Bush DLED32287HDCNTDFVP led smart tv screen not turning on
  • ioanban
    • Dec 2020
    • 47
    Re: Bush DLED32287HDCNTDFVP led smart tv screen not turning on
    Problem: TV screen has no picture at all , I can't see any thing, all black.
    The TV's backlight is working (tested with led tester), I have changed the motherboard (tried 2 of them but the same no picture). I have measured the Voltages on the power board ( you have them in one of the previous posts), i have stand-by light when plugged in .
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The led tester is useful but is not a definative test due to the fact that only a low current is fed to the leds.
      Do the leds flash when you come out of standby?
      What voltage do you have on the led output connector at switch on?
      What is the dc voltage on pin 16 and on pin 5 of U2 (MAP3249)
      • cheeky2
        • Dec 2012
        • 337
        For people to help you and guide you need to give as much information as you can so that they can try to guide you in the right direction for resolving your issues.
        Without full information from your answers then you will take longer to get to your resolution if that is possible.
        First off I would suggest you remove the led power connector and place your led tester across the leds to power them on independently without the power from the TV's power supply.
        Then power on your TV and see if you get a picture on your TV. If you get a picture then clearly one or more of your leds could have failed or your power supply is faulty.
        Let us know what your results are, as they will indicate where the issue lies.
        • ioanban
          • Dec 2020
          • 47
          The LED's don't flash at all when coming out of standby.
          On the led output connector at switch on i have 30V.
          I can't find any U2 (MAP3249)
          • ioanban
            • Dec 2020
            • 47
            • ioanban
              • Dec 2020
              • 47
              #26
              I have done exactly as you have told me but i still don't get any picture .
              I have given all the information I had and as much as i could get every time. I do apologise if you think I'm not paying attention to what I'm being asked.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Post some photos of the top and underside of your power supply.
                • cheeky2
                  • Dec 2012
                  • 337
                  #28
                  The string of leds that light your TV screen up will have a higher voltage than 30V. The Led voltage string is measured with reference to the ground of the TV. So place one probe on the metal chassis of the housing and one on one of the two connections for the led power connector. Measure both voltages.
                  Though from what you have said so far I would suspect a faulty screen.
                  Use a scart device to check the main board by connecting up a fully wired scart lead to a vhs player or a dvd player. Put the scart device that you have connected to the TV into standby. Now turn on the TV from standby give a few moments to initialise the TV then turn on the scart connected device from standby to on. Play the media you have for the scart connected device ( ie vhs tape on vhs recorder ensuring that the media has audio coming out) or play a cd on the dvd player. If your main board is good then you should get audio and should be able to adjust volume with remote control and mute it. The scart lead will switch over automatically to the scart connection without any interaction of the remote control.
                  If you get audio then I would say your main board is good.
                  • ioanban
                    • Dec 2020
                    • 47
                    #29
                    Picture attached. Everything seems to be ok.
                    • ioanban
                      • Dec 2020
                      • 47
                      #30
                      That's exactly how i took the measurements!
                      The main board, i have previously said that i had it replaced it and i still haven't solved the problem !
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Disconnect the led connector and use you led tester to power up the leds and switch on your set and see if you have a picture.
                        • ioanban
                          • Dec 2020
                          • 47
                          #32
                          I've tried before, i got no picture .
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            If there is an smd fuse on the panel strip, have you checked it
                            • ioanban
                              • Dec 2020
                              • 47
                              #34
                              yes, there's one and it's ok
                              • ioanban
                                • Dec 2020
                                • 47
                                #35
                                I have just reread your first post and I am not too sure what the problem is.
                                You say you the backlights are OK. Are they coming on but there is no picture.
                                You have also changed the mainboard and you still have "the problem".
                                Can I ask once again for a detailed description of what is and isn't working.
                                you have said it as well. I have power, I have replaced main board, I have verified the backing light, there is nothing wrong with them and I still have no picture in the screen !
                                I'm thinking that the panel is gone.
                                • cheeky2
                                  • Dec 2012
                                  • 337
                                  #36
                                  But you failed to say whether you get audio or not? Changing a main board doesn't necessarily mean that the main board is good. If you have a different main board which uses a different screen combination then you can quite easily get backlights but no screen display. Did you realise that?
                                  Main boards can be programmed up for different screen combinations and are often done so in the same model of TV when the manufacturers get different screens. So purchasing a main board for a TV based on the model number of the TV isn't advisable and can give you exactly the symptoms you describe.
                                  Often sellers on ebay have no clue about this!
                                  Though in all probability your screen is goosed!
                                  • ioanban
                                    • Dec 2020
                                    • 47
                                    #37
                                    I'm sorry for omitting to say that I did get sound with an dvd player but no picture.
                                    when I'm ordering parts for tv's I'm always making sure they have the same part number, I know that same model tv can have different boards .
                                    Thank you,
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • TheDando
                                      MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                                      by TheDando
                                      Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                                      10-28-2024, 06:59 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • mrtek
                                      Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                      by mrtek
                                      Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                      11-26-2024, 09:58 AM
