Help with identifying missing resistor from JVC push buttons TV3024-ZC10-01(C)
  • cheeky2
    • Dec 2012
    • 337
    Someone previously had damaged a couple of the push buttons who has whilst pushing them in pushed off a smd resistor from a JVC 40" LED TV LT-40C550 main board MSDV3255-ZC01.
    The missing resistor off the push control buttons TV3024-ZC10-01(C) pcb is R06 see the pictures.
    I have tried downloading manuals for the Haier manufactured main board however they don't include the schematic for the push buttons!
    So if anyone has the pcb that could measure the resistance or have a schematic diagram for it would be much appreciated.
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: Help with identifying missing resistor from JVC push buttons TV3024-ZC10-01(C)
    Most likely the will the same value as the other resistors on the right side between K6 and K7.
    • cheeky2
      • Dec 2012
      • 337
      Unfortunately that's not the case in this pcb
      • alfatv
        • Sep 2020
        • 353
        Replace resistor with a potentiometer and keep adjusting it until it functions properly.
        • cheeky2
          • Dec 2012
          • 337
          This is what I came to the same conclusion myself. The problem being the smd resistors are the small size 0402 so connecting up the thin wires to the pads on a potentiometer is going to be tricky without damaging them! Looks like the microscope is coming out!
          • badcap111
            Xiaomi mi 9T missing resistor
            by badcap111
            Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
            I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
            Is...
            08-07-2023, 10:42 AM
          • ugamazing
            Assistance with identifying resistor value on 820-02918 A2992 board?
            by ugamazing
            Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
            I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
            09-06-2024, 08:33 AM
          • spleenharvester
            Ugreen HDMI splitter missing a pulldown resistor
            by spleenharvester
            Odd one I've found. This splitter likes to cut out - on my Xbox Series S the display/audio would randomly go to black for a few seconds - on my PC the monitor would flicker several times before eventually staying on. A few others have reported similar issues. Couldn't be bothered returning it for the sake of £8.
            I pulled it apart and found it is driven by a Texas TS3DV642 mux/demux. There appears to be a missing pulldown resistor on the HPD line, it is just left floating. Adding a 100K pulldown to ground fixes the flickering.
            (Not that this is worth the hassle for an...
            09-15-2025, 11:23 AM
          • plummmm
            Asus X570-P identifying potential missing SMD
            by plummmm
            I am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
            The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just...
            08-29-2025, 11:57 AM
          • liquidzorch
            Missing resistor on BQ ILIM pin. DA0P5JMB6D0
            by liquidzorch
            Hello. I can't find the schematics anywhere for this motherboard, does anyone have one, and can give me the resistor value for the BQ728H missing in pic below? I already read the dadsheet, and this resistor value is calculated, so I can't just go with whats in the "typical" diagram.
            On a second note, could this resistor cause it to only boot with the battery and not the charger? It boots fine with a charged battery, but will not turn on with the charger (nor charge). The 19v does not get past the first mosfet, it recieves pulses to turn on, but something is preventing it....
            12-18-2023, 01:56 PM
