Samsung QLED Q60R constant reboot issue
  • pobrklija
    • Aug 2012
    • bosnia
    Re: Samsung QLED Q60R constant reboot issue
    Just wanted to say that i had the same problem. Diode d001 is shorted in the right part of screen. I removed it and tv is working fine. Thank you
    • Mordecai253
      • Nov 2022
      Originally posted by jneupauer@sbcglobal.net
      this QN55Q60RAFXZA was rebooting.
      backlights stayed on when power cable to main was disconnected.
      i reconnected the cable.
      pulled ldvs cables... set stayed on.
      turned up volume... had sound.
      remote turned the set on and off normally.
      tried each ldvs cable one at a time... set stayed on.
      reconnected both ldvs.. set reboots.
      i removed panel circuit board cover and let it run with both ldvs cables connected.
      felt around the boards until i burnt my finger.
      found diode pack hot.
      removed two hot diode packs.. restored the tv to a working state.
      they are very tiny
      This saved me a lot of time. I got a set for peanuts from a fellow who had given up on a QN65Q60R that was boot looping. He had attempted to block traces on the LVDS cables and had concluded there was a short on the board. With the help of a infrared thermometer and temp probe I was able to identify a single 6514P ESR protection diode. third in from the left edge. I did a bit of a hatchet job trying to remove it but as soon as I was done I plugged it back in and the TV turned on and stayed on with the full image restored, no lines, artifacts, etc.
      Save for a 'water spot' near where I was working in the lower left corner. It might be flux (yeah, I know) or simply IPA I was using to clean. The use of an air compressor to dry probably exacerbated things, pushing the material up the COF cable. (Frankly, I didn't even know fluid could travel, apparently along the inside, of those cables) I've tried to gently heat the panel from both sides and carefully apply some negative pressure by shop vac - so far without any luck. The spot might just be getting smaller on its own but it's only been a few days. If any one has any advice on how I might ameliorate my blotch, I'd appreciate it. Otherwise, thanks a million for this thread. It was a marvelously simply fix.
      One last question for y'all. What is the best explanation for this failure? It seems the diode failed in the open state with high resistance either direction versus a shorted diode. Was this simply a defective component or did it fail while actually protecting data lines from ESD, power surge etc.? It won't be an easy component to solder back in place and I guess I'd like some peace of mind if I decline an attempt. Thanks!
      Note the blotch changes tone with viewing angle / pics taken at same time
      • S14Sr20det
        • Mar 2023
        • 5
        I had the same issue and also repaired by replacing with 6514p from Digikey on a Samsung. I have since repaired another tv (nec 55”) by simply removing both of the esd diodes and NOT putting any back in their place. I use heat tape on the cof cable strip and a terry cloth damped with isopropyl under the strip to soak heat and avoid lifting the pressed and glued strip. Then generous amount of flux and chip quick solder to knock them off then follow with iso then more flux and desolder wick to clean up remaining solder. Many TVs don't seem to have these diodes and the newer ones that do have them tend to fail easily.
        • blikker8
          • Nov 2023
          Hi. My tv (QN55Q60RAF) has the same rebooting issue. The cluster of diodes that contains D001 is extremely hot on the left side of the LCD panel.
          I am inexperienced in soldering and removing components - what kind of equipment would I need to attempt removal? And are there any tutorials out there that could help me? I've images of the hot cluster below. Thanks!
          https://cdn.discordapp.com/attachmen...5e646fe34722a&
          https://media.discordapp.net/attachm...446&height=438
          • jason123
            • Oct 2015
            • 1069
            I used OnSemi part SZESD7004 and that Did not work. I guess the 6514p seems to have an additional diode on the 3,8 pins.. maybe that's the difference? Anyway I have those on order, just now sure why the OnSemi parts didn't work.
            • lotas
              • Jan 2016
              • 4618
              • Russia
              #26
              Originally posted by jason123
              Do you have a part number for these diode pack anybody? I removed the D002, the TV was working fine then I installed the OnSemi ESD7004, someone recommended on a different post, and now the TV is rebooting ago, though the pack is not getting hot.
              We removed it and there is no need to install anything else, everything will work fine, these diodes do more harm than good.
              • lotas
                • Jan 2016
                • 4618
                • Russia
                #27
                Datasheet for 6514P.
                • jason123
                  • Oct 2015
                  • 1069
                  I guess the 6514P is bidirectional and the one I used is unidirectional? Can't think of why else it wouldn't have worked. Can't imagine they just added clamping diodes just because. The fact they failed, tells me these are taking heavy hits, so running without them may not be very smart - I'm guessing Click image for larger version
                    • 12206
                    • U.S.
                    #29
                    Good question, I too would like to know if these need to be replaced for safety or are they just redundant components. They fail a LOT, is it poor design? guess I also wonder if maybe they know these will fail just out of warranty and people will buy a new tv?
                    Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND IT'S ALWAYS IGNORED SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS.
                    • jason123
                      • Oct 2015
                      • 1069
                      Confirming that uClamp 6514P works fine to replace the defective IC. ESD7004 (non-bidirectional) DOES NOT work.
                      • edugimeno
                        • May 2017
                        • 581
                        • Spain
                        #31
                        Hi everyone!
                        I just bought an "as is" Samsung QE50Q60 Smart TV, it wants to start, lights up BL, but enters into a reboot cycle not even getting to show anything on screen.
                        Should I start by going straight to these diode bridges? Sounds like it could be the same?
                        Thanks a lot!
                        • jason123
                          • Oct 2015
                          • 1069
                          It does sound like a similar problem. IF it's a diode packe issue, the shorted diode pack gets very hot (be careful not to burn your fingers!), At least it did in my case. You could do some voltage measurements on the PS rails first, just to be sure. Good luck
                          • edugimeno
                            • May 2017
                            • 581
                            • Spain
                            #33
                            Ok will check this next weekend. I've also seen that these tvs usually fail due to shorts inside the panel which is not repairable but the tape masking might take it back to life with some quality loss...
                            Anyone know if this method would last or would only give a couple.months? Because that's what I've read...
                            Will keep you all posted when I try it
                            • Storyteller12
                              • Jun 2020
                              • 624
                              I’ve seen the tape method work for years but as you mentioned the picture is usually degraded in some way or another.
                                Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                09-07-2024, 12:10 AM
                              • x_orange90_x
                                Samsung UN50KU6300F constant reboot, bad backlights?
                                by x_orange90_x
                                This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
                                02-09-2024, 08:41 PM
                                09-07-2024, 05:50 AM
                              • Kaar3l
                                Samsung QLED QE65Q7FNAT only standby light
                                by Kaar3l
                                TV: Samsung QLED QE65Q7FNAT
                                PSU: BN4400940A
                                MB: BN94-12832K
                                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                09-24-2024, 01:35 PM
                              • brkie
                                Samsung UE75TU6905 reboot loop
                                by brkie
                                I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                I read on Samsung's website (reviews)...
                                09-04-2024, 01:45 AM
