JVC 49cf890 - Fire TV - no picture but sound
  • dskall
    • Oct 2016
    • 2905
    • usa
    #41
    Re: JVC 49cf890 - Fire TV - no picture but sound
    Vone test at the round spot or caps next to it. The other is just fuse designation.
    Vone around 25v. Test both side of fuse with N on it for 12v
    • lotas
      • Jan 2016
      • 4901
      • Russia
      #42
      Originally posted by Dobsuk
      Voffe - 0V
      Vss - 0V
      Cannot find Vone and VCC AVD. Found VONE here but not sure which point to measure:
      Also found few Vcc point but not AVD.
      On this 32V point i have got 0V
      32V is not a dot, this is the designation of a standing fuse ("N" - 32v at 5a)
      • Dobsuk
        • May 2020
        • 127
        • England
        #43
        Vone - 0V
        All Vcc points are with the correct voltage. +- 0.1 but maybe because of my multimeter. For example Vcc_1.6 is 1.7 on my meter.
        1.05 -> 1.1
        1.8 -> 1.8
        3.3 -> 3.2
        • lotas
          • Jan 2016
          • 4901
          • Russia
          #44
          I wrote to you, check, ring all ceramic capacitors with a multimeter for a short circuit.
          • Dobsuk
            • May 2020
            • 127
            • England
            #45
            I did that already. No shorts...
            • dskall
              • Oct 2016
              • 2905
              • usa
              #46
              Vone is important voltage. If it is not there you will have no picture.
              • Dobsuk
                • May 2020
                • 127
                • England
                #47
                So, i checked it few times - it is not there
                • lotas
                  • Jan 2016
                  • 4901
                  • Russia
                  #48
                  Is there tension at these points?
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    #49
                    No - 0V
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      #50
                      Maybe you can list your voltages so we don't have to hunt though posts to figure out what voltages you have and what are missing.
                      • Dobsuk
                        • May 2020
                        • 127
                        • England
                        #51
                        Voffe - 0V
                        Vss - 0V
                        Vone - 0V
                        Vcc_1.6 -> 1.7
                        Vcc_1.05 -> 1.1
                        Vcc_1.8 -> 1.8
                        Vcc_3.3 -> 3.2
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #52
                          There also is an AVVD test point on left side of your main chip.
                          • Dobsuk
                            • May 2020
                            • 127
                            • England
                            #53
                            Excuse my incompetence but i cannot see any AVVD test points
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #54
                              Post #35 first picture between label and caps look like AVVD. If you have no voltage there, I would say you have a bad power chip.
                              • Dobsuk
                                • May 2020
                                • 127
                                • England
                                #55
                                Happy New Year to all. Sorry but I was away for few weeks.
                                AVVD - 1.7V
                                • Dobsuk
                                  • May 2020
                                  • 127
                                  • England
                                  #56
                                  It will be sold as spare. Thank you all.
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • jchang
                                    Samsung UN70NU6900F no picture and no sound
                                    by jchang
                                    Hi all
                                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                    Symptom:
                                    No picture no sound.
                                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                    No sound at all.
                                    What I tried:
                                    1. I tried unplugging the left or right ribbon...
                                    01-09-2023, 06:28 PM
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
