Led backlight universal board
  • Hornnumb2
    • Feb 2011
    • 210
    I ordered one of these off Aliexpress but haven't been able to get it to work correctly. I am feeding it with 24 volts from main board and it seems to be just passing the 24v to output. I am trying to replace some ccfl with led strips. Any ideas what I am doing wrong. I have tried this one. Ca-266. https://www.aliexpress.com/item/3297...6c4a25c43f8d-3
    Thanks Michael
  • R_J
    • Jun 2012
    • 9535
    Re: Led backlight universal board
    Likely the wrong led strips
    • Hornnumb2
      • Feb 2011
      • 210
      Any idea what a 10 led strip should pull in amps?/
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • ermals
        Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
        by ermals
        Hi all!
        I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
        1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
        2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
        3. I've checked voltages...
        08-01-2022, 10:35 AM
