Phillips 55PUS6561/12 EEPROM Bin file
  • unimatrix93
    • Oct 2021
    • 339
    • Magyarország
    Hello there!
    I'm looking for a EEPROM bin file for a Phillips 55PUS6561/12.
    Chassis: QM16.3E_LA
    Motherboard: 715G772-M01-B00-005K
    Thanks in advance! 😊
  • lotas
    • Jan 2016
    • 4476
    • Russia
    Re: Phillips 55PUS6561/12 EEPROM Bin file
    Originally posted by unimatrix93
    Hello there!
    Chassis: QM16.3E_LA
    Dump .bin what spi flash MX25L1605A?
    I have from PHILIPS 49PUS6561 / 12.
    Will it suit you?
    • unimatrix93
      • Oct 2021
      • 339
      • Magyarország
      Will it suit you?
      My model has a MX25L1606E SPI chip, should I give it a try with your bin? 🤔
      Thank you!
      • lotas
        • Jan 2016
        • 4476
        • Russia
        Try:
        Save your Dump just in case.
        • unimatrix93
          • Oct 2021
          • 339
          • Magyarország
          Try:
          Thank you Sir! 😊
          I will try tomorrow and report back with the results.
          • unimatrix93
            • Oct 2021
            • 339
            • Magyarország
            So I reprogrammed the EEPROM with your bin file and the problem is still the same.
            Backlight, display working with no data on it, no menu, nothing just blank screen with flashing red power led. ��
            • William1967
              • Nov 2017
              • 203
              • Netherlands
              Disconnect one of the flat cables between the t-con and display and see what happens, after that do the same with the other cable, don't forget to disconnect the power cable when you disconnect any of the cables. Make pictures and upload them here.
              • unimatrix93
                • Oct 2021
                • 339
                • Magyarország
                Sorry for the late reply but I was away during the weekend.
                Left flat cable disconnected:
                Right flat cable disconnected:
                Both disconnected
                Thanks for your help!
                • William1967
                  • Nov 2017
                  • 203
                  • Netherlands
                  Try this: press 062598 HOME followed by the 3 digit code you find on the rear.
                  • unimatrix93
                    • Oct 2021
                    • 339
                    • Magyarország
                    So I pressed the key sequence and the TV turned off after a few seconds.
                    • William1967
                      • Nov 2017
                      • 203
                      • Netherlands
                      And what happens when you switch the tv on again?
                      • unimatrix93
                        • Oct 2021
                        • 339
                        • Magyarország
                        I made a video for you about the whole procedure.
                        https://www.youtube.com/watch?v=OYD7yCxzAes
                        • my2k2
                          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                          by my2k2
                          Good day to every one,
                          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                          Does anybody have an eeprom dump file? I really appreciate any help.
                          Thanks in advance.
                          07-01-2024, 09:04 PM
                        • Forest79
                          by Forest79
                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                          07-23-2023, 07:39 AM
                        • SidneyCanadas
                          93C46 and 93C56 EEPROM
                          by SidneyCanadas
                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                          06-14-2023, 01:16 PM
                        • hazem3636
                          need Bios Bin file Dell server 220
                          by hazem3636
                          hi everyone
                          i need dump file for dell server r220
                          i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                          i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                          if anyone has this method please need his supporting .
                          all the best
                          EXE file is attched and Original Bin file from the Bios Chip is attached also
                          and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                          11-05-2022, 06:20 AM
                        • dmccul2698
                          Pioneer DEX-P99rs "No EEProm " diagnostic code.
                          by dmccul2698
                          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                          1). Understand the schematic and check the connections between the EEProm and DSP
                          2). Check the functionality of the EEProm
                          I don't know if this is the unit's problem but it's a place to start.
                          I have little to no electronic experience...
                          04-08-2024, 05:32 PM
