samsung la32a436t1d upside down picture
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have the above model of tv and it shows the picture upside down
    Does someone know how can i fix this problem i have do already factory reset without result ?
    thanks in advance
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: samsung la32a436t1d upside down picture
    what mainboard number and lcd number (usually on a white sticker) is used in this set
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      lcd number you mean the display sir ?
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        yes thats the one
        • dskall
          • Oct 2016
          • 2905
          • usa
          https://www.youtube.com/watch?v=ds2l...hnologyReviews
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            thanks for the answer sir
            if and i didnt understand from the video how can i find the right type for my tv
            it happens something strange
            i disconnect the tv from power upply and connected again after 2 hour approximately and now the picture come back normall but the colours have distort like solarize picture
            i think my tv have serious problem
            is there case to be the firmware ?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              could be the wrong lvds settings has this tv been worked on before
              • Xristakis795
                • Mar 2021
                • 162
                • Greece
                and can i change this sir ?
                • Xristakis795
                  • Mar 2021
                  • 162
                  • Greece
                  thanks a lot sir
                  i change the option in lvds format in jeida and the colours fix
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Could be firmware. Seems settings are changing.
                    • nomoresonys
                      • 12306
                      • U.S.
                      I would try a firmware update too, if it keeps messing up after then it's prolly a mainboard issue. The screens don't usually just flip, you could get a flip if someone put a missmatch board in, has it been worked with before?
                      • Xristakis795
                        • Mar 2021
                        • 162
                        • Greece
                        yes sir works normal
                        i change only t con board with a saame type before two months because i had distort colours without problem
                        just because has sound and no picture in digital channnels i had do factory reset
                        but without cause this procedure problem again
                        Suddenly one morning i open the tv and i saw the picture upside down
                        As about as the firmware version update i have look to find a file without success
                        I cant find
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Thats good the tv is fixed the tcon you fitted may of not been a exact match as the old one hence the issues the main thing is its working now, could the tv self updated the software one morning hence on that day you had the issue start?
                          • Xristakis795
                            • Mar 2021
                            • 162
                            • Greece
                            I do not know sir
                            but it is old and does not have internet connection to update itself
                            Anyway, it's important that it works now
                            Thank you very much for the useful information you gave me
                            my only problem now is to find some firmware to upgrade it
                            • cheeky2
                              • Dec 2012
                              • 338
                              • uk
                              I bet your original tcon board had a as15f failure on it.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                I do not know sir
                                Its quite a old set now 2008 i think i have had a look online and cant find any firmware
                                • nomoresonys
                                  • 12306
                                  • U.S.
                                  While you were in the service menu did you see anything like screen flip or such? need to be VERY careful in there.
                                    09-07-2024, 05:50 AM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • JJAAMM
                                    by JJAAMM
                                    Problem
                                    07-06-2023, 06:01 AM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Dodgethis
                                    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                    by Dodgethis
                                    Hello all,
                                    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                    09-11-2024, 07:39 AM
