UN55D6900 BN44-00428B partial led driver circuit failure
  • R_J
    • Jun 2012
    • 9535
    Re: UN55D6900 BN44-00428B partial led driver circuit failure
    Which is "THE DIODE"? D9251? I assume bottom = anode & top = Cathode. Vdv is common to all for circuits, The high voltage may be due to lack of feedback, The circuit assumes the current through the leds is too low so it increases the voltage to compensate. Is the voltage across Q9223 source resistor high like before (2.27v)
    • RDC55
      • Dec 2017
      • 180
      Originally posted by Daveleone
      However, on all of the other circuits the voltage on the bottom of the diode is 116V and on the top of the diode is 160V, while on the affected circuit the voltage on the bottom of the diode is 116V but on the top of the diode is 222V, and the LEDs appear to be overdriven (too bright) on that strip (although I'm making that assessment from looking through the holes in the back of the TV because I don't have the panel disassembled).
      So just to be sure when you say bottom of the diode and top of the diode where are you probing - is that like Dxx51 anode / cathode? And just to be sure that is in respect to chassis ground?
      222V sounds scary, particularly if the LED's seem brighter. If they were probed at the 801A and 801B connectors just like when you hook up the LED tester (R3+ to L3-) then that would be a more exact measurement of the voltage drop across the string. I am thinking anything over about 170 VDC I would shut it down.
      Are we sure the 222V is not on the disabled string with the missing components?
      I suspect it would be brighter as a stand alone power supply since PWM would go to max drive. The measured voltage drop that you posted for the current limit resistors for the functioning strings indicates the LED's are just barely being driven. I believe that is somewhat normal particularly if there is no video then the PWM drive will adjust to minimum brightness.
      If you don't have an oscilloscope to evaluate the PWM signal then perhaps swapping the suspect LED segment PWM input wire with another segment might be beneficial to rule out any issues with the main PWM drive signal for that segment.
      • Daveleone
        • Apr 2016
        • 267
        Yes (D9521), yes (bottom=anode, top=cathode), and yes (wrt ground). Sorry for not being more specific, I'm brand new to this and didn't know which side was the anode vs cathode. I had to Google it
        Interestingly, sometimes when I read it it is fluctuating between 2.5v-2.6v. Other times it is 0V. I do notice the LEDs flickering when this happens. More below...
        Ok, I checked across R3+ to L3- and it sometimes it reads -2.5v, other times it reads 130v and then steadily rises to 219V. I notice the LEDs flickering, and the timing of the flickering seems to correspond to the change between the two voltage profiles I'm seeing. When I get the -2.5v reading across R3+ to L3-, the voltage across R9265 is 0v. When I get the higher voltage across R3+ to L3-, the voltage across R9265 is the 130V-219V reading.
        Yes, I'm sure about that. But I still am not sure how having that R9165 circuit with missing components would affect this R9265 circuit, if at all?
        Anyways, with the instability and strangely high voltage, do you think I maybe I should just take the loss on this one and order a replacement power supply? It's only $43 vs the time I'd have to invest on continuing to debug this. Either way, I've learned a TON about how these LED driver circuits work, what to test, how to test, etc. just by going through this process with you. The time invested so far has been a valuable learning experience for me. So thanks so much for that.
        • RDC55
          • Dec 2017
          • 180
          I am not quite sure how to comment on those voltage reading but this is my best guess, maybe R_J has a theory also.
          Was this supposed to say Q9253 and source resistor would then be R9265?
          And as before this meant R9265 source resistor, but see more below says 100's of volts or zero volts across R9265.
          First of all there is no way you can have 130 to 219V across R9265 unless it is open. At the lower number of 130V you are still talking thousand of watts so the resistor would have to be open, or the etch connectivity is not right.
          As for 219V directly across the LED's again this is really unsustainable as it would mean over 4V of Vf across each LED. I don't know the exact numbers of what is sustainable across an LED, but I would guess that would overheat and open them fairly quickly.
          One explanation for 219V across the LED's is that the LED's are defective, and when driven by full current one or more is going high resistance and the board compensates by upping the voltage to maintain the current. This of course would mean you have a bad strip in the TV.
