Phillips 55PUS6561/12 EEPROM Bin file
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    Hello there!
    I'm looking for a EEPROM bin file for a Phillips 55PUS6561/12.
    Chassis: QM16.3E_LA
    Motherboard: 715G772-M01-B00-005K
    Thanks in advance! 😊
  • lotas
    • Jan 2016
    • 4900
    • Russia
    Re: Phillips 55PUS6561/12 EEPROM Bin file
    Originally posted by unimatrix93
    Hello there!
    Chassis: QM16.3E_LA
    Dump .bin what spi flash MX25L1605A?
    I have from PHILIPS 49PUS6561 / 12.
    Will it suit you?
    • unimatrix93
      • Oct 2021
      • 360
      • Magyarország
      Will it suit you?
      My model has a MX25L1606E SPI chip, should I give it a try with your bin? 🤔
      Thank you!
      • lotas
        • Jan 2016
        • 4900
        • Russia
        Try:
        Save your Dump just in case.
        • unimatrix93
          • Oct 2021
          • 360
          • Magyarország
          Try:
          Thank you Sir! 😊
          I will try tomorrow and report back with the results.
          • unimatrix93
            • Oct 2021
            • 360
            • Magyarország
            So I reprogrammed the EEPROM with your bin file and the problem is still the same.
            Backlight, display working with no data on it, no menu, nothing just blank screen with flashing red power led. ��
            • William1967
              • Nov 2017
              • 217
              • Netherlands
              Disconnect one of the flat cables between the t-con and display and see what happens, after that do the same with the other cable, don't forget to disconnect the power cable when you disconnect any of the cables. Make pictures and upload them here.
              • unimatrix93
                • Oct 2021
                • 360
                • Magyarország
                Sorry for the late reply but I was away during the weekend.
                Left flat cable disconnected:
                Right flat cable disconnected:
                Both disconnected
                Thanks for your help!
                • William1967
                  • Nov 2017
                  • 217
                  • Netherlands
                  Try this: press 062598 HOME followed by the 3 digit code you find on the rear.
                  • unimatrix93
                    • Oct 2021
                    • 360
                    • Magyarország
                    So I pressed the key sequence and the TV turned off after a few seconds.
                    • William1967
                      • Nov 2017
                      • 217
                      • Netherlands
                      And what happens when you switch the tv on again?
                      • unimatrix93
                        • Oct 2021
                        • 360
                        • Magyarország
                        I made a video for you about the whole procedure.
                        https://www.youtube.com/watch?v=OYD7yCxzAes
                        • m1ch43lzm
                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                          by m1ch43lzm
                          Hi everyone
                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                          There's also an extra OTP Secu.R...
                          09-06-2025, 05:47 PM
                        • my2k2
                          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                          by my2k2
                          Good day to every one,
                          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                          Does anybody have an eeprom dump file? I really appreciate any help.
                          Thanks in advance.
                          07-01-2024, 09:04 PM
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
                        • SidneyCanadas
                          93C46 and 93C56 EEPROM
                          by SidneyCanadas
                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                          06-14-2023, 01:16 PM
