Samsung UE40D5000 power board - 9.4V on B13V
  • NoxiousPluK
    Generic nerd
    • Aug 2021
    • 3
    • Netherlands
    I'm strugling today with trying to fix a UE40D5000 power board.
    A5V gives a nice 5V, B5V and B13V stay off until I short A5V to PS-ON, so far so good.
    B5V comes up as a nice 5V as well but B13V gets me 9.4V max.
    Also backlight doesn't get power, those pins stay at 0 even if I put 5V on BLU_ON (measuring across CH1+ and CH1- on CNL802).
    After turning on PS-ON, I see about 165VAC going into TM801S; I'm not sure what voltage I should see there.
    The caps next to CNL802 get 96VDC, which seems too low as well since CNL802 should be 268V. These caps are all in parallel.
    I'm suspecting the input voltage to TM801S is too low, but I can't find what I should measure on the in- and outputs of this transformer.
    Suggestions welcome, thanks a lot in advance!
    Attached the circuit diagram for this specific board.
  • lotas
    • Jan 2016
    • 4743
    • Russia
    Re: Samsung UE40D5000 power board - 9.4V on B13V
    When switching to operating mode, what is the voltage at the PFC output?
    Should be around 400v DC.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4451
      • Italy - Milan
      Try change ICM851 and PCM803, if doesn't work change ICM801, i guess you have correct 400vdc on PFC out. You cannot measure AC on TM801 because its a square wave
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What voltage do you have at each side of inductor L9801
        • NoxiousPluK
          Generic nerd
          • Aug 2021
          • 3
          • Netherlands
          I measured across CP803S because that should be the same voltage right? I get 320VDC both with and without PS-ON shorted to A5V.
          Would that indicate something to be wrong on the hot side? I'm surprised the A5V is exactly 5V then tho.
          I might not have the correct voltage on PFC out, see above!
          I'm not sure where to probe for this; see attached images.
          Thanks so much already
          • lotas
            • Jan 2016
            • 4743
            • Russia
            Yes, your PFC does not work.
            PFC is not related to STB 5v.
            In the standby power supply, the PFC does not work and the output should be 320v, when switching to the operating mode, the PFC should give out about 400v.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4451
              • Italy - Milan
              I tell you the following test, retest PFC out but right after test for the B13v, i suspect your ON command was not ok. 5V are stable because them are took from standby ps through a mosfet. If pfc again is low check M_Vcc, must be maybe something around 5-15v, if present replace ICP801
              • lotas
                • Jan 2016
                • 4743
                • Russia
                What is the voltage across the CP811 capacitor?
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                  09-07-2024, 05:50 AM
                • Nicktronic
                  Samsung Power Supply Board BN44-00874F
                  by Nicktronic
                  Hey everyone,
                  This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                  Anybody...
                  03-17-2025, 06:20 AM
