Help with LKP-0P023 REV0.3 PSU
  • cheeky2
    • Dec 2012
    • 337
    I am trying to identify D7 on this power supply board that Q5 MDF9N50 mosfet R53 22ohm and R54 47 ohm and the IC2 FAN7930 have all failed. I have managed to work out these from looking on the internet.
    However D7 I have seen no mention of the value of it so anyone with one kicking around could you let me know the designation of the markings on it please?
    Hopefully someone has one laying around that can give the value of it.
    I know ohms supplies have a kit056 for it however for the price of the kit I can get a whole working unit delivered for less!
    I have all the other failed components available besides the D7 I suspect it may well be a 1N4148W diode but just wish to ensure I get it right!
    Just noticed the R57 0.15ohm has also gone as well (not surprising really).
    Thanks in advance for any help.
    See attached pictures of location of the diode (at least what's left of it!).
    Regards Anthony
  • lotas
    • Jan 2016
    • 4651
    • Russia
    Re: Help with LKP-0P023 REV0.3 PSU
    According to the datasheet on FAN7930 there is a diode just 1N4148 (W) marking (A2, T4), so put it on and don't worry.
    • cheeky2
      • Dec 2012
      • 337
      Thanks for that I thought it was a 1N4148W diode but couldn't find any sheets that related to it with the FAN7930. I will give it a go soon as just have found a 2watt 0.15watt resistor to replace the R57 that was open circuit.
      • cheeky2
        • Dec 2012
        • 337
        For anyone interested here are a few of the parts that blow on these psu's:
        F1= T3.15A slow blow
        R1= 4.7 ohm
        R52=680 Ohm
        R53= 22 ohm
        R54= 47 ohm
        R56= 10k
        R57= 0.15 Ohm suspect 3Watts
        IC1= GR8876A Substitute using LD7575
        IC2= FAN7930C though you can use any variant ie FAN7930B
        Q1= 2N3906
        Q5= MDF9N50
        Q6= JCS2N65F
        R35= 0.3 Ohm suspect 2Watts
        D7= 1N4148W
        If I find anything else then I will update the list.
        • cheeky2
          • Dec 2012
          • 337
          Finally repaired this psu as also Q2 had also gone as well.
          So parts list for anyone interested is as follows:
          R1= 4.7 ohm
          R52=680 Ohm
          R53= 22 ohm
          R54= 47 ohm
          R56= 10k
          Q1= 2N3906
          Q2= PMBT3904
          Q5= MDF9N50
          Q6= JCS2N65F
          D7= 1N4148W
          • elviramjw
            • Apr 2013
            • 56
            Looking for values of r31, r32 and r33 on this lkp-op023 pcb
            Around IC1
            Thnx
            • cheeky2
              • Dec 2012
              • 337
              Just checked I did take some pictures of the area when repairing the psu when checking out the resistors for possible failure so you may well be lucky with the images.
              The power supply has now been sold so I can no longer check on the psu.
              • jaycee1980
                • Sep 2011
                About to do one of these myself.. the 68uF 450V primary cap was bad, F1 and R57 are gone, not sure about Q5. IC1 seems to have survived (at least the top hasnt blown off of it!)
                I'll be checking the rest of the supply works first - i have a 100uF 450V capacitor, and this first stage is a PFC so it can be bypassed. If the rest of the PSU is shot, there isn't much point in attempting a repair I think.
                I wish they'd build protection into PFC controllers so that if the cap fails, they dont just drive the MOSFET on hard, causing this type of failure! So bloody common...
                • jaycee1980
                  • Sep 2011
                  Sure enough by bypassing the PFC, this one appears to work ! Q5 is dead though, and I found R53 was open so I suspect the PFC chip has bought it as well (just didn't blow its top off)
                  If anyone wants to try bypassing the PFC to see if the rest of the supply works, do the following:
                  Remove R57, Q5, L2, D1
                  Remove R22 (might not be needed, but best to keep the PFC out of it if the chips still there)
                  Fit wire links at J3 and D2
                  Oh, and fit a new F1 and E2 - this is usually why the PFC exploded in the first place ! Bloody CrapXon junk!
                  • cheeky2
                    • Dec 2012
                    • 337
                    Thanks for that information if I ever have one of these go again I will try it out.
                    Originally I just used a cheaper used different model psu I believe it was a Technika psu model that had all the outputs for a third of the cost of these psu's. As the ic for the repair was coming from china so the wait would have been too long and had it lieing around getting dusty for me to repair when I had the time!
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • unimatrix93
                      TV backlight zener diode
                      by unimatrix93
                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                      The led strips has 9 6V leds.
                      02-10-2025, 12:13 PM
                    • NicRac
                      monowheel repair,Is the diode the problem?
                      by NicRac
                      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                      First of all, I am new here. Therefore I will shortly introduce myself.
                      I am Nico and currently I study Physics.
                      In my freetime I like to build and repair stuff. Especially big battery's.
                      A few years ago I got myself an electric unicycle, monowheel or however you call that.
                      The battery bms was broken so I replaced and resolder that. Nothing big.
                      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                      07-26-2024, 06:13 AM
                    • dennis_elx33
                      NO BODY MARKING Diode
                      by dennis_elx33
                      Hello Everyone,
                      I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                      While compared to the reading of another diode from the next channel it won't read at reverse bias.
                      Now the problem is; it does not have any body marking.
                      So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                      What do you think is this diode?
                      Can you please suggest what part number can i use to replace this faulty diode instead?
                      Hoping that you...
                      06-14-2024, 12:36 AM
                    • eccerr0r
                      Electric lawnmower...purpose of diode...
                      by eccerr0r
                      I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                      The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                      08-27-2022, 12:54 PM
