I have been replacing backlight strips for years now with no problems. Just this month however I have broken 2 screens trying to remove the glue which bonds to the bezel on TCL TVs. I have tried the hair dryer trick and heating up an xacto knife, neither of which worked successfully. Do you have any suggestions? Some techs say use Acitone. Wouldn't that damage the screen? Please help.
Hard glue/Cracking screen
Tags: None
Re: Hard glue/Cracking screen
I used to have this problem but someone else here posted a solution that I really liked. Use a feeler gauge. I like the .20 -.25mm. blades. Its strong enough the slice the adhesive but flexible enough to go over the humps in the bezel. -
That's great! I will try that next time. Should I heat up the feeler gauge? I believe that's where I got in trouble the most by using too much heat. Perhaps I should just warm it it up under hot water?Comment
I dont heat it. I dont think warm water would hurt tho. Just go slow.Comment
I'm sorry. I have been calling the plastic frame pieces glued to the underside of the screen the bezel. These pieces are clipped into the body structure and cannot be removed with the screen attached as too much flexing would be involved which would cause damage to the screen. I will try that however if all else fails. Thanks.Comment
Is it really actual glue, or just a thick double sided tape product? Sony uses a double sided tape to attach the panel to the panel mounting bezel which has to be removed before the panel is free to lift off.
You've got me wondering if the panel AND the mounting bezel can be removed together. Possibly so, but how would you put them back together by yourself? Three people, maybe... by yourself - not so easy.Comment
Yes, it is a double sided tape. However, I believe additional glue or silicon is added in certain spots which is impossible to sever. It's almost like epoxy.
I guess it would be possible to lift off the screen with plastic bezel landing strips still attached, but you would have to break all the clips off the strips first. Then you would have to make some kind of a jig to rest the screen down onto because the extra height of the strips would put stress on the panel edges when laid on flat surface.Comment
I just did a Vizio 55un-E1 and an Insignia Model: NS-55DR710NA17 and I had to leave the top and side panel support bezels attached to the panel as I was afraid to pry to hard with shim material. I set the panel on some thick cardboard (I think it's an artist painting protector) that is about a 1/2 inch thick and a bit smaller than the screen. Note it did take a couple of tries when lifting the screen to get all three bezels resting just right so they did not snag when lifting the panel, a helper here would be nice.
To reinstall I made up a couple of long thin pieces of cardboard that were wrapped with painters tape to thicken it and spaced them equally from the center on top of the diffuser sheet. I then set the screen on and could adjust the edges so the panel support bezels would drop down in alignment. I then pulled out the thin pieces of cardboard and snapped the panel bezels in place.
That might actually be overkill but I get the paranoia when handling the panel, but they seem to handle a little flexing OK. Just for fun check out Bigdog's repair at 28:30 mark:
https://www.youtube.com/watch?v=gVlMY7p7xuk
And not to criticize him because he does a lot of videos that are very helpful.
You can also add both the Insignia and Vizio bonded the panel boards to the frame with some god awful double-sided sticky squares that required a lot of time to carefully pry the boards loose - Bigdog shows those at 25:30.Last edited by RDC55; 07-18-2021, 08:01 PM.Comment
Why do you have to break all the clips off? You can usually unlatch them and stick a piece of heavy paper under them to prevent them from snapping back in place. Once all the clips are unsnapped, lift off the panel. I don't lay panels flat, but stand them on their edges against a wall, so having the bezel on them isn't a problem.Yes, it is a double sided tape. However, I believe additional glue or silicon is added in certain spots which is impossible to sever. It's almost like epoxy.
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo - Loading...
