Horizontal lines LG 49UH668V
  • NoobieTVrepair
    • Aug 2021
    • 10
    http://imgur.com/a/NcZBzgT
    Can get this for £40, would it be worth fixing it
    Could it be a simple LED strip change or is it most likely a bigger issue with the LCD panel?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4451
    • Italy - Milan
    Re: Horizontal lines LG 49UH668V
    Bad panel, not surely fixable.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ihandyrepair
      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
      by Ihandyrepair
      Hi guys
      I just started fixing 4k TV few months ago. so I am still learning a lot
      I got this tv from friend complaint is ghosting or horizontal lines on image.
      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
      then it started to show the ghosting white image.
      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
      it has 3 thin small boards at the bottom of the...
      12-05-2022, 04:18 PM
    • ggil44
      Sony XBR-65X750D Horizontal lines bottom of screen
      by ggil44
      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
      05-30-2023, 07:51 PM
    • x_orange90_x
      Samsung UN46C8000XFXZA Horizontal lines
      by x_orange90_x
      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
      07-15-2023, 05:06 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
