Phillips 50PF7321D/37 Plasma slow reboot
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Phillips 50PF7321D/37 Plasma slow reboot
    well bad news, I got a used Y-board off ebay for $45 and broke the FFC connector on it so I can't use it
    good news, i let it cool and put the heat gun on that vertical board and the screen turned on pretty fast, so, that is it. I'll get some new caps for it and see if that makes a difference. If it does not, I'll unsolder that board off the one I bought and put it on the original
      • 12146
      • U.S.
      I like your determination, I think you can get that old thing going, I have an old lg plasma thats trying to beat me down, replaced upper buffer then found the x had most transistors shorted out, waiting on those to show up but I'm not very optomistic, prolly find more shit bad before its over.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I hate this thing. Taken it apart at least seven times and it's 100lbs and not easy. I said he should get this
        https://www.amazon.com/Sceptre-50-in.../dp/B01CJV6722
        even though it's cheap, it's not a smart tv because they use a roku and cable.
        to hold them over anyways before they get a high end one. They said nah, to keep this 17yo 720p plasma
        Not even sure the'll get a high end one. They watch tv alllll the time.
        they wanted it back today but changed their mind, I offered to drill a hole on the back cover (steel) where this board is and they can use a hairdrier in the mean time to keep it warm, but I they asked how long till I can fix it, so I just ordered some caps from mouser. Luckily I'm literally 5mins away from the mouser HQ so I can pick them up from will call monday
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          what is the fine tuner on that board? Since I'm using some new caps, am I going to have to adjust something to compensate for this?
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            If the picture is good and the trimpots haven't been touched, do not adjust anything.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              #26
              Well it worked. The tiny one I could not get to so I put on the other side 🤷
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                #27
                Interesting, before and after I fixed it, when they used component, the sound actually created this red semi-transparent blobs up and down the screen (when the audio was silent it went away)
                I put them on HDMI (TV only has one port, so I got a 3xHDMI switcher with IR remote that my brother in law gave me like six years ago)
                but on HDMI, the left side of the screen (irrelevant of input-cable, roku or DVD), there is a permanent green ~1" line on the very left edge, that pushes the screen right the same size. I tried to adjust the picture x and y but it made no difference. I wonder if there is some bad caps on the video board. I recapped most of the caps on the power board I know the power going to it is very stable, unless there is other components with issues. He says it doesn't bother him. Bothers me a little bit
                  • 12146
                  • U.S.
                  #28
                  so it does this when you use the hdmi switcher or just the hdmi without switcher or both?
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    #29
                    both
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      #30
                      There's no overscan or underscan on the picture? Meaning there's no cut pixels except that it is shifted horizontally?
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        #31
                        It cuts off an inch on the left side, and moves the picture and inch to the right side. I tried to use the config menu to move the picture to the right and the line did not move
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          #32
                          If it only happens in HDMI it's something with the main board, try factory reset or access the service menu and look for some option that could do this picture shifting.
                          • spice_disc
                            Vizio TV M50-C1 reboot cycle and static on screen
                            by spice_disc
                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                            09-08-2024, 02:37 PM
                          • jimbofz
                            samsung plasma ps50 c580g1k slow tripping relay
                            by jimbofz
                            Hi ,this appears to have 2 faults
                            black lines on raster and faulty main board ?
                            let me explain futher
                            at switch on the relay does a few slow clicks with red led blinking and repeats every 10 seconds .i ran the psu into 2x 100w lamps and it runs fine all day supplies good .
                            i removed y sus and x sus checked for dry joints and checked all igbt anf fets all ok
                            next i removed buffer and checked for any s/c buffer ics all ok
                            so i unplugged feed to main board from logic board and linked test points pin 3 and 4 ,
                            tv still trips but now i get plain...
                            03-15-2021, 02:18 AM
                          • gjlpereira
                            MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                            by gjlpereira
                            Hi forum.
                            I'm working on a macbook pro, model a1708, that is running extremely slow.
                            Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                            One other symptom of the problem with the machine is that the fan is always running at full speed.
                            This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                            09-06-2022, 07:45 PM
                          • jesterace
                            Samsung Plasma PS60E530 no image, slow blinking green led
                            by jesterace
                            Trying to figure out what might be wrong with this plasma tv. It gives no image at all, not even a flash. No sound. The status led on the inside of the tv blinks very slowly. Maybe once every 5 or more seconds (which i understand indicates a fault causing shutdown).
                            I tested the main voltages which came out as follows:
                            VA: 57v (Panel states 57v)
                            VSC: -45v (Panel states -200)
                            VS: 213v (Panel states 211v)
                            VE: 139v (Panel states 105v)
                            I tested the VSC at a capacitor on the Y MAIN board labelled VSCAN but i'm not sure...
                            10-01-2019, 06:06 AM
                          • nissimezra
                            HP Notebook 15-dy1731ms VERY SLOW
                            by nissimezra
                            Hi to everyone.
                            I never seen something like this. I have HP Notebook 15-dy1731ms motherboard: DA0P5DMB8CO REV C that is very very slow. I tried all the basic, updating the bios, replacing ssd, replacing ram, soldering all coils, reflow CPU power supply but the laptop is still very very slow. Never seen a motherboard that is slow. CPU power suppliers 1.8 volts, the cpu barely getting hot.
                            What left for me to do is reflow the CPU and try manually programing the bios chip with programer.
                            Anyone have any idea what it can be?
                            04-13-2023, 02:45 PM
