Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4651
    • Russia
    #541
    Originally posted by pellas
    Works! Thanks a lot! I even managed it using the clothespin.
    Ok!
    • sirjoe
      • Aug 2024
      • 8
      • ITALY
      #542
      Originally posted by lotas
      Try it. Change the program to NeoProgrammer V2.2.0.10, it works more correctly than Asprogrammer with status registers settings.
      Thanks Iotas I will proceed soon! Is there a special procedure with neoprogrammer?
      • lotas
        • Jan 2016
        • 4651
        • Russia
        #543
        No, everything is the same.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4364
          • Italy - Milan
          #544
          For Lotas:
          basically you get the first FFF bytes from a dump of same BN41 board code and insert it into the broken dump? Is this because the rest of dump has some data unique for that model/revision? (same model code can have different panel maybe..)
          For the rest:
          can you check please if you have two components at the very first input of the power board named SA00x and if those are shorted 0 ohms? thanks..
          • lotas
            • Jan 2016
            • 4651
            • Russia
            #545
            [QUOTE=Davi.p;n3340604]For Lotas:
            [QUOTE]
            It all depends on the software version, if the firmware has been updated over the network or via USB, then the data also changes in this 25Q40 and a dump with the old software version will no longer work. The diagonal of the panel does not play a role here...
            • lotas
              • Jan 2016
              • 4651
              • Russia
              #546
              Take a photo from both sides and show what the components are?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4364
                • Italy - Milan
                #547
                ok but from where do you get the correct header without knowing the actual firmware version?
                you have all versions dump and you compare the sane part?
                • lotas
                  • Jan 2016
                  • 4651
                  • Russia
                  #548
                  Yes
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4364
                    • Italy - Milan
                    #549
                    ok now i remember the discussion, spi flash software must pair with main software version.. thanks a lot..
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4364
                      • Italy - Milan
                      #550
                      Originally posted by crystalsound
                      it was definitely original. But the native problem of the tv was not "no standby at all", it was booting with backlight and no image, 4-5 seconds with audio then off and reboot again. I desoldered the 25q40, read it and posted here without doing anything else.
                      Hi, you must put original dump in original eprom, it may be fully ok, my doubt the other one spi flash, the one that contains tcon software, or the tcon power section, or the SOC bga balls, save the other flash, 25x80, write in the one from new board, or get the correct one from some site..
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4364
                        • Italy - Milan
                        #551
                        Originally posted by jaypay15
                        I flashed the bin and register value but the TV is still dead. I read the chip back and the bin was intact. Thanks for your time.
                        For you: can.you read the content of the 24c eprom and post it here?
                        For Lotas: do you have info on version numbers of your bin?
                        i think it can be check the version on the very bottom of settings eprom bin. This is what i remeber, sorry if i'm wrong..
                        • jaypay15
                          • Aug 2024
                          • 6
                          • uk
                          #552
                          It’s strange, but everything should have worked if everything was done correctly, except that it wouldn’t have hurt...
                          I am not sure what to try next.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4364
                            • Italy - Milan
                            #553
                            ....Maybe there's a newer or older version that Lotas does not have...(?)
                            TO EVERYBODY HERE IN THIS THREAD: i suggest you to check the power supply board if you have the 2 surge absorber SAxxx shorted and must be replaced.. i think without this the problem can to present itself again..
                            • lotas
                              • Jan 2016
                              • 4651
                              • Russia
                              #554
                              Write down in detail how you did everything, how you recorded it, what you set in the program, what program you used, and read and post the dump from the chip that you have already recorded...
                              • jaypay15
                                • Aug 2024
                                • 6
                                • uk
                                #555
                                I have just realised my mistake . I loaded the .rar file instead of the extracted one🙄. More haste less speed ,I will try again later.
                                • lotas
                                  • Jan 2016
                                  • 4651
                                  • Russia
                                  #556
                                  Sadly, the firmware file must have a .bin extension.
                                  • jaypay15
                                    • Aug 2024
                                    • 6
                                    • uk
                                    #557
                                    Success , Many thanks Lotas. I feel a bit of an idiot for not noticing my mistake. settings attached
                                    • lotas
                                      • Jan 2016
                                      • 4651
                                      • Russia
                                      #558
                                      Yes, they are set correctly and they need to be written to the chip, this is done after recording the dump.
                                      Status register: 1
                                      S7 (SRP0)
                                      S3 (BP1)
                                      Status register: 2
                                      S14 (CMP)
                                      S9 (QE)
                                      • sirjoe
                                        • Aug 2024
                                        • 8
                                        • ITALY
                                        #559
                                        Unfortunately it doesn't work, now the standby LED stays on, and when I try to turn on the TV it flashes but it can't start. I tried 2 or 3 times to write the firmware but the result doesn't change
                                        • lotas
                                          • Jan 2016
                                          • 4651
                                          • Russia
                                          #560
                                          This suggests that the dump you posted was not original, the dump was not written correctly, or something else was wrong...
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
