ViZIO M70-D3 Completely Dead (Weird!)
  • goofykao@yahoo.com
    • Sep 2021
    • 3
    Hi, Just joined this forum hoping to fix this TV.
    Sorry for the long post to explain the problem in details.
    Model: VIZIO M70-D3, 4 years old
    What happened: TV had no issue at all and one day just died (4 weeks ago) and NO LED stand-by light (usually it's Red at bottom left front side)
    Current status: Cannot power on and NO LED stand-by light
    Strategy: Since I am not good at fixing boards at component level, it's better for me to just replace boards with known good ones
    Trouble Shooting History:
    1. Ensured the power connection was good and full battery in the remote control
    2. Followed all possible procedures to power-cycle the TV
    3. Purchased identical Power Supply, Main, T-Con boards from TVPartsToday and tried all possible combinations between old and new ones
    4. Kept logs of voltage measurement while swapping boards and all readings are the same, e.g., old and new boards behaved the same way
    5. While performing all these trouble-shooting, TV power and stand-by LED has never been ON (dead all the time)
    6. Used magnifying glass to visually inspect old and new boards and found no difference (at least appearance are identical and no indication of damage)
    Voltage measurement data (values are identical between old and new boards):
    1. Power board (09-70CAR0C0-00): Both old and new ones behaved the same.
    Isolated:
    -AC-DET: 4.36V
    -PS-ON: ~0
    -16VS: 16.2V
    Connected to main board:
    -AC-DET: 3.95V
    -PS-ON: ~0
    -16VS: 16.2V
    PS-ON no change while pressing remote or power-on button
    2. Main board (Y8387242S): Both old and new ones behaved the same.
    -USB port has 5V but it won't charge an iPhone (used it to test the power)
    -There is 3.2V to the stand-by LED but LED is not lit
    -Optical port has NO light while trying all old and new board combination
    3. T-Con board (RUNTK0151FVZZ): Both old and new ones behaved the same.
    -Tried disconnected from main board and attempted to power on TV but not working
    Possible explanation: The new ones from TVPartsToday are also BAD (in the same way). But what are the odds??
    Any help is appreciated!! Thanks.
  • R_J
    • 9632
    Re: ViZIO M70-D3 Completely Dead (Weird!)
    If you tried the Power supply, main and T-con, that leaves the panel itself, try disconnecting the panel from the T-con and see if the TV turns on.
      • Sep 2021
      • 3
      Thanks a lot for the help!
      I followed your instruction and the TV turned on!!
      Please advise what I can do next. Thanks!
      • nickgronk
        • Apr 2021
        • 32
        There should be two ribon cables, 1 on either side of the TCON (left and right side of panel). I suggest unplugging 1 side, trying to turn the set on. Vice versa. If you get a picture on one side, there is a problem with the panel - let us know how you make out. If its only a bad TCON then thats an even simpler fix. Cheers
        • carlosemarin
          • Nov 2021
          Did you finally identified what was the problem? I got exactly the same symptoms with my TV. 4 years and boom... dead. Thanks
          • frannyjunk
            • Oct 2010
            • 82
            I have the Vizio M60 C3 which is dead. No power whatsoever. Upon opening the back cover, I noticed 4 bulging capacitors. I will be replacing these capacitors today when the new ones arrive. According to a YouTube post, that should do the trick.
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • howardc64
              Vizio SmartCast TV software bug that looks like hardware
              by howardc64
              Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
              It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
              11-16-2024, 05:17 PM
            • Novabeau 2
              Vizio e55u-d2 55 inch tv service manual & schematic
              by Novabeau 2
              Hello everyone, I'm trying to find some service manuals or schematics for a vizio e55u-d2 55 inch tv that just conked out the other night. It has no power whatsoever.
              Have tried all the reset process that vizio had.
              Any Insight to this would be great and appreciated. If you all think it's not cost prohibited to fix let me know. known thank you and have a wonderful day.
              04-21-2025, 05:50 PM
