Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
  • thesteve
    • Jun 2021
    • 27
    Re: Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
    Thanks, this is all great information!
    So I have a matched pair of T-Con & main board from a supposedly known working set (cracked screen).
    My two previous attempts at USB update seemed to work but ended in failure.
    Do you guys think this was because the model number (and panel size) of those previous boards was a mismatch?
    Do you think I should try the USB firmware update again with this latest well-matched main board?
    I think the info on the USB is good, because as I mentioned, the TV (and flashy USB stick) went along with a long sequence of read/write/thinking LED flashes consistent with everything working... it just didn't end well.
    To be sure, I recopied over the file to the USB just in case I possibly corrupted something by removing it from my laptop without first "ejecting" it.
    Maybe if the t-con board knows the panel, I should use the old t-con board (?)
    What is meant by "end of lifetime." You mean Sony doesn't provide the firmware file? I found a file for the EX720 on a Sony website.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4687
      • Italy - Milan
      Yes and yes.
      What do you mean for old tcon, original one?
      Is not the tcon that knows the panel but mainboard that knows tcon, if model strings doesnt match the tcon is disabled, if i remember there are two enable signals from/to tcon.
      End of life mean that emmc contains a counter that considers that after tot acesses it is no more good and must stop working, for me its only a programmed obsolescence mechanism..
      • thesteve
        • Jun 2021
        • 27
        Correct, I should have said original tcon.
        So I think you're suggesting I use the new main board along with its matched tcon board and update the firmware.
        What is "tot accesses?" Is that Total? Could this Sony strategy be explained to me a little further please? Are you saying Sony prevents an old dog from learning new tricks (being reprogrammed to work again like I'm trying to do).
        Just to repeat past posts and so we're all on the same page, my TV still works 100% with its original tcon board and main board (briefly). Well, not 100%.
        I mean that even after unsuccessfully trying to replace the bad HDMI chip on the original board, the Sony boot logo still comes up perfectly (using the original boards), but since the HDMI chip is missing the bypass capacitors and input resistors, it eventually shuts down.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4687
          • Italy - Milan
          Sorry, total accesses..
          I cannot explain you much about end of life thing, never hit this argument much. So to resume it briefly, do an update, then go to service mode, update those few options, then hope for the best.. i warn you, it is possible that those bad situations are generated by a programmed obsolescence fact, to make a proof of this if you update your original board and follow the right manual steps maybe you brick also this board.. if this happens i have i test for you..
          • thesteve
            • Jun 2021
            • 27
            Thanks, that's an ingenious idea.
            I wonder if I should try to replace the missing tiny surface mount components first, though. If I apply myself it should be possible... it's just so incredibly stressful to deal with those microscopic parts.
            It seems I have a Sophie's choice of sorts.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4687
              • Italy - Milan
              #26
              Yes stressful, if your attempts are made with an hot air that risks to make the pieces fly away... but if you would warm the board from the bottom, it is way more easy, it's only a matter of still hand and good plier... i mean using a simple tablet of alluminum on top of a kitchen stove..
              • thesteve
                • Jun 2021
                • 27
                Well I have 30 days to return the latest eBay boards so it's worth a shot.
                That's good advice. I think there's a chance the replacement HDMI chip is properly soldered in place. So I was thinking of just using less than a drop of some kind of glue to stick the surface mount resistors/caps in place, and then once they are fixed I could solder them with a fine tip iron.
                They're so small, there's no identifying marks on them... they're either black or tan in color. I hope they are all the same. I guess I can confirm on the schematic but now you see another reason I did not want to attempt this.
                I have renewed courage, though. Thanks.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4687
                  • Italy - Milan
                  #28
                  Ah good, i had totally forgot the glue technique, never tried, maybe it needs an heat resistant one..(?)
                  • thesteve
                    • Jun 2021
                    • 27
                    Good point. I do have hi-temp epoxy I can mix up if necessary.
                    • thesteve
                      • Jun 2021
                      • 27
                      Got it!!!
                      So after two days of no reply from the eBay seller, I figured I would risk trying the USB firmware update and if it didn't work I'd just return it since the seller was ignoring me.
                      Well one thing I only mentioned in an earlier post was that I had to trim the ears on the LVDS cable for it to fit in the first and second eBay main boards I tried. This was because the connector was slightly different. (I should have taken this as a hint that I had the wrong board.)
                      So with the ears missing, when I would plug it into the proper board (my original board or the correct 55" EX720 board I just bought) there was room on either side for the cable to be off-center. I knew this because I would get error LEDs if it was not aligned perfectly.
                      So I before trying the USB update, I had to verify that the cable was centered. It took a few attempts. Well on the third try, I turned it on and to my absolute shock I not only had the sound of snow, but I had real snow! A beautiful picture!
                      So I can't take any credit for doing anything at all with this repair other than my mistakes. Too bad I'll never know if the USB update was the problem or not.
                      Oh well, at least I can verify that if you replace the main board with one from the same model and replace the matching T-Con board as well, it will work.
                      Thanks for everyone's replies. They kept me trying, and now I have my beautiful 55" Sony working once again as a second TV just in time for football season!
                      • Bruggefan
                        MD71-HB0 Firmware bricked of X557-AT2 NICs
                        by Bruggefan
                        Hi all
                        I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
                        I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
                        What happened:
                        - Did BMC firmware update in 2020
                        - Doing this, my MAC adresses were cleared from my nics
                        - Added MAC adresses with an eeupdate tool
                        Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
                        Since then, both my 10Gbit and my 1Gbit NICs stopped working.
                        The amber led on the NICs is solid on, no matter...
                        12-18-2025, 03:12 AM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                      • satbeginner
                        Firmware for Marantz SR6009 needed, bricked after power fail
                        by satbeginner
                        new to Badcaps, my name is Leo, I am a retired Dutch engineer now living in sunny Spain.
                        After a power fail my trusty Marantz SR6009 bricked its firmware.
                        I checked all voltages and fuses but these are all OK.
                        Furthermore, when I initiate the Firmware restore via USB, the display lights up with the USB message and the walking dots, so to me it seems the hardware is still OK.
                        But, I need the firmware file to restore the firmware via USB.
                        I know it is a longshot because of the age of this amp, but I can only hope..
                        Thanks...
                        04-04-2026, 03:13 AM
                      • Diah
                        needed Sony firmware PKG3.008EUA for any of this Model
                        by Diah
                        any one had Copy of this firmware PKG3.008EUA , its last Firmware and deleted from Sony Server support page. doesn't matter which region , it can be used for several Model .
                        i did find old Version, but need this one to solve Smart function of this Sony TV which never had in its working life internet confection. the resent Version as in attached Photo
                        Model share this Firmware are :
                        KD-49X8505B, KD-55X8505B, KD-55X9005B, KD-65S9005B, KD-65X8505B, KD-65X9005B, KD-65X9505B, KD-70X8505B, KD-75S9005B, KD-79X9005B, KD-85X9505B, KDL-32W705B, KDL-32W705C, KDL-32W706B, KDL-40W605B,...
                        02-11-2026, 04:21 PM
                      • weisian
                        VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
                        by weisian
                        I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
                        1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
                        2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
                        03-12-2026, 05:54 AM
