TCL 49S515 How to remove lcd panel
  • anupkg1985
    • Sep 2020
    • 180
    I have got a TCL 50 inch tv which has some water damage on the diffuser sheets. TV is turning on and could see the water stains on the screen. I'm trying to open the panel however I don't have idea, how to remove LCD panel. Looks like bezel is not removable from 3 sides so only one side can be opened.
  • anupkg1985
    • Sep 2020
    • 180
    Re: TCL 49S515 How to remove lcd panel
    Looks like LDC and back reflective sheets are is glued inside the metal frame. Any one has idea, how to remove it? I see some water stain on the screen, how to get rid of those without removing lcd?
    • dskall
      • Oct 2016
      • 2905
      • usa
      Usually have small screws and they have to be pried loose because they snap together.
      I can't tell if the plastic is covering the panel or not.
      • anupkg1985
        • Sep 2020
        • 180
        Unfortunately I don't see any screws on the edges or on the frame. I could see double sided black tape inserted on the panel.
        • vinceroger69
          • Mar 2012
          • 6714
          This video published this morning may help as tcl tear down https://www.youtube.com/watch?v=JHvysrIbY1U
          • dskall
            • Oct 2016
            • 2905
            • usa
            What luck. I couldn't find any yesterday.
            • vinceroger69
              • Mar 2012
              • 6714
              im subbed to his channel so was in todays youtube list.
              • anupkg1985
                • Sep 2020
                • 180
                It couldn't help much though as its backlight model and the one I have is the edge light model.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  hopefully it will help in regards to disassembling the set to actually get too the edgelit strips
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Like in the video, I'd have a feel around the edges with one of these https://www.aliexpress.com/item/32903760354.html
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      A lot of larger screen sets im finding there sticking the lcd panel down at various points.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        The panel is loose in the frame otherwise, it makes sense. They aren't assembled with disassembly in mind.
                        • cheeky2
                          • Dec 2012
                          • 337
                          Just seen the video I was shocked to see him lift the screen up from the horizontal flat surface especially with a large screen. I never do that as it's so likely to stress the screen and damage it by cracking it. I always leave the screen TV vertical and then lift it up around 1cm from the surrounding housing which is then already positioned close by a wall. It is then then left resting against the wall.
                          The only other way on this would be to lift the frame out if the outside bezel isn't removed. Obviously this would be very difficult to achieve without causing any damage to the screen ensuring its not taped or glued inside it!
                          Good luck
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                            20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                            by sam_sam_sam
                            I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                            At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                            Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                            04-09-2023, 08:04 PM
                          • howardc64
                            LG 49UJ6500 LCD panel lighter band that goes away
                            by howardc64
                            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                            02-19-2023, 12:13 AM
                          • triplefour
                            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                            by triplefour
                            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                            tcon is built into mainboard.
                            Only one cable goes to panel boards.
                            there is a cable from one panel board to the other that links them.
                            cost cutting measure that results in us having harder time to diagnose.
                            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                            07-28-2022, 07:59 PM
                          • Storyteller12
                            QN55Q60R Service Menu Panel Help
                            by Storyteller12
                            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                            01-13-2024, 01:57 PM
