LG OLEDB6, no picture, get picture
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    Hi guys,
    I bought that TV as wrong as won't turn on. After plugged give 2 click, than one click and blink 3 times the led.
    I have checked many things, there is no short, voltages ok. Than was without heatshield for an hour under voltage, than turned ON, got a picture, yess...
    I have assemled, after run it for half an hour, than again no picture, but still has sound. Since turned off again the same, won't turn ON.
    For me pretty sure it is a BGA problem, but not sure which. 90% that is a GPU on the T-Con board, but what you mean guys? Can be the processor on the MB? If 100% GPU than i will send it for rework.
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    Re: LG OLEDB6, no picture, get picture
    I told wrong, the TV now is on, but simply give no picture. EDIT: however, it is now surprising that 12.9 can be measured on the 12V side and 25.5V on the 24V side. Any idea please guys?
    • Formaster
      • Jul 2021
      • 68
      • Switzerland
      After few start now the voltages go higher again. 13.2 and 26.4. What can be the problem? Help please ...
      • Formaster
        • Jul 2021
        • 68
        • Switzerland
        Now 27.5/13.8V. Any idea somebody? I wont start anymore until solve that high voltage.
        • mmartell
          • Oct 2013
          • 3189
          With power off and unplugged use a hair dryer to heat only one of the suspect BGA ic's. If you get a picture you likely have found the problem. If not, try another.
          • Formaster
            • Jul 2021
            • 68
            • Switzerland
            Thanks. Did'nt works, but found another problem, it is new.
            The marked coil has a short, than one of theses beeps not. I thinking about to order a t-con board, but how can i test the PS of that 100% good is? Doesnt want to kill the changed t-con.
            +these 2 caps has short.
            • mmartell
              • Oct 2013
              • 3189
              A coil should show low resistance. And the "caps" in your second pic are not caps they are filters and should also show a low resistance.
              • Formaster
                • Jul 2021
                • 68
                • Switzerland
                Thank you! I ordered a T-CON, now got a picture but i have one black horizontal line on the screen. Can be the display defected or this T-CON board trash?
                • mmartell
                  • Oct 2013
                  • 3189
                  I don't know much about OLED's perhaps someone else will answer that BUT I think the horizontal line is a panel failure which probably killed your original tcon and if so will likely kill its replacement in time.
                  • Formaster
                    • Jul 2021
                    • 68
                    • Switzerland
                    thx, on panel mean you the display or the MB? sorry for the stupd question...('s)
                    • mmartell
                      • Oct 2013
                      • 3189
                      Display itself or if you're lucky the problem is on the panel boards (attached to the panel) and can be repaired.
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • CyberPhoenix
                        Issue with picture quality of Sony bravia TV
                        by CyberPhoenix
                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                        01-22-2024, 02:08 AM
                      • Rauni
                        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                        by Rauni
                        Hello, this is my first post on this forum, and my first attempted to repair a TV.
                        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                        Read also that we should test what happens if we...
                        10-01-2023, 12:06 AM
