50t32-soc xl bd short
  • SsimoR
    • Apr 2020
    Hi everyone.
    I have a 50" Toshiba tv that's showing vertical bars. I checked the t-con voltages and got vgh 24V and vgl -10V anyways I changed it with a good working t-con. I still have the same issue. I checked 50t32-soc xl bd and found a 100ohm resistor fried so I changed it. started the tv and it worked and I can see the logo...... but in a couple of seconds the same resistor got burned. I checked the rest of the resistors and capacitors, transistors and they're all seems to be good...Any idea what else can I do to try and solve this problem? Thank you!
  • SsimoR
    • Apr 2020
    Re: 50t32-soc xl bd short
    It's ok, I got it fixed. Tv is up and running great!
    • skynetronics
      • Mar 2016
      • 12
      • Chile
      Hey mate, what you did to solve the problem?
      I have the same R075 (100 ohm) open. The other components seems normal (transistors, capacitors, etc).
      PS: I'm from Chile and the problem is in an AOC, model LE50U7970, same panel with the same symptoms.
      • zinzin54
        • May 2022
        • France
        I see you have the same problem as me. I have the 100 ohms resistor which is open, R082 on the 50T32-SOC XR ( the other board). So i change it but the problem is the same. I haven't time to investigate more. I think to see again this week-end. SsimoR solved the problem. Could you tell how you solved it please ?
        Thank you.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You got to love when people don't post how they fixed a problem.
          So remove that resistor check from shorted pad and locate shorts then remove one at a time until short goes away.
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            https://youtu.be/ht1VBTlzbUo
            • Elmano Gamela
              • Dec 2021
              • Moçambique
              I have the same problem, R075 keep burn after change. Help please
              • lotas
                • Jan 2016
                • 4787
                • Russia
                Remove the diode assembly D004 and R075 will no longer light up.
                • Makado
                  • Mar 2024
                  • South Africa
                  Thanks guys i managed to fix my Hisense TV
                  • gaelican
                    Asus ROG ga401IV motherboard - AC Short Protection resistor getting hot
                    by gaelican
                    I am working on an Asus ROG laptop repair. I was able to find that there is a short on the motherboard, and the 20 volts from the charger only gets to the first mosfet before disappearing.
                    When looking around with a thermal camera, I noticed the chip marked "14C" in the picture was getting warm. Nothing else was receiving heat.
                    I found a boardview diagram and schematic for a motherboard that looks nearly identical, that has the same component. This appears to be marked as "AC Short Protection" with a value of 13.7KOhms.
                    02-21-2025, 01:51 PM
                  • CapLeaker
                    Happened again. Resistor go short!
                    by CapLeaker
                    That's now the second time in my repair career that a through hole resistor go short!
                    it was a Vishay CPF124K900FHB14 1W resistor measuring new 24.9kohm. <- notice the KILO ohm. Well now it measures 28.1 Ohm! See picture and PDF attached. This is something very rare happening, but apparently it does happen!...
                    07-07-2025, 03:20 PM
                  • angelos
                    Hisense LCD42W60P Television
                    by angelos
                    Hi Guys,
                    I have this 2008 lcd tv that uses ccfl lamps. The tv is stuck on standby. This is what I have noticed. The standby 5Vs voltage is not 5V but rather 3.28V. There is a 14V rail as well but that measures ok. I put my volt meter on the 5Vs rail and switch on the 220Vac. I noticed that the 5Vs rail goes to 5.1V and quicky changes to 3 28V and steady.
                    I unplugged the main board and ccfl lamp wires and tested the power supply separate from the tv without load and put a 470 ohm resistor to the stby rail to force the tv on.
                    1. Pfc circuit activates and mains smoothing cap is...
                    07-12-2025, 11:44 AM
                  • DynaxSC
                    Extreme High Current & Low Voltage Short Killer ??
                    by DynaxSC
                    Hi Folks
                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                    After taking off the socket, the shorts dissappear again.
                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                    10-15-2024, 10:13 AM
                  • jinu_j
                    by jinu_j
                    Hi
                    05-03-2025, 10:51 PM
