RCA RTU5540-B, flashes once - no backlight
  • Noobwithamultimeter
    • Apr 2021
    • 94
    Found this TV more than a year ago, got it to turn on on my first try and thought wow - what a good score. Played around with it a bit more and discovered a power fault where I would turn it on, it would flash once and the image would be there but no back light. A solution was to try to force powering it on by unplugging it, plugging it back in and when it finally stayed on I would leave it on 24 hours a day on lower backlight setting.
    After about 6 months of this I thought I should try fixing it permanently so I watched some youtube videos and someone suggested to look at your transformers for solder working their way up the legs of the transformers. I looked at mine and tried the idea, dropping about 5 fresh drops of solder on the joints that looked funny to me. To my delight the TV turned on INSTANTLY without issue and I was using it normally for the last 5-6 months.
    The issue unfortunately re-emerged and I trust it is LED-strip related entirely and the only thing I succeeded in was establishing a better connection which resulted in success in powering on the tv. Now that an LED or two have burned out since, I cannot power on the TV again.
    I started this thread as there is only one other topic with this model, I assume people are not yet having problems with them since it is a 2017 model. I don't want to assume anything being the problem, just wanted to put this out there in case anyone had any ideas as to what else it might be.
  • neilc6
    • Nov 2015
    • 1550
    Re: RCA RTU5540-B, flashes once - no backlight
    RCA TVs that turn on with no backlight or flash of backlights have bad backlights. Backlight level can only be set in the service menu and standard picture mode runs them at 100% causing to burn out around the 2 year mark after the warranty has run out. New strips are impossible to find even from Chinese suppliers. Don't touch them anymore unless they end up in front of my house for free.
      • Apr 2021
      • 94
      I was running mine at 45 out of 100. Even that wasn't low enough to save it. What a scam.
      • neilc6
        • Nov 2015
        • 1550
        RCA TVs are white label TVs which I believe are manufactured by Skyworth and sold under a number of brands including Westinghouse and Proscan. Skyworth is producing lower end TVs for both LG and Samsung now. They have a similar chassis style as the RCAs, are made in China vs assembled in Mexico and have a bit better build quality than RCAs.
        The one feature of RCA TVs is lower price and you get what you pay for. Picture quality is decent since there are only a handful of panel manufacturers. All brands have LED failures. You could pay a lot more a Samsung or Sony and still have backlight issues after 2 years if you put your TV in Dynamic mode.
          • Apr 2021
          • 94
          Yeah that panel is ok, I may resort to an experimental repair using all good LED strips from a broken screen 50". I will post pictures if I go that route
          • neilc6
            • Nov 2015
            • 1550
            Think I repaired the LEDs in that model and they kept on burning up even with the backlight level turned down. Ended up ordering 2W LED modules and replacing all the LEDs in the bad strip.
              • Apr 2021
              • 94
              Wow. What a tedious job. I don't envy that work.
                • Apr 2021
                • 94
                Well I unscrewed the back of this TV and let me tell you - this is the easiest back removal I've ever encountered. I placed the set face-down on my table and unscrewed all the screws, simply pulling the back off containing the LED strips in one piece. I didn't even have to handle the delicate LED panel or diffuser sheets once! Whew! Now I'm happy no damage or dirtying will occur to the panel whatsoever.
                  • Apr 2021
                  • 94
                  I just tested 12 leds in a row and they are all working. Also I see no burned looking or black ones. Could it be something else preventing the tv from coming on? Like the EEPROM?
                    • Apr 2021
                    • 94
                    I'm onto something here, just powered up the TV and saw that ONLY the left side illuminated for a split second, then turned off. It looks like ALL the LEDS are fine! So there is something wrong with the driver for the right hand side for some reason...
                      • Apr 2021
                      • 94
                      Switching the power connector from left to right exhibits the same problem, (left side still turns on for a split second) so it appears there is something in the right hand set of LEDs that's preventing them from turning on...
                        • Apr 2021
                        • 94
                        So I can confirm that EVERY single LED lights up. I took a video of each side, slowed it down and then watched it for each side of the tv, one connector at a time. The problem it seems is the ability for my power board to deliver enough power to turn on both sides simultaneously. I am confident it needs a new power board, or possible repair (not likely since I'm a noob)
                          • Apr 2021
                          • 94
                          Whatever was preventing it from turning on, after re-connecting everything it seems to be resolved! The TV is now working! However, I will never turn it off again for fear the power board is on it's last days, and also because LED strips always burn out leds the instant you power them on just like light bulbs, soooo...
                          • tech9pc
                            • Sep 2021
                            • 49
                            I have the same one. Same problem for about a year now .... grey screen when turn on sometimes. If I leave it on for about 8 hours straight the next time I turn it on it works fine. If I shut it off in a period of less than 8 hours I have to unplug it 2 or 3 times to get it back up. I know it would not be the power supply, panel or mainboard because it works like a dream when on and is a great 4K tv with excellent picture. So it has to be either the t-con or led strip causing the power on display glitch. I have held off on ripping it apart ... but have not found a solution either.
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • DanPoka
                              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                              by DanPoka
                              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                              02-15-2025, 05:05 AM
                            • ItepK
                              LG 32LG3000 TV, three red light flashes, then the backlight turns on, but no picture
                              by ItepK
                              Hello everyone! I've found this television, and I began troubleshooting it.
                              First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
                              I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
                              After the recapping, all the voltages stableized, however, the issue in the title still remains.
                              I could...
                              01-03-2025, 09:01 AM
                            • Comp_Pro
                              No Backlight Macbook A1990 820-01041
                              by Comp_Pro
                              Hello all,
                              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                              Tests performed:
                              There is no backlight even with a good screen.
                              Backlight IC is receiving the correct support voltages.
                              Fuse F8400 ok
                              Current sense resistor R8400 ok
                              Backlight IC is receiving 3.3V on enable pin.
                              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                              Backlight IC receiving 5V from PP5V_G3S
                              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                              05-06-2024, 10:23 PM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
