Can you dignose from the photo ? . Toshiba 65S2650EV
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4498
    • Italy - Milan
    #101
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    The TP that marks VGL are not all coming from the board, there are almost 5 near the chip that have no trace from the border but appear to come from the output pins of chip, i don't know what they means..
    there's no more chance surely, rip it off..
    ..but.. if you like to waste much time.. i have repaired my only tv with this problem, but not sure it was 100% the same, my had no lines.., so, searching the outer zone of the panel pcb for the 3,3v line that enters the side of the last tab, cut it on the pcb, turn on the tv, maybe image disappears, turn off, re join the broken trace, turn on tv, hope that image reappears, if it doesn't it's a pain.. before doing this must be saved the content of the tcon eeprom, if the inage doesn't come back, reload eeprom with old content.. this op. is risky, i don't suggest it
    • Ancient1
      • 275
      • Israel
      #102
      I don't have eeprom writer, so ..
      "searching the outer zone of the panel pcb for the 3,3v line that enters the side of the last tab," I did take measurements of all TP on the distribution board (earlier photos) , so I can find the TP but you say cut the 3.3 to the 1st TAB I was working on - this I assume signals something to the eeprom ? and it may get garbled - and rejoin the track ?
      Seems complicated.. Looks like ripping the TAB is next
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4498
        • Italy - Milan
        #103
        forget about second method if you have no eprom programmer..
        • Ancient1
          • 275
          • Israel
          #104
          So , time to take the TAB out .. and pray ?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4498
            • Italy - Milan
            #105
            of course
            • Ancient1
              • 275
              • Israel
              #106
              I plan on : low heat ( heat gun ) and slowly peel off .
              sounds ok ?
              but what pray should I say ? would jewish pray be good ? . not funny
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4498
                • Italy - Milan
                #107
                no need of heat...
                • Ancient1
                  • 275
                  • Israel
                  #108
                  So I pulled the TAB out
                  On power connect , something blew on PSU , I think a coil . Burnt through the blanket under.
                  No idea why as I did nothing unusual.
                  Total Loss
                  Thanks a lot for your help ! awsome !
                  • Ancient1
                    • 275
                    • Israel
                    #109
                    by the way :
                    Fuse is blown.
                    Any clue what this : R44 , is ? one end melted
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4498
                      • Italy - Milan
                      #110
                      This is non sense, unless you have done something out of the plans, further that type of piece of wire, i have never seen in years and years of TV studying.., take a photo of the whole board..
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #111
                        Originally posted by Ancient1
                        by the way :
                        Fuse is blown.
                        search Current Limiting Manganin Wire Shunt Milliohm Resistor
                        • budwich
                          • Jul 2015
                          • 3097
                          Total Loss
                          IF the picture of the tab that is shown is how you powered up the set at the time, it is possible that the "half removal" was not a good idea. It should have been totally disconnected.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4498
                            • Italy - Milan
                            #113
                            Contact your electrcian, this fault seems to be due to a surge from the energy distributor or another device on the house cabling
                            • Ancient1
                              • 275
                              • Israel
                              #114
                              Budwich : The TAB was totally removed.
                              vinceroger69 : Thanks ! Is it possible to solder back ? I want to check the Panel at least.
                              Davi.p : The blow up occurred exactly with Wall Power connect. I don't think Power Surge is possible and I have my PC with surge protector in same room - the Surge protector would have "jumped". I don't think the wire resistor was the fault i.e if I change the Fuse and solder this Resistor back the PSU would still not work . You agree ?
                              A TV from Hell. I put so much work time and money in it..
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4498
                                • Italy - Milan
                                #115
                                This problem is not related with work on panel, i can only say this. Have you removed the thin wire from the panel before?
                                • Ancient1
                                  • 275
                                  • Israel
                                  #116
                                  Yes, of course I did. I don't want a wire with electricity floating around.
                                  What a story ...
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #117
                                    Hi not sure about re using the r44 it depends i guess on how much has been lost in total lengh as may alter the resistance. I cant see how removing the tab could of caused it though.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4498
                                      • Italy - Milan
                                      #118
                                      i am waiting for the photos..
                                      • Ancient1
                                        • 275
                                        • Israel
                                        #119
                                        vinceroger69 : Agreed. This is what makes this a TV from hell. I put down the TV same way I did many times before..
                                        In the image you can easily see that the Wire Resistor was cut clean at the VIA.
                                        Thing is, its unlikely it caused the Main Fuse to blow i.e something else is damaged.
                                        Davi.p : What photos ? I am facing a PSU repair issue, and frankly , this took the air out of me.. I don't feel like taking out Mosfets etc , at least for now. I already spent ~$42 on new LED strips ( after I replaced 2 (saw another 2 already replaced), sold, it came back with BL issue, didn't notice Panel issue, was happy - expected to sell at +$150 ..nasty )
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4498
                                          • Italy - Milan
                                          #120
                                          But you are an hobbyist tinkerer like me? So you quit the repair without even searching an used board?
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
