Bush DLED32287HDCNTDFVP led smart tv screen not turning on
  • ioanban
    replied
    Re: Bush DLED32287HDCNTDFVP led smart tv screen not turning on
    pins 3 and 4 show 1.95V
    pins 11 and 12 show 12.3 V
    the rest nothing
  • dick_barton
    replied
    It's the voltages on all the connector pins that are needed.
  • vinceroger69
    replied
    Originally posted by ioanban
    hi dick_barton,
    i have 12.3 V
    on that connector you should have more than one voltage reading maybe a 5v etc
  • ioanban
    replied
    hi dick_barton,
    i have 12.3 V
  • dick_barton
    replied
    Can you give the voltages on the 12 pins of the connector.
  • ioanban
    replied
    1.The fuse is ok.
    2. Both of the 400v capacitors look ok and I'm getting 342V
  • dick_barton
    replied
    What DC voltage do you have between the two legs of the large 400V capacitor.
    Be careful when measuring for you meter probes not to slip.
  • vinceroger69
    replied
    on your third picture by the ribbon cable connector there is a fuse do you get voltage too each side of it?
  • ioanban
    replied
    Hi guys,
    Sorry for the late reply but i have some health problems and I'm not able to be acctive all the time.
    I have tried everything you asked me, i get only standby light and backing light (i have tested it with the led tester)
    I have had 2 main boards replacements and it's still the same.
    please tell me how to do the testing when you suggest checking something because i'm a newbie and i get confused .
    I'll try to attach a picture with every board from the tv but i have a feeling that the led panel is gone .
    Thank you all for your patience to try and help me !
  • ducky29
    replied
    Re: Bush led smart tv screen not turning on
    How many volts do you have at Q43?
  • Storyteller12
    replied
    How did you verify the backlights work? Does the tv and backlights stay on and and just no picture. Or does it light up and then turn the tv off.
    Did you test them with a led tester? If so what was the volts it was reading.
  • dick_barton
    replied
    Check Q43 and Q31 on the mainboard which supplies the panel voltage.
  • ioanban
    replied
    As i was saying in the description, the backing light is fine , turns on when pushing the power button and i've replaced the main board with a functional one but the result is the same , the panel won't turn on .
  • ioanban
    replied
    I didn't see any legend with the voltage to be able to check if the main board is receiving enough voltage.
  • neilc6
    replied
    You need to more accurately describe your symptoms. Do you have standby light and when you press power, it responds and turns on with no video or no backlight. Or does it not respond to the power button? If TV turns on with no backlight, backlights are suspect. If the TV has standby light and doesn't react to power button, then main board is suspect. If TV turns on with no video but has backlight, then tcon is suspect. If you don't have a tcon then panel is suspect.
  • Storyteller12
    replied
    Did you check voltages with a multimeter? Is there a legend on the board with pin out of the voltages? Also I’ve never heard of “Bush” so posting pics of all the boards with high res photos would help, if you want help.
  • Bush DLED32287HDCNTDFVP led smart tv screen not turning on
    I have a Bush DLED32287HDCNTDFVP (the one without a T Con board ) with a screen that won't turn on.
    I have checked the backing light (it's fine), the main board seems to receive power as well, i have even tried replacing the main board but without any success and checked all the connections .
    Does anyone have any idea what might be the problem ?
    Thank you,
    John
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • TheDando
    MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
    by TheDando
    Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
    10-28-2024, 06:59 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • mrtek
    Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
    by mrtek
    Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
    11-26-2024, 09:58 AM
