Samsung smart tv bad power board BN44-0503A
  • xfox
    • Feb 2018
    • 84
    Re: Samsung smart tv bad power board BN44-0503A
    ok, so with pull up resistor voltage is 12.75 13.3 and 13.4
    • iamosmoses@live.com
      • Apr 2018
      • usa
      where can i get a schematic diagram for bn44-00503a samsung power board??
        • 12328
        • U.S.
        so what are your symptoms live.com?
        • ohren
          by ohren
          09-08-2023, 05:24 PM
        • C152Heavy
          by C152Heavy
          Summary for TL-DR readers:
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
        • MacGyver's paperclip
          what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
          by MacGyver's paperclip
          TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
          07-01-2023, 12:12 PM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
