Philips 32PFL3605/12 U4201 replacement
  • Pulka
    • Sep 2019
    • 3
    • Hungary
    Hello everyone!
    This is my first post, but not my first attempt to repair a TV.
    So a few days ago I got this Philips TV (TPM4.1E LA), which produced weird symptoms.
    There were no 12 and 24V, which was caused by a shorted schottky. I replaced that, the voltages are alright everywhere, but it still refused to turn on or even produce a standby light.
    Thats when I removed the cover lid from the U4201, turns out that it badly burnt through, thanks to that replaced diode. It's an MTK MT8222TMMU, and I already found a replacement for it. However in the service manual, it's listed as MT8222AMMU/A.
    So my question is, should I go through with the TMMU one, or use the AMMU/A?
    I'll attach some images which might help, since I couldn't find a datasheet for the AMMU/A.
    Thank you to everyone in advance, who might be able to give some advice!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Philips 32PFL3605/12 U4201 replacement
    I would go for the same as the one one the board. You picked an ambitious repair.
    • Pulka
      • Sep 2019
      • 3
      • Hungary
      Thanks! I figured that I should just pick the same one.
      I tend to pick up TVs with power issues, since they always have a surprise in them. I mean, what's the fun if it's just some caps? ;D
      • dskall
        • Oct 2016
        • 2905
        • usa
        My first attempt at doing one of these ic was a bunch of torn off traces.
        • R_J
          • 9624
          Since the ic is definitely bad, use a sharp knife to cut the pins right at the ic body making sure you don't cut down to the board and cut a trace, then you can easily remove the pins from the board.
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
          • Rauni
            Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
            by Rauni
            Hello, this is my first post on this forum, and my first attempted to repair a TV.
            My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
            Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
            Read also that we should test what happens if we...
            10-01-2023, 12:06 AM
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
