Vertical bar stuck on TV Screen, AKAI AKTV434 UHD Smart
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Hi, I've got a weird case on a television. Backlight turns on and there is audio however screen slowly fades in with all different colours and weird vertical bars. I suspected the T-CON (Part number: HV430QUB-N4A) and so I went ahead and disconnected one side of the screen and left the other connected, after trying both ways the artifacts still seem to be there (in fact they got worse with one side disconnected). To me this indicated a T-CON problem not an LCD problem however after disconnecting both LCD ribbon cables from the T-CON only leaving the backlight connected is saw this (Image below). It seems as if a column of pixels got stuck partly open? Any ideas if this is fixable or what to do next. At this point I'm suspecting a bad T-CON and an LCD with a burnt-in column. I'd also like to mention that when the tv was fully assembled, this column would shine bright once the tv powers on (maybe bad T-CON caused this section to light up and previous owners left it on like this for a long time and it got burnt in? I don't think it's one of those two thin LCD boards as when I touch the ribbons on them I get no response.)
    There is a lot of reflection on the bottom left side of the image, please ignore that.
    Thanks in advance.
    • 21592
    Re: Vertical bar stuck on TV Screen, AKAI 42 inch
    TV model number ? https://www.badcaps.net/forum/showthread.php?t=24661
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      It's an AKAI AKTV434 UHD Smart. sorry about that.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Re: Vertical bar stuck on TV Screen, AKAI AKTV434 UHD Smart
        Certainly bad Tcon, also your screen could be partially damaged but there's no way of knowing that without replacing the Tcon first.
        A working TV? How boring!
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • praveenramavath
          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
          by praveenramavath
          Hello All,
          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
          https://www.hifivision.com/threads/m...-screen.98243/
          Troubleshooting Summary: Majority Internet Radio - Flash Chip
          04-26-2025, 09:08 AM
        • BMCappelletti
          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
          by BMCappelletti
          Hi everyone.
          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
          02-18-2025, 12:22 PM