          And perhaps another explanation is that IC9151 from either being defective or not receiving the proper feedback is boosting the voltage to an uncontrolled elevated level.
          Having that R9165 circuit with missing components should not affect the R9265 circuit, but it may cause an excess voltage as the boost voltage is adjusted upwards trying to increase current, which it can't because there are missing components. I was just asking to be sure about where you were measuring.
          And finally I would say yes to getting a new Power Supply. I am fairly experienced and I personally would not attempt to remove 20 pin IC's and reuse them unless replacements were not available. I believe the soldering process is stressful enough on a component, but the de-soldering process is even worse so I just wouldn't trust it. You said you weren't very experienced so kudos to you for even accomplishing the task with the etch / components still in tact.
          I would also keep in mind if the issue with the 219V across the LED's is actually a bad strip then you may also be replacing those. Perhaps it would be a good idea to swap the wires around again like you did before and see if a different segment behaves normally when driven by the suspect Power Supply channel.
          • Daveleone
            • Apr 2016
            • 267
            Yes, you are correct, it should be Q9253. I think R_J had a typo, but I understood what he was looking for.
            You're right, this was a mistake when I wrote my reply (sorry, I was running on 20 minutes sleep from the night before ). My statement should have read:
            "...When I get the higher (130V-219V) voltage across R3+ to L3-, the voltage across R9265 is the 2.5V-2.6V reading."
            I did some visual inspection and found that one of the surface mount caps and one surface mount resistor had shifted when I moved the IC between circuits. I resoldered those to make sure there was a good solder joint and was able to get 159V driving those LEDs on the circuit we've been working on. But it is not stable. When I power off the TV and power it on again, sometimes the voltage on that circuit across R3+ to L3- appears to be fluctuating between -2.5V and >100V. The other circuits are still ok. And if I plug in the main board and power on the TV, I only get 80V across each LED strip pair (eg R3+ to L3-, etc) (half the expected voltage drop), and the LEDs are obviously very dim.
            And finally I would say yes to getting a new Power Supply...You said you weren't very experienced so kudos to you for even accomplishing the task with the etch / components still in tact.
            I ordered the replacement power supply. Should arrive Saturday. I'll give a status update once I've received it. And thanks for the kudos! I am pretty happy with what I learned and my soldering accomplishments here, even if I didn't end up fixing the board. It's a big step forward for me skill-wise. Thanks again for your help!
            • Daveleone
              • Apr 2016
              • 267
              Update:
              - The first replacement power supply I received was all rusted & corroded. All I would get was a relay click on, then immediately off. No LED lights.
              - The company sent a replacement board and the replacement was also defective. It would click on, make a high pitched whine, the LEDs would come on momentarily, then relay click off.
              - Finally, the company sent a 3rd board and 3rd time's a charm, as they say! It works perfectly.
              Took a month to get a working board, but...TV fixed. Thanks again for all the help.
              • osrex
                LED DRIVER KEEPS DYING
                by osrex
                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                i have no datasheet at all for the LED lights, all i have is its length.
                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                05-05-2025, 03:36 PM
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
              • charif
                Audio Driver for Thomson P14C4BK128
                by charif
                Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                Here are the details:
                • Model: Thomson P14C4BK128
                • Operating System: Windows 10 64-bit
                If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                Thanks in advance for your help!
                04-30-2025, 05:41 PM
              • bohaboha
                how to install gl usb2.0 uvc camera device driver on windows 10
                by bohaboha
                Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                any help?
                01-26-2025, 08:33 PM
              • harp
                help with graphics driver for eMachine G725
                by harp
                I am trying to find graphics driver for old laptop eMachine G725, for winxp 32bit... from data on internet, https://gadgetaz.com/Laptop/eMachines_G725--1942 it will have Intel GMA 4500MHD graphics, so I downloaded a few of them but nothing work, error say: this computer does not meet the minimum requirements for installing the software. So, please somebody help me to find bare minimum graphics driver to see non deformed screen anymore...
                07-02-2025, 01:26 AM
