I have been replacing backlight strips for years now with no problems. Just this month however I have broken 2 screens trying to remove the glue which bonds to the bezel on TCL TVs. I have tried the hair dryer trick and heating up an xacto knife, neither of which worked successfully. Do you have any suggestions? Some techs say use Acitone. Wouldn't that damage the screen? Please help.
Hard glue/Cracking screen
Re: Hard glue/Cracking screen
Originally posted by Wes Richards View PostThat's great! I will try that next time. Should I heat up the feeler gauge? I believe that's where I got in trouble the most by using too much heat. Perhaps I should just warm it it up under hot water?
Originally posted by alfatv View PostCan you try to remove bezel together with screen without separating them? You can practice on those screens you broke already.
Is it really actual glue, or just a thick double sided tape product? Sony uses a double sided tape to attach the panel to the panel mounting bezel which has to be removed before the panel is free to lift off.
You've got me wondering if the panel AND the mounting bezel can be removed together. Possibly so, but how would you put them back together by yourself? Three people, maybe... by yourself - not so easy.
Yes, it is a double sided tape. However, I believe additional glue or silicon is added in certain spots which is impossible to sever. It's almost like epoxy.
I guess it would be possible to lift off the screen with plastic bezel landing strips still attached, but you would have to break all the clips off the strips first. Then you would have to make some kind of a jig to rest the screen down onto because the extra height of the strips would put stress on the panel edges when laid on flat surface.
I just did a Vizio 55un-E1 and an Insignia Model: NS-55DR710NA17 and I had to leave the top and side panel support bezels attached to the panel as I was afraid to pry to hard with shim material. I set the panel on some thick cardboard (I think it's an artist painting protector) that is about a 1/2 inch thick and a bit smaller than the screen. Note it did take a couple of tries when lifting the screen to get all three bezels resting just right so they did not snag when lifting the panel, a helper here would be nice.
To reinstall I made up a couple of long thin pieces of cardboard that were wrapped with painters tape to thicken it and spaced them equally from the center on top of the diffuser sheet. I then set the screen on and could adjust the edges so the panel support bezels would drop down in alignment. I then pulled out the thin pieces of cardboard and snapped the panel bezels in place.
That might actually be overkill but I get the paranoia when handling the panel, but they seem to handle a little flexing OK. Just for fun check out Bigdog's repair at 28:30 mark:
https://www.youtube.com/watch?v=gVlMY7p7xuk
And not to criticize him because he does a lot of videos that are very helpful.
You can also add both the Insignia and Vizio bonded the panel boards to the frame with some god awful double-sided sticky squares that required a lot of time to carefully pry the boards loose - Bigdog shows those at 25:30.Last edited by RDC55; 07-18-2021, 08:01 PM.
Originally posted by Wes Richards View PostYes, it is a double sided tape. However, I believe additional glue or silicon is added in certain spots which is impossible to sever. It's almost like epoxy.
