No backlight Philips 42pfl6007h/12 TV after thunderstorm
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Hi, This post is a continuation of my previous post regarding another question about this tv. After getting struck by lightning my tv's backlight has stopped turning on, on powerup it turns on for a couple of milliseconds and then shuts off, I've tried forcing on the backlights and tested the mainboard which is working perfectly but the PSU shows no voltage output even when the backlight is disconnected leading me to believe that the PSU is almost certainly the problem. The PSU's model number is DPS-119CP (I've included an image below), I'm still unable to figure out whether this TV uses CFL or LED backlights (I would really appreciate it if you could help me figure that out). Any ideas of how I can proceed? As I would like to attempt to fix the PSU before completely replacing it. Thanks!
    (The backlight connectors are the ones at the top right in the image - 2 connectors, one black, one white)
    One other thing I forgot to mention, sometimes when plugging in the tv I see a spark happen a little above those 2 green coils that are located close to the fuse (between the top coil and that black cuboid capacitor). This doesn't always happen and I'm not sure which exact component is arcing
  • Maalobs
    • Jun 2016
    • 120
    • Sweden
    Re: No backlight Philips 42pfl6007h/12 TV after thunderstorm
    You have a link to the service manual in the other thread.
    Chapter 5 covers fault finding and you should study the chapter in detail, including the flowcharts.
    The service manual covers a chassis that is used in several different TV-models, and consequently some sections describe model-specific information.
    Use Table 2-1 to find out which sections are unique to your particular TV-model.
    The table points to section 7-2 for a description of the power supply, and there is additional information there about testing and component-level repairs on the power supply.
    Unfortunately there isn't a schematic provided for the power supply in your specific TV-model, though.
    A tip:
    You can open your images in MSPaint and add annotations into the bitmap to mark points of interest.
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      Thanks for the info! I've had a look at the service manual however unfortunately the PSU that I have is stated as being a "Black box" with instructions stating that you should just replace the unit.
      • lotas
        • Jan 2016
        • 4905
        • Russia
        Here is a diagram of the DPS-119AP A, but without the ratings.
          • 31298
          look at the lamp transformer and any semiconductors connected to it.
          coils make great EMP recievers during storms!
          • Gjackson
            • Aug 2021
            • 134
            • Malta
            So I searched around for a bit and found a diode ic that seems to have something to do with the backlights (image below), after testing with my multimeter I found it to be shorted as it lets current pass both ways, 0.1v one way and 0.3v the other way. I'll remove it from the Pcb and test it when it's out of circuit to see if its the problem
            • Gjackson
              • Aug 2021
              • 134
              • Malta
              Does anyone know how I can test if the transformer is good? I can't seem to found what pinouts it has. I believe these 2 are the backlight transformers, it seems to me that the larger one is the one that actually generates voltage for the connector on the PSU, any idea what the small one does?
              Edit: I probed the large transformer's input (the 4 pins on the hot side) and they are all completely shorted, is this normal?
              • lotas
                • Jan 2016
                • 4905
                • Russia
                I gave you a diagram
                  • Jul 2011
                  • 6070
                  You have to use a Ring Tester to check the transformer you can not use a ohm meter for the purpose of checking a transformer the only you can check for is an open winding
                  • Gjackson
                    • Aug 2021
                    • 134
                    • Malta
                    Update:
                    I found 2 bad Fet's that control the backlight, after replacing it works perfectly now! Thank you all.
                    • jellekaz
                      • Oct 2022
                      • Netherlands
                      Hello Gjackson,
                      Could you please give the positions of the two FETS and your solution (code on schedule, FET type, etc)? I might have the same problem.
                      • chestercc
                        Philips TV Backlight Repair
                        by chestercc
                        So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                        My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                        The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                        11-18-2022, 01:15 PM
                      • ohren
                        Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                        by ohren
                        I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                        The setup is basically:
                        Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                        Transistor is switching the 3.5 V supply on the power board....
                        12-05-2024, 11:10 AM
                      • Patrick501
                        Philips 55PUS6704 no picture, backlight ok
                        by Patrick501
                        I'd like to repair a Philips 55PUS6704.
                        It turns on and you can see the backlight, hear the sound but no picture.
                        When I disconnect one of the T-con cables, half of the screen turns white.
                        right cable disconnected= right side white
                        left cable disconnected= left side white
                        When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                        There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                        Also you can notice one single...
                        11-12-2025, 08:46 AM
                      • ovrax
                        Philips 55PUS6804/12 turn on & off (probably backlight issue)
                        by ovrax
                        First of all, please excuse me as I'm quite new to this field.
                        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                        The Ambilight works perfectly and stays on.
                        No sounds.
                        Thanks in advance.
                        08-25-2024, 04:33 AM
                      • triplefour
                        by triplefour
                        09-13-2023, 10:43 PM
