Samsung UN55MU6290 Boot loop
  • anupkg1985
    • Sep 2020
    • 180
    I have got Samsung UN55MU6290 UHD tv which is not powering on. When plugged in backlight comes on and then goes off in an about 10 seconds and it keeps happening. No video on screen at all. I checked backlights with BL tester and all looks good with BL. When measure voltage on main caps it jumps from 390v to 362v and rises again and keeps cycling. Below are the reading when mainboard connected to power board -
    Pin | Signal Voltage Reading
    1 | Fail Count 3.3 V
    2 | ANA DIM 0.99 V
    3 | A13V 12.8 V
    4 | OD On-OFF 3.3 V
    5 | A13V 12.8 V
    6 | PWM BLU 3.3 V
    7 | A13V 12.8V
    8 | Power ON 3.3 V
    9 | A13V 12.8V
    10 | GND
    11 | GND
    12 | GND
    I suspect the defect with main board as backlight keeps on when mainboard is disconnected. Could you help me to diagnose the exact issue?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4291
    • Italy - Milan
    Re: Samsung UN55MU6290 Boot loop
    Bad leds 100%
    • brucetv
      • May 2015
      • 281
      • united states
      My guess is a short on the lower panel driver boards. Check all resistors, diodes, and caps especially on the board all the way on the left facing the back. Unhook one ribbon cable at a time and see if it stops boot looping. If it does you found which side your short is on. The MU series is notorious for having shorts on the panel driver boards. Samsung's quality has gone down hill since 2017.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4291
        • Italy - Milan
        Sorry not 100% my mistake, 50% panel boards, 50% leds, just to clarify, neither BL tester nor mainboard disconnecting are safe testings, cause only when m.b. is connected it starts with full brightness and this built problems that in these new Samsung become a restart...
        • anupkg1985
          • Sep 2020
          • 180
          Thanks for the information. After disconnecting right side ribbon to panel driver board I get the stable backlight and no more reboot. However I was expecting half of the picture on the screen but its fully dark/blank. Could thus be panel issue or expected? How should I proceed now?
          Update- It doesn't matter which side I disconnect, reboot stops by disconnecting either of the ribbon. One side has small IC on the driver board while other does not.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4291
            • Italy - Milan
            So it is a shorted cap on the panel's boards, then test all the bigger ones with the best ohmmeter you have and watch those that have less ohms also decimals, this if it is readable a short, then remove those with less ohms and test them outside..
            • anupkg1985
              • Sep 2020
              • 180
              What should be the expected value for good caps and what range of readings should be considered for short caps?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4291
                • Italy - Milan
                not shorted caps is high ohms (maybe kohms) or open, shorted ones around zero.
                • anupkg1985
                  • Sep 2020
                  • 180
                  I tested all the caps however most of them are above 5k. Only one near the dc converter IC, C75 reads 1.1k ohm. Doesn't show continuity however if set is turned on then show continuity on this cap. Could this be culprit?
                  Update- Vdd voltage on the driver board is not stable it jumps from 3.3v to 2.6v and back if both sides are connected. If right side ribbon removed then its stable on left side.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4291
                    • Italy - Milan
                    sorry i forgot to mention there possibly be some diode packs on the far side of the boards, check them and also the resistors connected to them, i feel the vcc rail doesn't previews possibile problems with caps..
                    • anupkg1985
                      • Sep 2020
                      • 180
                      I checked all caps on the right side and none of them falls below 1.5k also the resistors most of them are reading OL or in k ohms.
                      If I block pin 3 on the ribbon which connects to VDD33 on the right side then set stays on but no picture. Could this be panel issue?
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4291
                        • Italy - Milan
                        Never disconnect vcc alone.. possible damages so.. the short can be of the non explicit type so connect all up and test the voltage on AVDD test point or the bigger caps, are there some caps that doesn't present a voltage?
                        • anupkg1985
                          • Sep 2020
                          • 180
                          Voltage is not stable on all the VDD test points, it measures from 1.8 v to 0.32v and jumps back.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4291
                            • Italy - Milan
                            Not VDD, i say AVDD but in this set it is caled VAA,i see now..
                            • anupkg1985
                              • Sep 2020
                              • 180
                              Voltage is fluctuating on VAA test point from 8v to 0.012v, its very hard to measure as it's fluctuating very fast up and down. Also most of the points like HVAA have fluctuating voltage. There is no voltage present on VAA point if I remove right side ribbon.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4291
                                • Italy - Milan
                                Now if you have a bench power supply or a dc-dc regulator with current control i tell you what to do..
                                • anupkg1985
                                  • Sep 2020
                                  • 180
                                  I don't have current control power supply, only I have is DMM and LED tester. However what is the next step with power supply?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4291
                                    • Italy - Milan
                                    Don't wait until you find a power supply, so if you have an hot air station remove one by one the condensers on the VAA rail and retest each time until you find the one that blocks the supply rail...
                                    before doing this watch carefully at the magnifier lens each condenser and see if one is slightly different from others, then start remove that..
                                    • anupkg1985
                                      • Sep 2020
                                      • 180
                                      Thanks for the your patience and help. I'm not professional so don't have most of the equipments. I have soldering iron and removing smd caps it bit complex with that, however I'll try. I'm curious about the Power Supply stuff, that would be new learning for me.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4291
                                        • Italy - Milan
                                        the technique with PS is to feed current slowly increasing and feeling the heat on suspected components ( caps)
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
                                        • signedupfordownload
                                          Samsung UE49KU6500U boot loop
                                          by signedupfordownload
                                          My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                          With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                          I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                          07-29-2024, 01:56 PM
