Tcl 55r635
  • Jason616
    • Sep 2016
    • 99
    Tcl 55r635
    I can see the tv turn on but there is no picture .
    Tried hard resetting it ect with no luck I can see the tv turn on but the screen remains blackish/white screen .
    Any ideas ?
  • neilc6
    • Nov 2015
    • 1550
    Re: Tcl 55r635
    If TV turns on with no backlights or flash of backlights, backlights are first suspect. If TV turns on with backlight but no video, tcon is first suspect but some newer models don't have tcon boards.
    • dskall
      • Oct 2016
      • 2905
      • usa
      Re: Tcl 55r635
      So tap on screen. Do you see any white flash where you tap? With flashlight do you see any image on screen?
      • Jason616
        • Sep 2016
        • 99
        Re: Tcl 55r635
        I can see the leds come on the screen will light up white .
        But no picture and can't see the menu or anything on screen just white
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: Tcl 55r635
          So white screen. Need pictures of boards. T-con?
          • Storyteller12
            • Jun 2020
            • 624
            Re: Tcl 55r635
            Picture of the tv with the boards would be a good start.
            As mentioned if there is a tcon board I would check the fuse to see if it’s getting any power first.
            • Jason616
              • Sep 2016
              • 99
              Re: Tcl 55r635
              Here are some pics let me know if you need more
              • Storyteller12
                • Jun 2020
                • 624
                Re: Tcl 55r635
                Ok. Looks like you do have a tcon board. Do you have a multimeter to test it for power?
                You can try unplugging one side of the lvds cables going to it and see if you get a picture on either half of the screen.
                • Jason616
                  • Sep 2016
                  • 99
                  Re: Tcl 55r635
                  Yeah I have a multimeter
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Re: Tcl 55r635
                    White fuse one right side of cable coming into t-con. Need to measure both sides for voltage.
                    • Jason616
                      • Sep 2016
                      • 99
                      Re: Tcl 55r635
                      I get 12 volts on each side of it
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        Re: Tcl 55r635
                        T-con to blurred and upside down for me to read.
                        • Jason616
                          • Sep 2016
                          • 99
                          Re: Tcl 55r635
                          Here are some more pics of the t con board
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Re: Tcl 55r635
                            On the fuse side of board there are various test points, VGHF, HVAA, VDD's. etc. to check.
                            • Jason616
                              • Sep 2016
                              • 99
                              Re: Tcl 55r635
                              Do you need the voltages ?
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Re: Tcl 55r635
                                Yes, Unless you know if they are all correct.
                                • Jason616
                                  • Sep 2016
                                  • 99
                                  Re: Tcl 55r635
                                  Vghf:0.00
                                  hvaa:0.00
                                  vddv3:0.24
                                  vdd1v:0.00
                                  vcc:11.97
                                  vdd1v8:0.00
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    Re: Tcl 55r635
                                    So, you have voltage to t-con but board is dead. Missing Vdd3v3 voltage is probably why you're missing the rest of your voltages.
                                    • Jason616
                                      • Sep 2016
                                      • 99
                                      Re: Tcl 55r635
                                      Looks like I will be buying a new t con board
                                      • Sevenqi
                                        • Jul 2011
                                        • 292
                                        Re: Tcl 55r635
                                        t-con may not a problem for this model TV. You can try to disconnect the right side of the panel board cable (brown color from the second photo), then power on tv to see if you can see anything on the screen.
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
                                        • dicky96
                                          HP Elitebook Screen blank - backlights but no image
                                          by dicky96
                                          Hi guys
                                          I'm trying to fix this laptop screen
                                          Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                          OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                          I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                          04-28-2021, 07:30 AM
