Philips 32PFL3008H/12 Remote doesnt work
  • SemDex
    • Apr 2018
    • 9
    • Lithuania
    Hello guys,
    First post here so sorry if ill do any mistakes..
    Got TV for repair, Philips 32PFL3008H/12, Main board VESTEL 17MB95S-1 170912. TV turns on, has image and everything, but there is no response to remote controll. Checked IR receiver - it gave no signal at all. Replaced IR receiver with no luck, still no response to remote, but i got proper waveform when any button is pressed. so far i tried ruling out software - flashed EEPROM / BIOS / NAND, no luck. At this point, when turned on, TV displays message "SHOP MODE", message closes, tv works as intended. It can be somewhat controlled using "button" on the side - you can select channels, adjust volume and select source, but thats it, no way to reach meny or anything else.. maybe anyone around can give any great ideas on what else i could check.. according to service manual, signal from remote goes through 100 ohms resistor straight to CPU - checked, resistor is there, its 100 ohms, got waveforms after it, but still no respone..
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Philips 32PFL3008H/12 Remote doesnt work
    will it go into service mode to see if you can turn shop mode off ?
    https://electro-medical.blogspot.com...vice-mode.html
    • SemDex
      • Apr 2018
      • 9
      • Lithuania
      Press menu button firstly. While main menu is on screen press 4725
      Stuck at this step - TV does not respond to ANY of the buttons on the remote. Forgot to mention - tried with 3 remotes, all known good, two were universal ones for philips TV's, 3rd one was original, but from different TV, original remote which was for this exact tv was lost long time ago
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        https://www.philips.co.uk/c-f/XC0000...reen-shop-mode
        • SemDex
          • Apr 2018
          • 9
          • Lithuania
          Well, all of their suggestions starts with "press button on remote", which sadly, doesnt work..
          • vinceroger69
            • Mar 2012
            • 6714
            i wonder if the mainboard is for a diffrent brand tv hence the remote may not work but as you have tried changing the software it should of rectified the issue as this mainboard is used in bush and toshiba etc branded tvs
            • SemDex
              • Apr 2018
              • 9
              • Lithuania
              I tried to go for motherboard replacement, but accidentaly got wrong revision of the board (Rev 2.1 instead of Rev 1.0), so with panel connected it bootloops (even though according to seller it is for same exact TV), but oh well. Whats interesting, i tried turning it on / off with remote also, and it wasnt reacting to remote aswell. (Well, might be that it had different pinout i guess). My current question would be - is there a chance that TV is "bound" to one specific remote model so none of other remotes work?
              And also, is there anything specific about IR receiver for such tv's, or they are pretty much standart ones ?
              • lotas
                • Jan 2016
                • 4649
                • Russia
                IR receiver
                • vinceroger69
                  • Mar 2012
                  • 6714
                  Have you got a all in one remote you could try the type that self scans until it finds the code for your tv
                  • SemDex
                    • Apr 2018
                    • 9
                    • Lithuania
                    Sadly dont have such one, dont even know if it exists im my country, at least cant get one in shops which sells TV's and accesories
                    • kalauzz
                      Philips 47PFL5028K/12 - Remote Control repair help
                      by kalauzz
                      my remote control for my beloved TV (Philips 47PFL5028K/12) is no more working.
                      Codes of the remote should be :
                      PHILIPS 996590004895, YKF314-005
                      It's blinking endlessy when I insert AAA batteries.
                      Checked cap seems ok, the transistor (i think is that) seems good
                      IC not checked.
                      I thought also to a stuck key.
                      I switched cap and seemed to be ok but it restarted blinking endlessy again..
                      May the IC fail if battery polarity is inverted? because my son told me he did that ...
                      The schematics...
                      09-08-2021, 08:26 AM
                    • cstout
                      DeLonghi AC Remote only accepts 3V
                      by cstout
                      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                      I can't find any schematics...
                      06-03-2024, 03:53 PM
                    • hollox123
                      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                      by hollox123
                      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                      1. Laptop keyboard doesn't work
                      2. The backlight on the laptop keyboard doesn't work
                      3. The x2 side LEDs (red) on the laptop don't work
                      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                      But I am strongly aiming that it is somehow a BIOS-related problem,...
                      05-11-2025, 08:05 AM
                    • Ierwin
                      Philips 58PUS7805 Menu working but no/weird picture from video sources
                      by Ierwin
                      I got a 58pus7805 that shows some weird behavior.
                      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                      I managed to install the latest official firmware by holding the control button while plugging...
                      03-10-2024, 12:50 PM
                    • jesterace
                      Samsung B2030HD IR Remote Receiver Dead, shorted micom?
                      by jesterace
                      I have this TV a small 20 inch that works perfectly except for the IR has stopped. I have confirmed that the remote control is fine and tried an alternative and even tried with IR blaster from phone. Remote 100% ok.
                      Tried installing latest firmware but no change.
                      TV won't respond to remote at all, not even to bring it out of standby. I have to use the touch sensitive front panel to operate, at which point TV is usable albeit with no remote.
                      Tried replacing the IR receiver diode/bulb on front panel and no change so put the old one back. After tracing...
                      10-26-2022, 02:20 AM
