functioning correctly?
    The 28 pin connector on the power board has all the correct ground, 3.5v, 12v, and 24v readings when tested, even when the screen isn't on or working.
    Thanks for any help!
    EDIT: My 20 minute theory has gone out the window - it must have just been a fluke that it started working. During this 'working' spell, the tv was still face down on my bed with the back removed while I was testing. After reassembling the back and putting the TV back on its stand, I couldn't get it to switch on again, even after leaving it in standby as well as in what should be the 'on' state overnight.
    After taking the back off again, I can see that what DOES happen after 20 minutes of being in the 'on' state, all LED's turn off, and the red standby light goes solid again - must be some sort of timeout or power saving setting, making it go back into standby mode.
  • Diah
    • Feb 2013
    • 6496
    Re: LG55UB850V no picture or audio - flashing LED's help please?
    try unplug the wifi module / speaker socket and turn on.
    athe sign of the tv working (as you will put the tv surface on yours bed )take always the Red LED on the audio SPDIF port if it lit on.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Cutting power to tv can corrupt firmware.
      • Scoff
        • Jul 2017
        • 101
        • Uk
        You Sir are a genius! I unplugged the 8 pin connector going to the WiFi / Bluetooth module - LGSBW41 EAT62093301
        and the TV screen powers up first time every time now! I'm not sure if this will cause any problems by being left unplugged, however I will put the back of the TV back on and see what happens.
        Is this a common issue on this model? I imagine it will no longer be possible to buy a 'new' module, only other used ones.
        I'm not sure if I can run an ethernet cable to the TV point to use instead, but I would like the WiFi to work if possible. Depending what is wrong with this board, i guess it may be possible to have the board repaired?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          i have seen a couple of wi fi modules fail like this i just purchased a used one from ebay and fixed the issue.
          • Scoff
            • Jul 2017
            • 101
            • Uk
            Thank you, that's useful to know. When sourcing a replacement board, do you know if it is essential to match the board version number? For example, my board shows LGIT: TWCM-B001D V1.6
            I have seen some versions of this board that show V1.7 and also V1.8.
            Would I need to get another V1.6 board, or is the version not as important provided I get the identical part numbers? On the V1.7 and V1.8, all part numbers printed on the boards appear to be identical. The only visual difference seems to be that the V1.8 has several CNC-ID numbers printed on it in the upper right area, and the Brand just says LG, compared with LG Electronics on my V1.6 e.g
            • Diah
              • Feb 2013
              • 6496
              disconnection the wifi module its part to remove load on the mainboards.
              at LG if you now send IN_STOP command(read about this command over this forum i explained it many time to make hard reset). after it go to reboot plug it out from wall... connect yours wifi again and see if it will assign it again so you can use this future on yours LG
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                if needed does this one match your board https://www.ebay.co.uk/itm/203443190...QAAOSwnOFgkohD
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  lg service remote apk
                  • nomoresonys
                    • 12306
                    • U.S.
                    If that don't work maybe clean it up, demonstration there: https://www.youtube.com/watch?v=xX9bB92UBbA
                    • Scoff
                      • Jul 2017
                      • 101
                      • Uk
                      Thanks for all the responses and info provided. I'll see if I can knock up an IR Blaster and give that a try so I can send IN_STOP Command. Failing that I'll pick up a used replacement board like the one vinceroger69 kindly linked.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        lg service remotes have certainly dropped in price now i may order myself one
                        https://www.ebay.co.uk/itm/133978976...3ABFBM7LfTsdNf
                        • Scoff
                          • Jul 2017
                          • 101
                          • Uk
                          I've had a look and can't find any IR LED's in my box of bits, so I'm going to order one of these service remotes instead - thanks for the link!
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            that app works on a android phone too i think if you have one.
                            • Diah
                              • Feb 2013
                              • 6496
                              IN_STOP are very effective action in such cases as yours. but you can try the factory reset from the TV menu. when it go to start reboot plug out from wall and reconnect your wifi module.. if it come on and u can use the wifi every things mean fine.
                              • Scoff
                                • Jul 2017
                                • 101
                                • Uk
                                I have a couple of android phones, but not old enough to run the legacy version of the remote app required. Also they do not have IR Blasters built in.
                                Funnily enough ,I just came across an old Nokia 3200 phone which does have an IR blaster built in. Now if I can just figure out a way of using it for this application...
                                • Scoff
                                  • Jul 2017
                                  • 101
                                  • Uk
                                  OK so I gave up on the IR Blaster idea and ordered an LG Service remote from amazon which arrived today. With the WiFi/Bluetooth module left unplugged, I turned on the TV no problem and pressed the IN_START button just to see some stats and that service screen came up fine showing over 16500 hours of viewing!!
                                  I pressed the IN_STOP button and entered the 0413 code and carried out the hard reset. Once the TV was back at standby I unplugged it and plugged the WiFi module back in, then turned the TV on and it switched on fine and allowed me to join my WiFi network and carry out the initial setup!
                                  I switched it off and back on several times after setting it up and all seemed OK, so I switched it off again and put the back cover back on and mounted it back onto its stand.
                                  Tried turning it on again and nothing, back to square one
                                  So the IN_STOP command seemed to fix it and allow it to boot up with the WiFi module plugged back in, which it wouldn't do before, however it was short lived and now no longer boots again.
                                  Does this confirm my WiFi module is faulty, or could it still be a problem on the logic board which is caused by the load of having a WiFi card connected?
                                  • Diah
                                    • Feb 2013
                                    • 6496
                                    i think yours problem at the Bluetooth section not the wifi... if you were before to turn off the bluetooth will be fine,, or when it first time turn on and you finish with setting and did IN_STOP again while the module connected could be fine too to reset the module MAC.
                                    • Scoff
                                      • Jul 2017
                                      • 101
                                      • Uk
                                      Thank you. How do I disable Bluetooth and leave WiFi enabled on the module? Is there something within IN_START where I can disable Bluetooth? I can only see WiFi information within IN_START and no Bluetooth information? Here is a picture of IN_START with the WiFi module UNPLUGGED
                                      • Diah
                                        • Feb 2013
                                        • 6496
                                        Man.. IN_Start or E_Z adjust service menu not for you... never inter it...
                                        now your mudule disconnected.. at normal menu setting the option will be gray ( because no mudule installed )
                                        so just after you exit this service menu plug the TV out from wall socket ( dont turn off from RC )
                                        plug yours module and after it turn on you can send in_stop again to reset MAC. later when every things fine.. go to the menu setting from there turn off bluetooth
                                        • Green Probe
                                          Recapping a Denon AVR X6400h SMPS
                                          by Green Probe
                                          (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                                          Disclaimer: I'm an amateur hobbyist and will get things wrong.
                                          Always use caution when working around mains power and high voltage capacitors!
                                          Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                                          SYMPTOMS:
                                          -No display...
                                          07-18-2025, 03:36 PM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • rabbituk
                                          Sony HCD BX7700dbi CMT flashing standby
                                          by rabbituk
                                          I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                          So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                          02-11-2025, 05:05 PM
                                        • Bloopeta
                                          Samsung UE43KU6400U Flashing Red Standby Light
                                          by Bloopeta
                                          Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                          Power button does nothing
                                          Have unplugged the mainboard, and backlights illuminate.
                                          Have tried removing panel ribbon cables one at a time, and that makes no change.
                                          With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                          Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                          09-11-2023, 02:34 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
