Samsung un49mu7000f dead no power
  • steven91919191
    • May 2020
    • 15
    • United Kingdom
    #61
    Originally posted by lotas
    What's the problem? Is the standby LED on? Does the backlight come on when you disconnect the motherboard from the power supply?
    Hi Iotas,
    Are you still active here? Our TV backlight works with MB disconnected. I can upload from eeprom for fix maybe?
    • lotas
      • Jan 2016
      • 4614
      • Russia
      #62
      Originally posted by steven91919191
      Hi Iotas,
      Hi, I'm still here, post your original dump here, I'll check if that's the problem.​
      • steven91919191
        • May 2020
        • 15
        • United Kingdom
        #63
        I tried to read it but says device disconnected or defective so i cant read it! New MB need to order
        • lotas
          • Jan 2016
          • 4614
          • Russia
          #64
          How do you read dump, using a clothespin or through an adapter, which programmer, post a photo of how it is connected to your programmer...
          • steven91919191
            • May 2020
            • 15
            • United Kingdom
            #65
            Its on a CH341A (ive flashed loads of BIOS with it) - just this one doesnt want to read. Dont use the clip or anything, always desolder and solder to the programmer board
            • steven91919191
              • May 2020
              • 15
              • United Kingdom
              #66
              The chip actually gets hot while reading too on the PC. I switched it to 3.3v and still cant be read
              • Diah
                • Feb 2013
                • 6376
                be sure you installed the chip in correct way... pin 8 should be at 3.3V
                • steven91919191
                  • May 2020
                  • 15
                  • United Kingdom
                  #68
                  Here it is
ID:	3560581Click image for larger version
                  • Diah
                    • Feb 2013
                    • 6376
                    if it at time installed at MB didn't get hot,,, i will prefer install it back and use clip.. other wise it will be expensive repair
                    • lotas
                      • Jan 2016
                      • 4614
                      • Russia
                      #70
                      Turn the adapter 180 degrees.
                      • steven91919191
                        • May 2020
                        • 15
                        • United Kingdom
                        #71
                        I dont have clip for this. This is an old programmer. I do have new MB coming tomorrow would like to repair this and then return board
                        • steven91919191
                          • May 2020
                          • 15
                          • United Kingdom
                          #72
                          Such as this??
                          • lotas
                            • Jan 2016
                            • 4614
                            • Russia
                            #73
                            Yes! If you haven't burned the chip yet!
                            • Diah
                              • Feb 2013
                              • 6376
                              lotas have right turn the the plate 18ß degree
                              • steven91919191
                                • May 2020
                                • 15
                                • United Kingdom
                                #75
                                Okay the pads on the adapter was slightly broken. Only missing about 1mm or less! I have jumped it and got the dump now Sorry!
                                • lotas
                                  • Jan 2016
                                  • 4614
                                  • Russia
                                  #76
                                  Try it, don’t forget about the register status (0x88, 0x42) after writing the corrected dump.
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    fly out ... lotas will do it
                                    • steven91919191
                                      • May 2020
                                      • 15
                                      • United Kingdom
                                      #78
                                      Thank you. I will try in 15 minutes when I'm back home. Can you clarify what you mean by register?
                                      I have colibri or neoprogrammer. Or I can download another if necessary of course
                                      • lotas
                                        • Jan 2016
                                        • 4614
                                        • Russia
                                        #79
                                        Yes, neoprogrammer is exactly what you need for this.
                                        In the program:
                                        1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                                        2. Click "Unprotect".
                                        3. Click "Clear IC" and "Yes".
                                        4. Click "Open File" and select your corrected dump.
                                        5. Press "Program IC" and "Yes".
                                        6. Click "Verify IC".
                                        7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE and press "Write" and "Yes"
                                        7. Close the program. Ready.​
                                        • steven91919191
                                          • May 2020
                                          • 15
                                          • United Kingdom
                                          #80
                                          In the program:
                                          Thank you for this. My status register #2 is set to 40 (I cant change it or select QE box). The write button is greyed out
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
