Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Samsung 65 Dead NO power NO standby light won't turn on
    Originally posted by lotas
    Most likely, the firmware of the standby mode IC1604 25Q40 flew off, as always in the "MU" series. Do you have main BN41-02570B?
    From post 1 i think his main is a BN94-12295K
    • lotas
      • Jan 2016
      • 4708
      • Russia
      I mean textolite.
      • vinceroger69
        • Mar 2012
        • 6714
        I mean textolite.
        sorry i get what you meant now post 7 has a picture pity white sticker over that number but from the first few didgits you can see your probably rite.
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Yes, this is it, now it remains to read the data from the IC1604 programmer and put the dump here, I will check it.
          • rgla
            • Nov 2021
            • 23
            Re: Samsung UN65MU8000FXZA Dead NO power NO standby light won't turn on
            Thanks for replying.
            Those are the exact numbers on my board posted in your image from post #22.
            This is a bit over my head:
            "now it remains to read the data from the IC1604 programmer and put the dump here"
            if it's a firmware update and the board still lives - that would be great. Although how do you do a firmware update on a brick?
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              have you got a programmer thats capable of reading and writing a 25Q40 ic if not look into a ch341a very easy too use and really cheap
              • lotas
                • Jan 2016
                • 4708
                • Russia
                #27
                If the content is corrupted (dump), I will fix it and write the corrected dump back to this spi flash.
                • rgla
                  • Nov 2021
                  • 23
                  Thanks. I don't have a programmer. I just looked into them on Amazon - very affordable but might be above my skill level. If these just plug into the chip and then USB I can probably handle it.
                  Also, I can't find a bios link anywhere on this site or the internet for this MB. From the ch341a I could clear the eeprom and download the info from a link? Is there more to it than that?
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    #29
                    I will fix your native bios for you, I need to look at it.
                    • lotas
                      • Jan 2016
                      • 4708
                      • Russia
                      #30
                      f you are engaged in TV repairs, then it is better to buy the RT809F programmer, with CH341A there will be many problems to correctly program the 25Q40
                      • rgla
                        • Nov 2021
                        • 23
                        thanks Lotas
                        I'm trying to repair a tv I own. But I am learning a lot. I am not a professional.
                        How will you be able to repair native bios from abraod?
                        I will wait to hear from you. Thank you
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          #32
                          First, I need you to post your non-working firmware.
                          • rgla
                            • Nov 2021
                            • 23
                            Well, almost good news.
                            I got a used mainboard. Installed it. Power is on and picture is up BUT half the screen is darker on one side (some faint lines going from top to bottom on left side of screen when screen is black)
                            Also, the remote only turns the TV on and off. No other functions. I tried taking out batteries and holding power button to reset but it didn't work
                            • rgla
                              • Nov 2021
                              • 23
                              How do I know what the firmware version is? is it the version of the TV FCO4?
                              • lotas
                                • Jan 2016
                                • 4708
                                • Russia
                                #35
                                Usually, in the settings for updating the software, you show which version is currently installed.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Best thing to do is add photos, it gives the more experienced members more informed detail of whats happening.
                                  Sadly though sounds like panel fault as well as backlight fault but photos will confirm.
                                  • lotas
                                    • Jan 2016
                                    • 4708
                                    • Russia
                                    #37
                                    If the remote control is for bluetooth, then you must first register the remote control and the TV itself.
                                    • lotas
                                      • Jan 2016
                                      • 4708
                                      • Russia
                                      #38
                                      Before you lost electricity, did Samsung perform well?
                                      And what is your used board from the same diagonal of the TV?
                                      • rgla
                                        • Nov 2021
                                        • 23
                                        Picture is still darker on one half of the screen.
                                        Vertical lines (greenish yellow) on dark half.
                                        tiny horizontal black lines on brighter half of screen
                                        updated Firmware to 1300.3
                                        • rgla
                                          • Nov 2021
                                          • 23
                                          Thanks again
                                          I'll try and answer multiple questions from above here:
                                          Yeah, sometimes I'm dumb. Just had to pair the remote with the TV.
                                          The TV was working PERFECT before the power outage.
                                          I bought the EXACT same board that was in the TV.
                                          I reset when I got the screen up. Half the screen is still darker. Attached photo below.
                                          The backlights seem to be working good. They appear to be the same brightness when viewed from the rear of the TV with back off.
                                          Is part of the used board I got bad?
                                          Internet says bad T-con board causes split screen but I don't think this TV has a t-con board or it's part of the MB
                                          thanks again
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • piposarcade
                                            Samsung UN50KU6300 dead no standby led
                                            by piposarcade
                                            01-04-2024, 01:33 PM
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                            05-22-2024, 02:07 PM
                                            09-07-2024, 05:50 AM
                                          • piposarcade
                                            by piposarcade
                                            Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                            01-04-2024, 12:03 PM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
