The problem with my TV is very similar to an earlier post but there was no final solution posted.
When the TV is first turned on from cold it will not turn on. The red standby light begins pulsing and a high pitch whine is heard. The back light remains off. If the TV is left trying to boot like this and then turned off and on again a few times then eventually it will turn on and sit there working all day long.
I initially suspected the PSU after spotting this kit for sale,
http://www.ohmsupplies.co.uk/epages/...roducts/KIT229
The capacitors generally look ok and I have however tried swapping a few of them out just in case but it has made no difference. The only thing left would be to swap all the capacitors just in case one is bad but not bulged or leaking etc.
I have now been reading a lot of posts saying the main board is the likely culprit. I have had the main board in the over before at 200 degrees for 10 mins to fix it stuck with the spinning logo and it has been perfect since.
Is there a way to fully test the PSU before throwing money at it potentially unnecessarily changing all the capacitors?
